Fix jetpack
Hi, I accidentally removed the cudnn file under jetpack, how can I reinstall the cudnn without flashing the board. And the jetpack for this board is installed by flashing the SD card, can I use SDK manager in this case? Thanks a lot.
You can select not to reflash the board when you run sdkmanager.
