First boot failed with SD card
I have downloaded jp60-orin-nano -sd-card-image from jetpack
and flashed it into a 64 GB SD card using Balena Etcher following the instructions in Jetson Orin Nano Developer Kit Getting Started | NVIDIA Developer.
Then I connected monitor, Keyboard, mouse, and SD card to the Orin nano developer kit and powered the board. However, after showing the NVIDIA sign for several seconds, the screen is blank saying no signal, but the light of board is still on and the fan is still running. Could you please help me with it? Thank you so much!
Hello @sunyusimon0532,
Have you tried flashing with SDK Manager?
regards,
Andrew
Dear Andrew,
Thank you for your reply. I haven’t tried SDK manager. I saw some topics mentioned that, but I am wondering whether I can solve it without using it. It seems that I need to short some pins which is a bit difficult for me now. But if I have to use SDK manager, I will try it later. Thank you!
I am having the same issue. I have not tried SDK Manager, I wonder however if there is any solution by flashing the jp60-orin-nano-sd-card-image into the SD card?
Regards,
Reza
Hello @sunyusimon0532 and @sr.firouzi,
When having issues during flashing, the best you can do is to use SDK Manager given that you would remove the possibilities of making a mistake that could cause an issue.
If the problem is shorting the pins in order to get the board in recovery mode, you can try rebooting into it if you have access through UART or ssh:
sudo reboot --force forced-recovery
If you want another option of getting and flashing Jetpack without SDK manager, here is this tutorial we have, it might be helpful for you:
regards,
Andrew
