FileNotFoundError: Experiment spec file wasn't found
• RTX3050Ti
• TAO Annotation convert
• TAO version 5.2.0.1
• Training spec file(If have, please share here)
data_spec.txt (304 Bytes)
• I’m trying to use tao dataset annotations to convert the dataset from coco to kitti since detectnet_v2 provide kitti configuration, but I received this error.
Also here is my tao mounts.
“Mounts”: [
“source”: “/media/ezahan/DATA/workspace/tao-experiments”,
“destination”: “/workspace/tao-experiments”
“source”: “/media/ezahan/DATA/workspace/tao-experiments/traffic_object_detection”,
“destination”: “/workspace/”
Any help would be appreciate
It is expected to be path inside the docker. According to your tao_mounts.json file, it should be /workspace/tao-experiments/traffic_object_detection/result.
Please modify others as well, for example, the path inside the spec file.
For this experiments, i use traffic_object_detection which destination would be in /workspace.
Yet still persist the same error.
For spec file, i also modified the path to full path in my pc.
data_spec.txt (659 Bytes)
When you run tao dataset annotations convert -d data_spec.txt -r result,
the path to data_spec.txt is a path inside the docker. The path is defined in tao_mounts.json.
