How do you change the position of a Fire created with Flow in Create or Machinima ?
I don’t see a locator anymore and I can’t select the fire effect in the viewport to change placement.
xyz position are working but without a proper locator it’s difficult to manage.
https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_fluid-dynamics.html
See the Transforms section in the online docs. The Flow emitter is typically made the child of an xform to enable placement.
Yes, working fine. Thank you.
