Flash Drive Software failed on Xavier E3550
Hi Sir,
If there any solutions for below error message on SDK Manager when installing Drive Software?
ERROR: Flash Xavier B failed to bind partitions
Dear melinda.hung,
Did you check flashing DRIVE™ Software 9.0 using latest SDK manager? If so, could you please attach the screenshot of SDKManager and logs to understand the issue.
Dear SivaRamaKrishna,
Thanks. The problem is solved. I found the error is caused by autorun scripts blocked when flashing the system. After the scripts run over, then I flash the dual system successfully.
Great
Could anyone tell me how to run over the autorun scripts? Thanks in advance!!!
