File already exists in database: schema.proto
  • change the kafka adapter in DS6.3 to generate libnvds_kafka_proto.so dynamic library.
  • got the Error
[libprotobuf ERROR google/protobuf/descriptor_database.cc:58] File already exists in database: schema.proto
[libprotobuf FATAL google/protobuf/descriptor.cc:1358] CHECK failed: GeneratedDatabase()->Add(encoded_file_descriptor, size):
terminate called after throwing an instance of 'google::protobuf::FatalException'
  what():  CHECK failed: GeneratedDatabase()->Add(encoded_file_descriptor, size):
Aborted (core dumped)
  • my env
Software part of jetson-stats 4.2.4 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin Developer Kit - Jetpack 5.1.2 [L4T 35.4.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3701-0005
 - Module: NVIDIA Jetson AGX Orin (64GB ram)
Platform:
 - Distribution: Ubuntu 20.04 focal
 - Release: 5.10.120-tegra
jtop:
 - Version: 4.2.4
 - Service: Active
Libraries:
 - CUDA: 11.4.315
 - cuDNN: 8.6.0.166
 - TensorRT: 5.1.2
 - VPI: 2.3.9
 - Vulkan: 1.3.204
 - OpenCV: 4.6.0 - with CUDA: YES
  • I try to fix the bug follow some link. But I cant to fix the bug.
    the links
https://blog.csdn.net/sepnineth/article/details/106529302
https://stackoverflow.com/questions/37051635/several-shared-object-using-same-proto-leading-the-the-error-file-already-exist
https://groups.google.com/g/protobuf/c/RZRCnOywdSk/m/s5QvifLCBgAJ?pli=1
  • please give some guide! thks!
using the steps in readme, I am not able to reproduce this issue In DS6.4. can you use libprotoc 3.19.4?
I am now using proto 3.6.1. I will try the protobuf 3.19.4 in DS6.3
(base) orin@orin-root:~/workspace$ protoc --version
libprotoc 3.6.1
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
thanks, the bug is fixed.
