To run inference with deepstream, please use below steps.
$ xhost +
$ export DISPLAY=:0
$ docker run --runtime=nvidia -it --rm --net=host --gpus all --name ds6.3 -d -v /localhome/local-morganh:/localhome/local-morganh -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY nvcr.io/nvidia/deepstream:6.3-samples
$ docker exec -it ds6.3 /bin/bash
$ cd /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app
$ vim ds_classification_as_primary_gie.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
#width=1280
#height=720
width=640
height=360
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
#uri=file:///localhome/local-morganh/TAO_ClassificationTF2_resources/sample_images/staff/out.mp4
uri=file:///localhome/local-morganh/TAO_ClassificationTF2_resources/sample_images/non-staff/out_nonstaff.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
#type=2
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
#bitrate=200
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/model.onnx_b1_gpu0_fp32.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_as_primary_gie.txt
[tests]
file-loop=1
$ vim config_as_primary_gie.txt
[property]
gpu-id=0
net-scale-factor=0.0175070028011204
offsets=123.675;116.28;103.53
batch-size= 1
model-color-format=0
# model config
onnx-file=model.onnx
#tlt-model-key=yourkey
#tlt-encoded-model=your_unpruned_or_pruned_model.etlt
labelfile-path=labels.txt
#int8-calib-file=cal.bin
#model-engine-file=your_classification.engine
#input-dims=3;128;128;0
infer-dims=3;128;128
uff-input-blob-name=Input_1
output-blob-names=Identity:0
# process-mode: 2 - inferences on crops from primary detector, 1 - inferences on whole frame
process-mode=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
network-type=1 # defines that the model is a classifier.
num-detected-classes=2
interval=0
gie-unique-id=1
#threshold=0.05
classifier-async-mode=1
classifier-threshold=0.00002
operate-on-gie-id=1
#operate-on-class-ids=-1
scaling-filter=1
scaling-compute-hw=1
maintain-aspect-ratio=1
$ deepstream-app -c ds_classification_as_primary_gie.txt
** WARN: <parse_tracker:1604>: Unknown key 'enable-batch-process' for group [tracker]
libEGL warning: DRI3: Screen seems not DRI3 capable
libEGL warning: DRI2: failed to authenticate
0:00:02.940466597 6060 0x5593757ac830 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/model.onnx_b1_gpu0_fp32.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x128x128
1 OUTPUT kFLOAT Identity:0 2
0:00:03.038633010 6060 0x5593757ac830 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/model.onnx_b1_gpu0_fp32.engine
0:00:03.041324084 6060 0x5593757ac830 WARN nvinfer gstnvinfer.cpp:1047:gst_nvinfer_start:<primary_gie> warning: NvInfer asynchronous mode is applicable for secondaryclassifiers only. Turning off asynchronous mode
0:00:03.041538580 6060 0x5593757ac830 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_as_primary_gie.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:239>: Pipeline ready
WARNING from primary_gie: NvInfer asynchronous mode is applicable for secondaryclassifiers only. Turning off asynchronous mode
Debug info: gstnvinfer.cpp(1047): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
** INFO: <bus_callback:225>: Pipeline running
**PERF: FPS 0 (Avg)
**PERF: 305.10 (304.07)
**PERF: 297.63 (298.81)
**PERF: 299.63 (299.16)
**PERF: 300.00 (299.41)
**PERF: 295.01 (298.36)
**PERF: 298.34 (298.36)
**PERF: 300.27 (298.69)
**PERF: 298.44 (298.64)
**PERF: 297.81 (298.54)
Note: Correct previous setting to
Because in deepstream, y = scale_factor * (x- mean) .
In tao-tf2 torch mode, y = (x/255 - torch_mean)/std = (x - 255 * torch_mean) * (1/255/std) .
So, scale_factor = 1/255/std.
The mean = 255 * torch_mean
More, to generate mp4 file, please use below.
$ apt-get install ffmpeg
$ ffmpeg -framerate 2 -pattern_type glob -i ‘*.jpg’ -c:v libx264 -pix_fmt yuv420p -vf “crop=trunc(iw/2)*2:trunc(ih/2)*2” out.mp4
