I used gpu on TX1 for Sift(a feature matching algorithm).After sevel minutes’ executing it crashed with the error warning:
gk20a gpu.0:gk20a_fifo_handle_mmu_fault:mmu fault on engine 0,engine subid 0(gpc),client 10(t1 3),addr 0x00000000:0x22400000,type 2(pte),info 0x00000a82,inst_ptr 0x148b56000
gk20a gpu.0:gk20a_fifo_set_ctx_mmu_error_tsg:TSG 0 generated a mmu fault
gk20a gpu.0:gk20a_error_notifier:error notifier set to 31 for ch 502
safeCall()Runtime API error in file<cudaSiftH.cu>,line 247:unspecified launch failure.[224.191590] gk20a gpu.0 :gk20a_set_error_notifier:error notifier set to 31 for ch 501
gk20a gpu.0: gk20a_set_error_notifier :error notifier set t 31 for ch 500
gk20a gpu.0: gk20a_set_error_notifier :error notifier set t 31 for ch 499
gk20a gpu.0: fifo_error_isr:channel reset initiated from fifo_error_isr;intr=0x100000000
I don’t know how to locate the error ,and the file<cudaSiftH.cu>,line 247: safeCall(cudaThreadSynchronize());
Will you help me how to deal with this bug.Thanks.
