This changes two things. One is that the rt-patch.sh script itself was not modifying tegra_defconfig. Another was the script needed to also disabled the CPU idle on T19X platform, not just T18X. Lastly, the defconfig will have cpufreq compiled in and so cpufreq_times.c was missing conversions to raw spinlocks on the regular spinlocks in use. Without these changes, my experience was a board flashed with 32.1 and rt-patch.sh apply-patches in use would get stuck on boot in various kernel BUG calls.
diff --git a/kernel/kernel-4.9/drivers/cpufreq/cpufreq_times.c b/kernel/kernel-4.9/drivers/cpufreq/cpufreq_times.c
index 0e8754b6..d4f6504a 100644
--- a/kernel/kernel-4.9/drivers/cpufreq/cpufreq_times.c
+++ b/kernel/kernel-4.9/drivers/cpufreq/cpufreq_times.c
@@ -29,8 +29,8 @@
static DECLARE_HASHTABLE(uid_hash_table, UID_HASH_BITS);
-static DEFINE_SPINLOCK(task_time_in_state_lock); /* task->time_in_state */
-static DEFINE_SPINLOCK(uid_lock); /* uid_hash_table */
+static DEFINE_RAW_SPINLOCK(task_time_in_state_lock); /* task->time_in_state */
+static DEFINE_RAW_SPINLOCK(uid_lock); /* uid_hash_table */
struct uid_entry {
uid_t uid;
@@ -236,9 +236,9 @@ void cpufreq_task_times_init(struct task_struct *p)
unsigned long flags;
- spin_lock_irqsave(&task_time_in_state_lock, flags);
+ raw_spin_lock_irqsave(&task_time_in_state_lock, flags);
p->time_in_state = NULL;
- spin_unlock_irqrestore(&task_time_in_state_lock, flags);
+ raw_spin_unlock_irqrestore(&task_time_in_state_lock, flags);
p->max_state = 0;
@@ -253,9 +253,9 @@ void cpufreq_task_times_alloc(struct task_struct *p)
if (!temp)
return;
p->time_in_state = temp;
p->max_state = max_state;
@@ -283,10 +283,10 @@ void cpufreq_task_times_exit(struct task_struct *p)
if (!p->time_in_state)
return;
temp = p->time_in_state;
kfree(temp);
@@ -299,7 +299,7 @@ int proc_time_in_state_show(struct seq_file *m, struct pid_namespace *ns,
struct cpu_freqs *freqs;
struct cpu_freqs *last_freqs = NULL;
for_each_possible_cpu(cpu) {
freqs = all_freqs[cpu];
if (!freqs || freqs == last_freqs)
@@ -318,7 +318,7 @@ int proc_time_in_state_show(struct seq_file *m, struct pid_namespace *ns,
(unsigned long)cputime_to_clock_t(cputime));
return 0;
@@ -335,17 +335,17 @@ void cpufreq_acct_update_power(struct task_struct *p, cputime_t cputime)
state = freqs->offset + READ_ONCE(freqs->last_index);
if ((state < p->max_state || !cpufreq_task_times_realloc_locked(p)) &&
p->time_in_state)
p->time_in_state[state] += cputime;
- spin_lock_irqsave(&uid_lock, flags);
+ raw_spin_lock_irqsave(&uid_lock, flags);
uid_entry = find_or_register_uid_locked(uid);
if (uid_entry && state < uid_entry->max_state)
uid_entry->time_in_state[state] += cputime;
- spin_unlock_irqrestore(&uid_lock, flags);
+ raw_spin_unlock_irqrestore(&uid_lock, flags);
void cpufreq_times_create_policy(struct cpufreq_policy *policy)
@@ -393,7 +393,7 @@ void cpufreq_task_times_remove_uids(uid_t uid_start, uid_t uid_end)
struct hlist_node *tmp;
for (; uid_start <= uid_end; uid_start++) {
hash_for_each_possible_safe(uid_hash_table, uid_entry, tmp,
@@ -405,7 +405,7 @@ void cpufreq_task_times_remove_uids(uid_t uid_start, uid_t uid_end)
void cpufreq_times_record_transition(struct cpufreq_freqs *freq)
diff --git a/kernel/kernel-4.9/scripts/rt-patch.sh b/kernel/kernel-4.9/scripts/rt-patch.sh
index 6176eee2..daefe1c8 100755
--- a/kernel/kernel-4.9/scripts/rt-patch.sh
+++ b/kernel/kernel-4.9/scripts/rt-patch.sh
@@ -11,7 +11,7 @@
any_failure=0
apply_rt_patches()
- if [ -f ../arch/arm64/configs/.tmp.tegra_gnu_linux_defconfig ]; then
+ if [ -f ../arch/arm64/configs/.tmp.tegra_defconfig ]; then
echo "The PREEMPT RT patches are already applied to the kernel!"
else
file_list=`find ../rt-patches -name \*.patch -type f | sort`
@@ -20,27 +20,28 @@ apply_rt_patches()
patch -s -d .. -p1 < $p || any_failure=1
done
#make temporary copy of the defconfig file
- cp ../arch/arm64/configs/tegra_gnu_linux_defconfig\
- ../arch/arm64/configs/.tmp.tegra_gnu_linux_defconfig
- ./config --file ../arch/arm64/configs/tegra_gnu_linux_defconfig\
+ cp ../arch/arm64/configs/tegra_defconfig\
+ ../arch/arm64/configs/.tmp.tegra_defconfig
+ ./config --file ../arch/arm64/configs/tegra_defconfig\
--enable PREEMPT_RT_FULL --disable CPU_IDLE_TEGRA18X\
- --disable CPU_FREQ_GOV_INTERACTIVE || any_failure=1
+ --disable CPU_IDLE_TEGRA19X\
+ --disable CPU_FREQ_GOV_INTERACTIVE || any_failure=1
echo "The PREEMPT RT patches have been successfully applied!"
fi
revert_rt_patches()
file_list=`find ../rt-patches -name \*.patch -type f | sort -r`
for p in $file_list; do
# set flag in case of failure and continue
patch -s -R -d .. -p1 < $p || any_failure=1
done
# CPU_FREQ_GOV_INTERACTIVE need to keep disable for Automotive
- cp ../arch/arm64/configs/.tmp.tegra_gnu_linux_defconfig\
- ../arch/arm64/configs/tegra_gnu_linux_defconfig
- rm -rf ../arch/arm64/configs/.tmp.tegra_gnu_linux_defconfig
+ cp ../arch/arm64/configs/.tmp.tegra_defconfig\
+ ../arch/arm64/configs/tegra_defconfig
+ rm -rf ../arch/arm64/configs/.tmp.tegra_defconfig
echo "The PREEMPT RT patches have been successfully reverted!"
else
echo "The PREEMPT RT patches are not applied to the kernel!"
