Finding Delcarations and Definitions of Cuda types
Hi there,
after installing the SDK on Visual Studio 9, and working through a couple of listings from “Cuda by Example”, I noticed that the types used by Cuda
(e.g. cudaError_t) cannot be accessed through VS’s “Go to Declaration” or “Go to Definition”. I presume that the nvcc compiler adds a lot of header files that contain these, and that they are hidden from Visual Studio before that.
Am I correct in this assumption, and is there any tooling to turn source-code-navigation on for these types?
Thanks,
Sebastian.
Another issue: Code folding and brace matching are broken. I managed to get syntax highlighting to work, but that seems to be all of the luxury. Even the conventional code can no longer be navigated with F12, as I noticed. This is like the eighties!
Yeah the installation on my PC has this problem too, I suspect it’s some sort of path problem.
I just tried to figure it out in an ms-dos prompt the following happened:
Without quotes:
C:\Users\Skybuck>%CUDA_PATH%
‘C:\Tools\CUDA\Toolkit’ is not recognized as an internal or external command,
operable program or batch file.
With quotes:
C:\Users\Skybuck>“%CUDA_PATH%”
‘"C:\Tools\CUDA\Toolkit 4.0\v4.0"’ is not recognized as an internal or external
command,
Notice how the first one seems to be incomplete, it’s because there is a space in the folder.
Perhaps this is causing Visual Studio to not find these include files ?!?
For example:
CUDA_INC_PATH is declared as:
%CUDA_PATH%\include
Perhaps adding quotes around it might solve it…
I’ll give it a try and see if it helps External Image
Hmmm, strangely enough at the moment it is working… don’t know if it was something I did… might be because my virtual drive had “lucky” drive letter assignments…
