Hi,I changed FORCE_MAX_ZONEORDER default value to 12 and recombiled the kernel and then flashed agx, but the dp display not work, the jeson linux is the latest r35.2.1, and the same the r35.1.0,I tried to flash xavier nx,the display works. Could you help me? here is the log.
log.txt (114.8 KB)
Related topics
Topic | Replies | Views | Activity | |
Jetson AGX developer kit display doesnt work | 3 | 384 | July 26, 2023 | |
Orin AGX's display doesn't work after flashing with JetPack 5.1.2 | 5 | 510 | August 29, 2023 | |
Can't flash Jetson AGX Xavier Dev-Kit | 3 | 392 | November 8, 2021 | |
Flashing Xavier in drive AGX getting failed | 9 | 951 | August 17, 2023 | |
Flashing error | 3 | 391 | April 5, 2023 | |
AGX Ori flash error | 6 | 806 | November 2, 2022 | |
Display port not working " current input timing is not supported by the monitor display " | 5 | 93 | December 17, 2024 | |
My Drive AGX Xavier is not working at Flashing process in sdkmanager | 3 | 748 | May 11, 2023 | |
Jeston agx orin | 26 | 45 | December 13, 2024 | |
Flashing new kernel not updating defconfig | 5 | 447 | March 5, 2024 |
