I am trying to flash custom Linux system on my tx2 (buildroot).
I use the flash.sh script from L4T archive.
I managed to run my kernel by copying it to kernel and bootloader folder.
Buildroot generates both rootfs.ext4 and rootfs.tar file :
- I copied the rootfs.ext4 to bootloader/system.img and
./flash.sh -r jetson-tx2-devkit mmcblk0p1
but the kernel panics because the /sbin/init file does not exist. - I untar the rootfs.tar file to rootfs folder and
./flash.sh jetson-tx2-devkit mmcblk0p1
but the kernel doesn’t do anything after mounting the ext4-fs (no prompt)
Maybe I have an issue with the filesystem. Maybe mmcblk0p1 is not the right partition ?
Is there a solution to flash a tiny Linux system on TX2 ?
Thanks in advance,
