I have question concerning passing arguments to cuda kernels.
Suppose I have
a → points to cuda allocated memory
b → points to cuda allocated memory
then start a kernel
foo<<<…>>>(a, b); // with device foo(float *a, float *b);
Why can’t cuda do the following
*c[2];
c[0]–> points to cuda allocated memory
c[1]–> points to cuda allocated memory
then
foo2<<<…>>>(c);
where the signature for foo2 is
device foo2(float *c[2]);
In other words it is known at compile time that c[0] and c[1] are returning addresses in cuda memory.
I understand the compiler to be unable to handle foo3(float **a); But foo2 above is very similar to the original foo… I mean this should just tell the compiler to pick the two cuda addresses c[0] and c[1] at kernel launch …
