I’m trying to find out if an int is even or odd, I’ve read that modulus is slow in CUDA and I can’t seem to get it to work, is there anyway of doing this without modulus?
I was thinking of finding out what the last digit of the int and then checking to see what it is but I can’t seem to find a way to do this either…
any help would be great
this could work:
if (int & 0x1)
// odd
if (! (int & 0x1))
// even
Simple as:
if (i & 1) {
// odd
} else {
// even
I think the compiler is able to make this optimization when you use modulus with a constant. Please, share if you discover something.
in case you don’t know of it already: http://en.wikipedia.org/wiki/Two%27s_complement
(it’s more complicated than if (x & 1) if you need to support negative numbers, but it’s certainly not impossible)
I use this for CPU code, although I never tried it on the GPU.
typedef struct
union
unsigned int n;
struct
unsigned lsb :1; // The least-significant bit; will give the parity
unsigned oBits :30; // Other useless bits
unsigned msb :1; // The most significant bit; won't be needed here
} intSplitter;// Not a very inspired name
intSplitter x = whatever;
if(x.lsb)
// Odd
if(!x.lsb)
// Even
There might be some obscure problems with this code that I haven’t found yet.
i think this also applies for negative numbers.
Yeah, the table at Wikipedia supports that assumption … I’m not sure anymore though :)
Yeah, I am super-obviously wrong (and now I feel very dumb to boot). Ignore me when I answer technical questions in the middle of the night.
