Flash different between ./flash.sh and ./nvmflash
hi ,
i work with 32.5.2 and with patched xnx-16gb-r32.x-overlay.tbz2 to supply 16G-nx-xarvier .
This confuses me.When i flash 16G-nx-xarvier core board,use
./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
the core board ,work well ,hdmi is good.
but when i use
sudo BOARDID=3668 BOARDSKU=0001 FAB=100 BOARDREV=H.0 FUSELEVEL=fuselevel_production ./nvmassflashgen.sh -x 0x19 jetson-xavier-nx-devkit-emmc mmcblk0p1
./nvmflash
the core board ,hdmi can not work.
attention :
i edit tegra194-a02-bpmp-p3668-a00.dtb
I replaced all the files(tegra194-a02-bpmp-p3668-a00.dtb) I could find.
Are you able to also test rel-32.7.2? Just want to know the status of latest release.
And unfortunately I don’t have this device at this moment.
sorry i can‘t,because i must use 32.5.2 ,Our factory is producing. I don’t have much time to do this experiment.
i use the command:
is to crate mfi_jetson-xavier-nx-devkit-emmc.tbz2 for factory,to flash many core boards one time.
i flash with rel-32.7.2,and ./nvmflash,and flashed is good .the hdmi and pcie is work well.
thanks.
For rel-32.5.2, could you remove "TRIM_BPMP_DTB=“true”; from your p3668.conf.common and try again?
Your answer has solved this problem, with rel-32.5.2, and remove "TRIM_BPMP_DTB=“true”,flashed core board is wrok well.
thanks.
