Hi
I am able to record from the mic however I noticed that first time running arecord it given me device or resource busy. second time run most of the time it works. any suggestions ??
amixer -c tegrasndt210ref cset name=‘ADMAIF1 Mux’ I2S4
arecord -D hw:tegrasndt210ref,0 -r 48000 -f S32_LE -c 2 -d 10 test.wav
Hello!
It is most likely that pulseaudio is using the device. To see if it is pulseaudio you can try temporarily disabling it by …
$ echo "autospawn = no" > ${HOME}/.config/pulse/client.conf
$ pulseaudio --kill
To re-enable pulseaudio simply …
$ rm ${HOME}/.config/pulse/client.conf
$ pulseaudio --start
If it is pulseaudio and you do not need it then you can always uninstall it.
Regards,
Jon
hI Job,
seems not
vaitl@11223301010003f9:~$ pulseaudio --kill
E: [pulseaudio] main.c: Failed to kill daemon: No such process
vaitl@11223301010003f9:~$ sudo pulseaudio --kill
[sudo] password for vaitl:
E: [pulseaudio] core-util.c: Home directory not accessible: Permission denied
E: [pulseaudio] main.c: Failed to kill daemon: No such file or directory
Hello!
Please note that you only need to kill the daemon if it is running. In other words, once you have created the ‘.config/pulse/client.conf’ file on the next reboot pulseaudio should no longer be running. So do you see any pulseaudio processes runing at all?
$ ps aux | grep pulseaudio
Looks like I still see an instance running for gdm. If you don’t need pulseaudio at all you could try uninstalling …
$ sudo apt remove pulseaudio
Alternatively, if you need pulseaudio, you can always use pacmd to play the file …
$ pacmd list-sinks | grep name:
$ pacmd play-file <wav-file> alsa_output.platform-sound.analog-stereo
Regards,
Jon
