Hi all,
I got Qwen 3.8 Flash Next running on Flare on a single Spark configured as a worker node in a homelab kubernetes cluster today, using the published gb10 package. For a research prototype it was surprisingly smooth to run.
I ran llama-benchy 0.4.0 with the same settings as cosinus above (pp 2048, tg 128, depth 0/4096/8192, 3 runs), so the numbers can be compared. Decode, tok/s:
| Depth |
cosinus, converted with the recipe (c1 / c2 / c4) |
Mine, prepared gb10 package (c1 / c2 / c4) |
| 0 |
43.6 / 61.5 / 68.0 |
35.7 / 55.4 / 84.1 |
| 4096 |
39.4 / 63.6 / 67.4 |
37.9 / 56.3 / 71.6 |
| 8192 |
39.0 / 59.9 / 66.9 |
30.5 / 54.4 / 81.1 |
So about 20% slower for a single request, and faster with 4 in parallel. cosinus converted the model himself with the recipe; I used the prepared package, so the difference may come from the package as much as from the setup. Prefill with 2 and 4 requests lands at 1,750–2,040 tok/s, close to cosinus. The single-request prefill numbers are useless here, because the prefix cache serves the repeated context.
Keep in mind this Spark isn’t a dedicated box: it’s a worker node in a small Kubernetes cluster, sharing the node with other services, and every request goes through a gateway, so there’s some overhead in these numbers. For that setup, I find these results amazing.
Tried the embedding table cache too (someone mentioned a magic param): 1 and 2 GiB are within run-to-run noise, and they eat KV cache. The 26.8 GiB RAM option doesn’t fit next to the model.
Defaults |
1 GiB cache |
2 GiB cache |
| Decode, one request, code prompt (tok/s) |
52.5 |
47.9 |
48.6 |
| KV cache (tokens) |
418k |
344k |
242k |
I’ve also been testing it for coding with Pi, from a chat panel I wrote for my IDE. In the screenshot it runs the failing tests of a small sample I prepared for this, finds the bug, fixes it and runs the tests again: 8 steps in 29 s.
The setup is Thinkube, an open-source AI platform on Kubernetes I’m building, which supports DGX Spark nodes in the cluster. Flare support went out as a fix for 0.1 today: https://thinkube.org
Has anyone run this model on vLLM or SGLang on a Spark? I’d like to compare on the same prompts.
