My GUI is crashing after I type in the password. I have checked and my liblx.so file is “OK”. I’ve decided to reflash the Jetson with JetPack. I’m not sure what to put under the proxy server menu, or if I need to put fill it out. I’ve also noticed the flashing portion take no time and it immediately jumps to the input device information tab. Any advice?
FYI, I just added this thread for web links related to flashing. I did test the download from there using firefox which worked a few minutes ago.
https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/
Hi, GrumpyGator,
Could you please clarify the following questions?
- Do you use http proxy to download external files on your computer? JetPack can be configured to use http proxy to download OS and other files.
- Did you put the device to recovery mode before flashing? To check if device is in recovery mode, please enter “lsusb” command in host terminal, and check if there is a line with “NVidia Corp.” in the output.
If you still couldn’t flash your device, could you please send /_installer/logs/flashos.log and /JetPackTK1-installLog.log to TegraDeveloperPack-Users@nvidia.com ?
- I don’t believe I do. So I left that section blank when when running Jetpack.
- Nvidia Corp showed up when I ran lsusb.
Hi, GrumpyGator,
For further diagnose, could you please send /_installer/logs/flashos.log and /JetPackTK1-installLog.log to TegraDeveloperPack-Users@nvidia.com ?
