Hi there Nvidia Admin!
Having an issue with my bootloader on my Jetson Orin and am trying to fix it. Currently getting an error message that reads:
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
Im aware from reading through your forums you are supposed to change the eeprom read in the file “tegra234-mb2-bct-common.dtsi” to:
eeprom {
cvm_eeprom_read_size = <0x0>
When saving the file and running sdk manager to deploy it did not seem to take the changes…
Does sdkmanager compile the dtsi files for deployment?
Is there a better method or something I’m missing?
Thanks,
A.
