I am trying to generate a matrix of colors to represent a fractal in matlab.
I would like to use mex files anda cuda.
I wrote a code to fill a vector (that matlab sees as a matrix) using cuda but I am having problems.
Matlab close when I execute my mex function. I think is some memeory problem in cuda.
This is the first time I am gonna write something with cuda.
Could you take a look to my code and tell me where I am mistaking?
The code is here:
http://dl.dropbox.com/u/2723775/julia_mex_2.cu
Thank you!
Code here too:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "mex.h" //--This one is required for mex files
#include "cuda.h" //Cuda libreries
#include "cuda_runtime.h"
#include "cufft.h"
#include "driver_types.h"
int color_julia(double x, double y, double cx, double cy, double endpoint, double iteractions);
void checkCUDAError(const char *msg);
void julia_fractal(int widht_x , int width_y, double re_c, double im_c, double endpoint, double iteractions, double *output);
void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
//Declarations
double x,y,cx,cy,endpoint, iteractions;
x = mxGetScalar(prhs[0]);
y = mxGetScalar(prhs[1]);
cx = mxGetScalar(prhs[2]);
cy = mxGetScalar(prhs[3]);
endpoint = mxGetScalar(prhs[4]);
iteractions = mxGetScalar(prhs[5]);
/* Create the array */
plhs[0] = mxCreateDoubleMatrix(x,y,mxREAL);
julia_fractal(x,y,cx,cy,endpoint,iteractions,mxGetPr(plhs[0]));
return;
__global__ void fill_colors(float *output,int size)
int i = blockIdx.x * blockDim.x + threadIdx.x;
if(i<size){
output[i]=100; //color_julia (xpos, ypos, re_c, im_c, endpoint, iteractions);
}else{
return;
Prototype of function that decide the color
void julia_fractal(int width_x , int width_y, double re_c, double im_c, double endpoint, double iteractions, double *output)
* i,j = counters
* limit_x,limit_y = position on screen starting from the center
* x,y = counters/position on screen
* test = variable to decide if or not print the matrix for a test
int i, j, limit_x, limit_y, x, y, test;
float *device_output, *aux;
aux=(float*)calloc((width_x*width_y), sizeof(float));
//Cuda memory alloc
cudaMalloc((void **)&device_output,(sizeof(float)*(width_x*width_y)));
* xpos,ypos = coordinates to store the Z
* Z is calculed using:
* xpos = (double) ((x - limit_x)*2*threshold)/width_x;
* ypos = (double) ((y - limit_y)*2*threshold)/width_y;
double xpos, ypos, threshold = endpoint;
int counter = 0;
* Here we go to the center of the screen
limit_x = width_x / 2;
limit_y = width_y / 2;
test = 1;
if(test == 1){
printf("PRINT\n");
for(i=0; i<(width_x*width_y);i++){
printf("output1[%d] = %d",i,output[i]);
printf("\n");
printf("END PRINT\n");
//configuration of the calling
dim3 dimBlock(16);
dim3 dimGrid((width_x + dimBlock.x-1)/dimBlock.x, (width_y + dimBlock.y-1) / dimBlock.y);
//CUDA functioln calling
fill_colors<<<dimBlock, dimGrid>>>(device_output, (width_x*width_y));
//CUDA error control
cudaThreadSynchronize();
checkCUDAError("call test_1");
//copy memory
cudaMemcpy(aux, device_output, sizeof(float)*(width_x*width_y), cudaMemcpyDeviceToHost);
//casting
for(i=0;i<(width_x*width_y);i++)
output[i]=(double)aux[i];
* Test
* value test to 1 if you want to print the matrix
test = 1;
if(test == 1){
printf("PRINT\n");
printf("output2[%d] = %g",i,output[i]);
printf("\n");
return;
* This functions works on complex numbers (the C) and produces the color for
* the coordinate we are asking for on axis.
int color = 0,i;
double zx = x, zy = y;
double new_zx, new_zy;
for(i = 1; i<=(int)iteractions;i++)
// calculate Z
// re(z)=re(z^2) + re(c)
new_zx = zx * zx - zy * zy + cx;
// im(z)=2*im(z^2) + im(c)
new_zy = 2 * zx * zy + cy;
zx = new_zx;
zy = new_zy;
* Calculate the module than check if is out of range 2 (the one we are common using
* in all the implementations). sqrt(re^2 + im^2) > 2 ???
if (sqrt(zx * zx + zy * zy) > endpoint)
break;
// increment color
color++;
// se supera il tetto max ritorna colore
if (color >= 256)
break;
return color;
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
fprintf(stderr, "Cuda error: %s: %s.\n", msg, cudaGetErrorString( err) );
exit(-1);
/* TEST
void main(int argc, char **argv){
double *k;
k = calloc(100,sizeof(double);
julia_fractal(10,10,2,1.5,k);
