Hi all,
recently I noticed a performance issues related to the resources utilisation and I decided to fine tune the OS/linux rather than only the vLLM and RAY layer. If you have done anything similar please share.
Summary of Final State
- Latency: 0.09s (TTFT)
- Throughput: 52.59 tokens/s
- Context: 262,144 tokens (Stable)
- Concurrency & capacity: Supports up to 54 simultaneous users at the full 262,144 token context window with 115.5 tokens/s
Summary before tuning.
- Latency: 0.10s (TTFT)
- Throughput: 46.66 tokens/s
- Concurrency & capacity: Supports up to 54 simultaneous users at the full 262,144 token context window with 46.66 tokens/s
How I did it,
Linux Kernel & OS Optimisations
These changes were applied to the underlying DGX OS (Ubuntu 24.04 ARM64 6.17.0-1021-nvidia) to remove system jitter and maximise the performance of the unified memory bus.
CPU Fencing (Hardware Isolation)
Applied via /etc/default/grub to isolate the ARM64 Cortex-X925 Performance Cores.
- isolcpus=10-19: Removes the 10 performance cores from the general Linux scheduler.
- nohz_full=10-19: Enables “Tickless Mode,” stopping the kernel timer interrupt on those cores to eliminate context-switching overhead.
- rcu_nocbs=10-19: Offloads Read-Copy-Update (RCU) locking callbacks to the efficiency cores.
- processor.max_cstate=1: Disables deep-sleep energy saving to ensure zero wake-up latency.
Virtual Memory (VM) Subsystem
Applied via sysctl to prevent memory-to-NVMe bus contention.
- vm.swappiness=0: strictly prohibits the kernel from moving model weights to disk.
- vm.max_map_count=2097152: Increased to handle the massive memory mapping requirements of the 262k context window.
- vm.dirty_ratio=5 / vm.dirty_background_ratio=2: Forces frequent, small disk writes to prevent large I/O bursts from saturating the LPDDR5X bus.
- Huge Pages: Set to madvise to allow vLLM to manage 2MB/1GB pages without the overhead of automatic background compaction.
Networking (ConnectX-7 200G Fabric)
Applied to the InfiniBand/RoCEv2 bond0 interface.
- net.ipv4.tcp_congestion_control=bbr: Used Google’s BBR to maximize throughput and minimize latency on the point-to-point link.
- net.core.rmem_max=134217728 (128MB): Expanded socket buffers to handle high-bandwidth tensor transfers.
- RoCE QoS: Configured Priority Flow Control (PFC) on priority lane 3 to ensure lossless communication during All-Reduce operations.
vLLM Engine & Model Optimisations
These settings were configured for vLLM v0.22.1rc1 to leverage the Blackwell (sm_100) hardware primitives.
Computational Backends
- flashinfer: Enabled the Blackwell-optimized attention backend, which provides superior performance for MoE (Mixture of Experts) architectures.
- instanttensor Loader: Utilized the unified memory architecture to map Safetensors directly from NVMe to VRAM, resulting in an 18-second cold boot for the 35B model.
- FP8 KV-Cache: Enabled 8-bit quantization for the attention cache, doubling the available concurrency to 54x for the 262k context window.
Model-Specific Fixes (Qwen 3.6 35B)
- Processor Realignment: Manually patched preprocessor_config.json to replace the deprecated Qwen2VLImageProcessorFast with Qwen2VLImageProcessor, resolving internal vision-init hangs.
Distributed Coordination (Ray)
- TP=2 (Tensor Parallelism): Layers were split across both GPUs over the bond0 200G link.
- VLLM_RPC_TIMEOUT=600000: Increased the internal timeout to 10 minutes to accommodate the heavy torch.compile graph-capturing phase required for Blackwell optimisations.
- Dedicated Worker Locks: Enabled shared memory locking between Ray actors to stabilise distributed memory access.
I create a script finetune.sh to apply and revert the settings above.
Sharing this script only for reference needs
Adjustments and tests needed before use.
#!/usr/bin/env bash
# setup_production_fabric.sh - Production-grade tuning for NVIDIA DGX Spark (Blackwell)
set -euo pipefail
# --- Configuration ---
MODEL_DIR="/home/geo/.cache/huggingface/hub/models--Qwen--Qwen3.6-35B-A3B-FP8"
PERF_CORES="10-19"
EFF_CORES="0-9"
BOND_IFACE="bond0"
log() { echo -e "\033[1;32m[$(date +%H:%M:%S)] $*\033[0m"; }
warn() { echo -e "\033[1;33m[WARN] $*\033[0m"; }
if [[ $EUID -ne 0 ]]; then
echo "This script must be run as root (sudo)."
exit 1
fi
apply_optimizations() {
log ">>> Starting Full Production Alignment..."
# 1. Hardware Fencing (CPU Isolation)
log "[1/6] Configuring CPU Isolation (GRUB)..."
if ! grep -q "isolcpus" /etc/default/grub; then
sed -i 's/GRUB_CMDLINE_LINUX_DEFAULT="\(.*\)"/GRUB_CMDLINE_LINUX_DEFAULT="\1 isolcpus='"$PERF_CORES"' nohz_full='"$PERF_CORES"' rcu_nocbs='"$PERF_CORES"' processor.max_cstate=1 arm_pmu.max_features=0"/' /etc/default/grub
update-grub || grub-mkconfig -o /boot/grub/grub.cfg
warn "CPU Isolation configured. A REBOOT is required to activate this fencing."
else
log "CPU Isolation already configured in GRUB."
fi
# 2. Virtual Memory & Bus Tuning (Persistent)
log "[2/6] Applying Persistent Sysctl (Memory/Network)..."
cat > /etc/sysctl.d/99-blackwell-perf.conf <<EOF
# Prevent bus contention
vm.swappiness = 0
vm.max_map_count = 2097152
vm.overcommit_memory = 1
vm.dirty_background_ratio = 2
vm.dirty_ratio = 5
vm.zone_reclaim_mode = 0
vm.panic_on_oom = 1
# 200G Fabric Tuning
net.core.netdev_max_backlog = 500000
net.core.rmem_max = 134217728
net.core.wmem_max = 134217728
net.core.somaxconn = 65535
net.ipv4.tcp_rmem = 4096 87380 134217728
net.ipv4.tcp_wmem = 4096 65536 134217728
net.ipv4.tcp_congestion_control = bbr
net.core.default_qdisc = fq
EOF
sysctl --system
# 3. Transparent Huge Pages
log "[3/6] Setting THP to madvise..."
echo madvise > /sys/kernel/mm/transparent_hugepage/enabled
echo madvise > /sys/kernel/mm/transparent_hugepage/defrag
# 4. Storage & Interrupts
log "[4/6] Optimizing NVMe and IRQ Affinity..."
if [ -d "/sys/block/nvme0n1/queue" ]; then
echo none > /sys/block/nvme0n1/queue/scheduler
echo 1024 > /sys/block/nvme0n1/queue/max_sectors_kb
echo 4096 > /sys/block/nvme0n1/queue/read_ahead_kb
fi
systemctl stop irqbalance && systemctl disable irqbalance
# Move interrupts to efficiency cores (mask 0x3ff)
for irq in /proc/irq/*; do
if [ -d "$irq" ]; then echo "3ff" > "$irq/smp_affinity" 2>/dev/null; fi
done
# 5. Model-Specific Fixes (Qwen 3.6)
log "[5/6] Patching Qwen 3.6 Model Configs..."
if [ -d "$MODEL_DIR" ]; then
find "$MODEL_DIR" -name "preprocessor_config.json" -exec sed -i 's/Qwen2VLImageProcessorFast/Qwen2VLImageProcessor/g' {} +
else
warn "Model directory not found, skipping patch."
fi
# 6. Limits (Persistent)
log "[6/6] Increasing System Limits..."
cat > /etc/security/limits.d/blackwell.conf <<EOF
* soft memlock unlimited
* hard memlock unlimited
* soft nofile 1048576
* hard nofile 1048576
EOF
log ">>> Production Alignment Complete."
log ">>> PLEASE REBOOT to finalize the CPU Hardware Fence."
revert_optimizations() {
log ">>> Reverting Changes..."
rm -f /etc/sysctl.d/99-blackwell-perf.conf
rm -f /etc/security/limits.d/blackwell.conf
sed -i 's/ isolcpus=.*arm_pmu.max_features=0//' /etc/default/grub
systemctl enable irqbalance && systemctl start irqbalance
log ">>> Reverted. Please reboot."
case "${1:-}" in
--apply) apply_optimizations ;;
--revert) revert_optimizations ;;
*) echo "Usage: sudo $0 {--apply|--revert}"; exit 1 ;;
esac
How to use it:
To apply all the production-grade kernel and model optimizations:
sudo ./setup_production_fabric.sh --apply
To revert all changes to the system default:
sudo ./setup_production_fabric.sh --revert
What this script applies
- CPU Hardware Fence: Strictly reserves Cores 10-19 for vLLM, moving everything else to Cores 0-9.
- Tickless Performance: Disables kernel timer interrupts on the Performance Cores.
- Unified Memory Safety: Disables swap and sets low dirty-page flush ratios to protect the LPDDR5X bus from NVMe interference.
- 200G Fabric Optimisation: Enables BBR and expands TCP buffers to 128MB for the InfiniBand link.
- Model Patching: Automatically fixes the Qwen2VLImageProcessorFast deprecation bug in your model files.
- Storage Throughput: Bypasses kernel I/O scheduling for the local NVMe drive.
How I started the model.
docker exec -d spark-ray bash -c "
HF_HUB_OFFLINE=1 \
RAY_ADDRESS=10.10.10.1:6379 \
VLLM_RPC_TIMEOUT=600000 \
vllm serve Qwen/Qwen3.6-35B-A3B-FP8 \
--tensor-parallel-size 2 \
--max-model-len 262144 \
--gpu-memory-utilization 0.8 \
--kv-cache-dtype fp8 \
--attention-backend flashinfer \
--load-format instanttensor \
--enable-prefix-caching \
--enable-chunked-prefill \
--distributed-executor-backend ray"
m
