When installing JetPack 5.0.1 using SDK Manager 1.8 0.10363, I get the following error:
08:54:22 INFO: File System and OS - target_image: 1. The root filesystem, provided with this package,
08:54:22 INFO: File System and OS - target_image: has to be extracted to this directory:
08:54:22 INFO: File System and OS - target_image: /media/phquanta/DATA/Jetpack_5.0/hw/JetPack_5.0.1_DP_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/rootfs
08:54:22 INFO: File System and OS - target_image: -----------------------------------------------------
08:54:22 INFO: File System and OS - target_image: 2. The root filesystem, provided with this package,
08:54:22 INFO: File System and OS - target_image: has to be extracted with ‘sudo’ to this directory:
08:54:22 INFO: File System and OS - target_image: Consult the Development Guide for instructions on
08:54:22 INFO: File System and OS - target_image: extracting and flashing your device.
08:54:22 INFO: File System and OS - target_image: |||||||||||||||||||||||||||||||||||||||||||||||||||||
08:54:22 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
08:54:22 INFO: File System and OS - target_image: [host] [ 320.00 KB used. Disk Avail: 64.27 GB ]
08:54:22 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP Install took 2m38s ]
08:54:22 ERROR: File System and OS - target_image: command terminated with error
08:54:22 SUMMARY: File System and OS - target_image: First Error: Installation failed.
