Hi, I am new to CUDA.
I am trying to fill triangles to array but one by one (no space between data)
struct Vertex
float3 pos;
float3 normal;
__device__ int globalIndex = 0;
__global__ void simpleKernel(Vertex * output)
//struct Triangle { Vertex1, Vertex2, Vertex3 }
//__shared__ <TriangleStruct> tmp[100]; //- using 100 threads per block
//int writeIndex = threadIdx.x + threadIdx.y;
//--- Produce Triangle --
// if triangle not created - exit thread
//tmp[writeIndex].Vertex1 - save triangle vertices...
//__syncthreads();
//int globalWriteIndex = atomicAdd(&globalIndex, 3); //atomic returns oldValue
//write to output:
//out[globalWriteIndex + 0] = tmp[writeIndex].vertex1
//out[globalWriteIndex + 1] = tmp[writeIndex].vertex2
//out[globalWriteIndex + 2] = tmp[writeIndex].vertex3
Is it possible ? out array should hold triangles in correct form (vertices in CW / CCW). I can not use globalWriteIndex calculated from thread and block IDx, because that gives me empty spaces between triangles if trinangle is not created.
