Stephen Yannalfo wrote:
Could you get the board_id with “ibv_devinfo”
Sure; took a little time as I had to get a system running to put the HCA in ;-)
When I put some IB between systems at home years ago, the PCIe
would limit me to about DDR anyway (one 8x 1.0, and 4x 2.0 …), so
i used DDR boards with available firmware. I have since upgraded
some bits of hardware, and wondering if I couldn’t get QDR on 8x 2.0.
But it seems QDR was mostly deployed with QSFP connector, not
CX4, so the MHJH29 seems a bit of a black sheep from that era…
Thanks for your help !
Host is a Supermicro X9SRi, primary PCIe slot (16x 2.0). Running
CentOS 7.3
[root@localhost ~]# ibv_devinfo
hca_id: mlx4_0
transport: InfiniBand (0)
fw_ver: 2.6.900
node_guid: 0002:c903:0002:173a
sys_image_guid: 0002:c903:0002:173d
vendor_id: 0x02c9
vendor_part_id: 26428
hw_ver: 0xA0
board_id: MT_04E0120005
phys_port_cnt: 2
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: InfiniBand
(second port same as first, nothing is plugged in).
2.6.9 feels old, the latest seems to be 2.9.1[000]
And the part number with:
lspci | grep Mell NOTE: the bus:dev.func of the device
lspci -s bus:dev.func -xxxvvv
That’s one verbose lspci :-)
02:00.0 InfiniBand: Mellanox Technologies MT26428 [ConnectX VPI PCIe 2.0 5GT/s - IB QDR / 10GigE] (rev a0)
Subsystem: Mellanox Technologies Device 0005
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 61
NUMA node: 0
Region 0: Memory at fba00000 (64-bit, non-prefetchable) [size=1M]
Region 2: Memory at 38ffff000000 (64-bit, prefetchable) [size=8M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] Vital Product Data
Product Name: Eagle QDR
Read-only fields:
[PN] Part number: MHJH29-XTC
[EC] Engineering changes: X5
[SN] Serial number: MT0821X00122
[V0] Vendor specific: PCIe Gen2 x8
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[V1] Vendor specific: N/A
[YA] Asset tag: N/A
[RW] Read-write area: 111 byte(s) free
End
Capabilities: [9c] MSI-X: Enable+ Count=256 Masked-
Vector table: BAR=0 offset=0007c000
PBA: BAR=0 offset=0007d000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #8, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Kernel driver in use: mlx4_core
Kernel modules: mlx4_core
00: b3 15 3c 67 06 04 10 00 a0 00 06 0c 10 00 00 00
10: 04 00 a0 fb 00 00 00 00 0c 00 00 ff ff 38 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 b3 15 05 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 0b 01 00 00
40: 01 48 03 00 00 00 00 00 03 9c ff 7f 00 00 00 78
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 10 00 02 00 01 8e 2c 01 20 20 00 00 82 f4 03 08
70: 00 00 82 00 00 00 00 00 00 00 00 00 00 00 00 00
80: 00 00 00 00 1f 00 00 00 00 00 00 00 00 00 00 00
90: 02 00 00 00 00 00 00 00 00 00 00 00 11 60 ff 80
a0: 00 c0 07 00 00 d0 07 00 05 00 8a 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
