i use 32.7.1 package to flash a nx device,and i met this problem(app image is not found)
my flash commad is
“${curdir}”/“tools/kernel_flash/l4t_initrd_flash.sh” --external-device nvme0n1p1 -c “${NVME_XML}” --showlogs “${board_type}” internal
i check the log with ‘set -x’ and i found there is a file(
L4T/tools/kernel_flash//images/external/ flash.xml.tmp
) lost
then i check the 32.6.1 flash process, i found there is a line changed in
Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh:315
cp -avf “${FLASH_XML_FILE}” “${dest_dir}/flash.xml.tmp”
this line is removed in L4T32.7.1
and i tested if add this line back, it’s done
i want to figure out why do you remove this line, and should i do this kind of operation to solve this problem?
is there any solution you recommend?
