Finetuning fastervit classification model
• Hardware (T4/V100/Xavier/Nano/etc) - A10G
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) - fastervit
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
nvidia/tao/pretrained_fastervit_classification_imagenet:fastervit_0_224_1k
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Is there a reference train spec file that is known to work? I am getting the following error if I use the spec file sample in Image Classification PyT - NVIDIA Docs
RuntimeError: Expected to have finished reduction in the prior iteration before starting a new one. This error indicates that your module has parameters that were not used in producing loss. You can enable unused parameter detection by passing the keyword argument find_unused_parameters=True to torch.nn.parallel.DistributedDataParallel, and by
making sure all forward function outputs participate in calculating loss.
If you already have done the above, then the distributed data parallel module wasn’t able to locate the output tensors in the return value of your module’s forward function. Please include the loss function and the structure of the return value of forward of your module when reporting this issue (e.g. list, dict, iterable).
Parameter indices which did not receive grad for rank 0: 365 366
In addition, you can set the environment variable TORCH_DISTRIBUTED_DEBUG to either INFO or DETAIL to print out information about which particular parameters did not receive gradient on this rank as part of this error
Could you please share the full command and full log? Thanks.
You can upload via the button
image.
Yes, you can refer to notebook tao_tutorials/notebooks/tao_launcher_starter_kit/classification_pyt at main · NVIDIA/tao_tutorials · GitHub
Code: tao_pytorch_backend/nvidia_tao_pytorch/cv/classification at dc07b02eb78c2eb868315107892b466496e55a0f · NVIDIA/tao_pytorch_backend · GitHub
