Kit App template currently cannot access files that are hosted in wsl
a reference application like Paraview (Open Scientific Visualization application) can:
this occurred while working with Kit-CAE extension. One of the suggestion was if KIT supports then KIT-CAE would automatically support as well.
reference: Custom File paths in Kit CAE unable to locate OpenFoam files · Issue #20 · NVIDIA-Omniverse/kit-cae · GitHub
Yes that sounds expected. It does not work with networked, or non normal drives. It does work with “mapped” drives in windows, meaning a network drive mapped as a “local” drive. You could try that.
the drives are mapped now (E:\,F:\) but cannot yet read them ?
Omniverse does support networked and mapped drives that are not Omniverse Nucleus servers.
You can access files from:
- Network shares (SMB/CIFS, NFS)
- Mapped network drives (Windows drive letters pointing to network locations)
- UNC paths (e.g.,
\\server\share\path)
- Local file systems
Key Points:
- File Protocol Support: Omniverse applications support
file:// URIs for local and network file access in addition to omniverse:// URIs for Nucleus servers.
- Performance Considerations:
- Network drives may have slower performance compared to Nucleus servers, especially for large USD files with many layers
- Nucleus is optimized for USD workflows with efficient caching and streaming
- Collaboration:
- Standard network drives work for file access but don’t provide Nucleus features like:
- Live collaboration and real-time syncing
- Version control and checkpointing
- Asset dependency tracking
- Configuration: You can open files from network locations through:
- The File Browser extension (standard OS file dialogs)
- Direct path entry in content browsers
- Command-line arguments with file paths
Recommendation: While networked drives work fine for single-user workflows or small teams, consider using Nucleus for production environments where you need collaboration, version control, and optimized USD streaming.
i’m not using any custom servers other than locally hosted on same machine ( WSL) and after you informed to map the drives, i did, but it refuses to detect mapped drive (that are not any custom server/Omniverse Nucleus server).
This is through WSL, correct? That is Linux running on Windows? I am not familiar with that setup as much. I can tell you, that I am writing this right now on a Windows 11 machine, running kit, that can detected two networked drives that are mapped as local drives. Beyond that, I have not tested it.
