The log from the issue ::
Step 3: Start the flashing process
Waiting for target to boot-up…
Waiting for device to expose ssh …Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH ready
mount.nfs: mounting [fc00:1:1:0::1]:/home/…/nvidia-jetson-orin/Linux_for_Tegra/rootfs failed, reason given by server: No such file or directory
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,…) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.sou25WqtBs. You can access the target’s terminal through “sshpass -p root ssh root@fc00:1:1:0::2”
Cleaning up…
////////////////////////////////////// Down the problem solving ////////////////////////////////////////////////////////////
NFS‑over‑IPv6 Export “No such file or directory”
Issue:
When exporting NFS shares to an IPv6 client, un‑bracketed IPv6 prefixes in /etc/exports
(e.g. fc00:1:1::/48
) are mis‑parsed as hostnames, so the server never really exports to that network. Clients then see:
mount.nfs: mounting [fc00:1:1:0::1]:/path/to/share failed, reason given by server: No such file or directory
Problem Statement
In
/etc/exports
you have lines like:/home/…/rootfs fc00:1:1::/48(rw,async) /home/…/images fc00:1:1::/48(ro,async)
showmount -e
does not list these under[fc00:1:1::]/48
Jetson (or any IPv6 client) cannot mount—they get “No such file or directory.”
Why It Happens
NFS’s export parser treats the slash in an un‑bracketed IPv6 address as part of its own syntax, not as a CIDR mask.
To export to an IPv6 network, you must wrap the address (and mask) in brackets:
[2001:db8:1::]/64
Public‑Friendly Fix
Edit
/etc/exports
Change any line exporting to IPv6 from this:- /path/to/share fc00:1:1::/48(rw,async,no_subtree_check) + /path/to/share [fc00:1:1::]/48(rw,async,no_subtree_check)
- Brackets disambiguate the colons from export syntax.
- The
/48
mask must follow the closing bracket.
Reload exports and restart NFS
sudo exportfs -ra sudo systemctl restart nfs-kernel-server
Adjust your firewall (UFW) for IPv6
If you use UFW, allow NFS (2049) and rpcbind (111) on your IPv6 subnet:sudo ufw allow from fc00:1:1::/48 to any port 2049 proto tcp sudo ufw allow from fc00:1:1::/48 to any port 2049 proto udp sudo ufw allow from fc00:1:1::/48 to any port 111 proto tcp sudo ufw allow from fc00:1:1::/48 to any port 111 proto udp sudo ufw reload
Result:
Your Jetson (or any IPv6 client) will now successfully mount the NFS share instead of failing with “No such file or directory.”
