Tried everything you suggested, but it still failed.
mkdir ~/tmp
cd ~/tmp
wget https://developer.download.nvidia.com/embedded/L4T/r21_Release_v6.0/Tegra124_Linux_R21.6.0_armhf.tbz2?bnYKGaqd8_6Wxrtq8ZPtJVxCd3jgbmALh4qf95xDH-aYwSULGTO_PHAwo7FGma66UdbEmkpd2c09jutQybdfhZU6ZxZbWEzrGXCaz9iWWiXgV46NprkcVMY0_PhpP4IyBLbO9zfq-5MslW_kb8aUM2286UapAoif5qxEHT9X -o Tegra124_Linux_R21.6.0_armhf.tbz2
wget http://developer.download.nvidia.com/embedded/L4T/r21_Release_v6.0/Tegra_Linux_Sample-Root-Filesystem_R21.6.0_armhf.tbz2?ysXteiR0gjxmJRWdgthY_vNbvwv3LcOgEnEeB18KZK2_bmfEpIQub12m8UnBdXaY43Og6dB5YMRwGuZvTZnqh7foMwlSROCtdvE7x5XwdP3uwBYWBTOFZ5KjJy2wRycKST2w1Qx7aw7PjJ5Qded3PKl4J5QUcB_gSfFgXPo_tM7TkUdkbQR9ZyWYOVYf2uurlzQ -o Tegra_Linux_Sample-Root-Filesystem_R21.6.0_armhf.tbz2
tar xf Tegra124_Linux_R21.6.0_armhf.tbz2
cd Linux_for_Tegra/rootfs
sudo tar xf ../../Tegra_Linux_Sample-Root-Filesystem_R21.6.0_armhf.tbz2
cd ..
sudo ./flash.sh -S 14580MiB jetson-tk1 mmcblk0p1 2>&1 | tee log_flash.txt
also checked the file size for system.img.raw.
-rw-r–r-- 1 root root 15288238080 Apr 16 14:41 system.img.raw
The error log is as follows:
copying bctfile(/home/cfl604/tmp/Linux_for_Tegra/bootloader/ardbeg/BCT/PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg)… done.
copying bootloader(/home/cfl604/tmp/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)… done.
populating kernel to rootfs… done.
populating jetson-tk1_extlinux.conf.emmc to rootfs… done.
done.
Making system.img…
populating rootfs from /home/cfl604/tmp/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3776512( 922 blks) ==> 28:3776524
1: SKP: 28672( 7 blks) ==> 3776552:28684
2: RAW: 16384( 4 blks) ==> 3776564:16396
3: SKP: 49152( 12 blks) ==> 3792960:49164
4: RAW: 8052736( 1966 blks) ==> 3792972:8052748
5: SKP: 25501696( 6226 blks) ==> 11845720:25501708
6: RAW: 8511488( 2078 blks) ==> 11845732:8511500
7: SKP: 88281088( 21553 blks) ==> 20357232:88281100
8: RAW: 8192( 2 blks) ==> 20357244:8204
9: SKP: 3731456( 911 blks) ==> 20365448:3731468
10: RAW: 8146944( 1989 blks) ==> 20365460:8146956
11: SKP: 4096( 1 blks) ==> 28512416:4108
12: RAW: 11702272( 2857 blks) ==> 28512428:11702284
13: SKP: 4096( 1 blks) ==> 40214712:4108
14: RAW: 249856( 61 blks) ==> 40214724:249868
15: SKP: 4096( 1 blks) ==> 40464592:4108
16: RAW: 1458176( 356 blks) ==> 40464604:1458188
17: SKP: 8192( 2 blks) ==> 41922792:8204
18: RAW: 65536( 16 blks) ==> 41922804:65548
19: SKP: 1880064( 459 blks) ==> 41988352:1880076
20: RAW: 7196672( 1757 blks) ==> 41988364:7196684
21: SKP: 4096( 1 blks) ==> 49185048:4108
22: RAW: 32768( 8 blks) ==> 49185060:32780
23: SKP: 4096( 1 blks) ==> 49217840:4108
24: RAW: 241664( 59 blks) ==> 49217852:241676
25: SKP: 4096( 1 blks) ==> 49459528:4108
26: RAW: 32768( 8 blks) ==> 49459540:32780
27: SKP: 4096( 1 blks) ==> 49492320:4108
28: RAW: 114688( 28 blks) ==> 49492332:114700
29: SKP: 4096( 1 blks) ==> 49607032:4108
30: RAW: 57344( 14 blks) ==> 49607044:57356
31: SKP: 4096( 1 blks) ==> 49664400:4108
32: RAW: 32768( 8 blks) ==> 49664412:32780
33: SKP: 4096( 1 blks) ==> 49697192:4108
34: RAW: 94208( 23 blks) ==> 49697204:94220
35: SKP: 4096( 1 blks) ==> 49791424:4108
36: RAW: 32768( 8 blks) ==> 49791436:32780
37: SKP: 4096( 1 blks) ==> 49824216:4108
38: RAW: 32768( 8 blks) ==> 49824228:32780
39: SKP: 4096( 1 blks) ==> 49857008:4108
40: RAW: 32768( 8 blks) ==> 49857020:32780
41: SKP: 4096( 1 blks) ==> 49889800:4108
42: RAW: 32768( 8 blks) ==> 49889812:32780
43: SKP: 4096( 1 blks) ==> 49922592:4108
44: RAW: 32768( 8 blks) ==> 49922604:32780
45: SKP: 4096( 1 blks) ==> 49955384:4108
46: RAW: 32768( 8 blks) ==> 49955396:32780
47: SKP: 4096( 1 blks) ==> 49988176:4108
48: RAW: 32768( 8 blks) ==> 49988188:32780
49: SKP: 4096( 1 blks) ==> 50020968:4108
50: RAW: 114688( 28 blks) ==> 50020980:114700
51: SKP: 4096( 1 blks) ==> 50135680:4108
52: RAW: 86016( 21 blks) ==> 50135692:86028
53: SKP: 4096( 1 blks) ==> 50221720:4108
54: RAW: 36864( 9 blks) ==> 50221732:36876
55: SKP: 8192( 2 blks) ==> 50258608:8204
56: RAW: 32768( 8 blks) ==> 50258620:32780
57: SKP: 4096( 1 blks) ==> 50291400:4108
58: RAW: 40960( 10 blks) ==> 50291412:40972
59: SKP: 4096( 1 blks) ==> 50332384:4108
60: RAW: 32768( 8 blks) ==> 50332396:32780
61: SKP: 4096( 1 blks) ==> 50365176:4108
62: RAW: 32768( 8 blks) ==> 50365188:32780
63: SKP: 4096( 1 blks) ==> 50397968:4108
64: RAW: 40960( 10 blks) ==> 50397980:40972
65: SKP: 4096( 1 blks) ==> 50438952:4108
66: RAW: 5353472( 1307 blks) ==> 50438964:5353484
67: SKP: 12288( 3 blks) ==> 55792448:12300
68: RAW: 303104( 74 blks) ==> 55792460:303116
69: SKP: 8192( 2 blks) ==> 56095576:8204
70: RAW: 151552( 37 blks) ==> 56095588:151564
71: SKP: 8192( 2 blks) ==> 56247152:8204
72: RAW: 114688( 28 blks) ==> 56247164:114700
73: SKP: 24576( 6 blks) ==> 56361864:24588
74: RAW: 192512( 47 blks) ==> 56361876:192524
75: SKP: 40960( 10 blks) ==> 56554400:40972
76: RAW: 561152( 137 blks) ==> 56554412:561164
77: SKP: 8192( 2 blks) ==> 57115576:8204
78: RAW: 24576( 6 blks) ==> 57115588:24588
79: SKP: 24576( 6 blks) ==> 57140176:24588
80: RAW: 253952( 62 blks) ==> 57140188:253964
81: SKP: 40960( 10 blks) ==> 57394152:40972
82: RAW: 180224( 44 blks) ==> 57394164:180236
83: SKP: 36864( 9 blks) ==> 57574400:36876
84: RAW: 307200( 75 blks) ==> 57574412:307212
85: SKP: 28672( 7 blks) ==> 57881624:28684
86: RAW: 204800( 50 blks) ==> 57881636:204812
87: SKP: 24576( 6 blks) ==> 58086448:24588
88: RAW: 20480( 5 blks) ==> 58086460:20492
89: SKP: 12288( 3 blks) ==> 58106952:12300
90: RAW: 221184( 54 blks) ==> 58106964:221196
91: SKP: 24576( 6 blks) ==> 58328160:24588
92: RAW: 24576( 6 blks) ==> 58328172:24588
93: SKP: 8192( 2 blks) ==> 58352760:8204
94: RAW: 552960( 135 blks) ==> 58352772:552972
95: SKP: 24576( 6 blks) ==> 58905744:24588
96: RAW: 196608( 48 blks) ==> 58905756:196620
97: SKP: 36864( 9 blks) ==> 59102376:36876
98: RAW: 32768( 8 blks) ==> 59102388:32780
99: SKP: 12288( 3 blks) ==> 59135168:12300
100: RAW: 233472( 57 blks) ==> 59135180:233484
101: SKP: 12288( 3 blks) ==> 59368664:12300
102: RAW: 24576( 6 blks) ==> 59368676:24588
103: SKP: 36864( 9 blks) ==> 59393264:36876
104: RAW: 180224( 44 blks) ==> 59393276:180236
105: SKP: 40960( 10 blks) ==> 59573512:40972
106: RAW: 20480( 5 blks) ==> 59573524:20492
107: SKP: 53248( 13 blks) ==> 59594016:53260
108: RAW: 151552( 37 blks) ==> 59594028:151564
109: SKP: 53248( 13 blks) ==> 59745592:53260
110: RAW: 303104( 74 blks) ==> 59745604:303116
111: SKP: 24576( 6 blks) ==> 60048720:24588
112: RAW: 225280( 55 blks) ==> 60048732:225292
113: SKP: 8192( 2 blks) ==> 60274024:8204
114: RAW: 32768( 8 blks) ==> 60274036:32780
115: SKP: 40960( 10 blks) ==> 60306816:40972
116: RAW: 180224( 44 blks) ==> 60306828:180236
117: SKP: 36864( 9 blks) ==> 60487064:36876
118: RAW: 868352( 212 blks) ==> 60487076:868364
119: SKP: 36864( 9 blks) ==> 61355440:36876
120: RAW: 180224( 44 blks) ==> 61355452:180236
121: SKP: 40960( 10 blks) ==> 61535688:40972
122: RAW: 20480( 5 blks) ==> 61535700:20492
123: SKP: 12288( 3 blks) ==> 61556192:12300
124: RAW: 221184( 54 blks) ==> 61556204:221196
125: SKP: 24576( 6 blks) ==> 61777400:24588
126: RAW: 24576( 6 blks) ==> 61777412:24588
127: SKP: 24576( 6 blks) ==> 61802000:24588
128: RAW: 192512( 47 blks) ==> 61802012:192524
129: SKP: 40960( 10 blks) ==> 61994536:40972
130: RAW: 24576( 6 blks) ==> 61994548:24588
131: SKP: 8192( 2 blks) ==> 62019136:8204
132: RAW: 237568( 58 blks) ==> 62019148:237580
133: SKP: 12288( 3 blks) ==> 62256728:12300
134: RAW: 831488( 203 blks) ==> 62256740:831500
135: SKP: 8192( 2 blks) ==> 63088240:8204
136: RAW: 258048( 63 blks) ==> 63088252:258060
137: SKP: 24576( 6 blks) ==> 63346312:24588
138: RAW: 303104( 74 blks) ==> 63346324:303116
139: SKP: 24576( 6 blks) ==> 63649440:24588
140: RAW: 208896( 51 blks) ==> 63649452:208908
141: SKP: 24576( 6 blks) ==> 63858360:24588
142: RAW: 864256( 211 blks) ==> 63858372:864268
143: SKP: 53248( 13 blks) ==> 64722640:53260
144: RAW: 151552( 37 blks) ==> 64722652:151564
145: SKP: 53248( 13 blks) ==> 64874216:53260
146: RAW: 303104( 74 blks) ==> 64874228:303116
147: SKP: 40960( 10 blks) ==> 65177344:40972
148: RAW: 176128( 43 blks) ==> 65177356:176140
149: SKP: 40960( 10 blks) ==> 65353496:40972
150: RAW: 270336( 66 blks) ==> 65353508:270348
151: SKP: 12288( 3 blks) ==> 65623856:12300
152: RAW: 20480( 5 blks) ==> 65623868:20492
153: SKP: 40960( 10 blks) ==> 65644360:40972
154: RAW: 180224( 44 blks) ==> 65644372:180236
155: SKP: 36864( 9 blks) ==> 65824608:36876
156: RAW: 24576( 6 blks) ==> 65824620:24588
157: SKP: 8192( 2 blks) ==> 65849208:8204
158: RAW: 237568( 58 blks) ==> 65849220:237580
159: SKP: 12288( 3 blks) ==> 66086800:12300
160: RAW: 20480( 5 blks) ==> 66086812:20492
161: SKP: 40960( 10 blks) ==> 66107304:40972
162: RAW: 180224( 44 blks) ==> 66107316:180236
163: SKP: 36864( 9 blks) ==> 66287552:36876
164: RAW: 24576( 6 blks) ==> 66287564:24588
165: SKP: 12288( 3 blks) ==> 66312152:12300
166: RAW: 233472( 57 blks) ==> 66312164:233484
167: SKP: 12288( 3 blks) ==> 66545648:12300
168: RAW: 258048( 63 blks) ==> 66545660:258060
169: SKP: 24576( 6 blks) ==> 66803720:24588
170: RAW: 303104( 74 blks) ==> 66803732:303116
171: SKP: 12288( 3 blks) ==> 67106848:12300
172: RAW: 233472( 57 blks) ==> 67106860:233484
173: SKP: 12288( 3 blks) ==> 67340344:12300
174: RAW: 24576( 6 blks) ==> 67340356:24588
175: SKP: 36864( 9 blks) ==> 67364944:36876
176: RAW: 208896( 51 blks) ==> 67364956:208908
177: SKP: 12288( 3 blks) ==> 67573864:12300
178: RAW: 270336( 66 blks) ==> 67573876:270348
179: SKP: 8192( 2 blks) ==> 67844224:8204
180: RAW: 303104( 74 blks) ==> 67844236:303116
181: SKP: 28672( 7 blks) ==> 68147352:28684
182: RAW: 192512( 47 blks) ==> 68147364:192524
183: SKP: 36864( 9 blks) ==> 68339888:36876
184: RAW: 24576( 6 blks) ==> 68339900:24588
185: SKP: 24576( 6 blks) ==> 68364488:24588
186: RAW: 208896( 51 blks) ==> 68364500:208908
187: SKP: 24576( 6 blks) ==> 68573408:24588
188: RAW: 24576( 6 blks) ==> 68573420:24588
189: SKP: 24576( 6 blks) ==> 68598008:24588
190: RAW: 253952( 62 blks) ==> 68598020:253964
191: SKP: 53248( 13 blks) ==> 68851984:53260
192: RAW: 167936( 41 blks) ==> 68851996:167948
193: SKP: 36864( 9 blks) ==> 69019944:36876
194: RAW: 24576( 6 blks) ==> 69019956:24588
195: SKP: 8192( 2 blks) ==> 69044544:8204
196: RAW: 237568( 58 blks) ==> 69044556:237580
197: SKP: 12288( 3 blks) ==> 69282136:12300
198: RAW: 20480( 5 blks) ==> 69282148:20492
199: SKP: 12288( 3 blks) ==> 69302640:12300
200: RAW: 237568( 58 blks) ==> 69302652:237580
201: SKP: 8192( 2 blks) ==> 69540232:8204
202: RAW: 24576( 6 blks) ==> 69540244:24588
203: SKP: 40960( 10 blks) ==> 69564832:40972
204: RAW: 180224( 44 blks) ==> 69564844:180236
205: SKP: 36864( 9 blks) ==> 69745080:36876
206: RAW: 278528( 68 blks) ==> 69745092:278540
207: SKP: 12288( 3 blks) ==> 70023632:12300
208: RAW: 24576( 6 blks) ==> 70023644:24588
209: SKP: 8192( 2 blks) ==> 70048232:8204
210: RAW: 237568( 58 blks) ==> 70048244:237580
211: SKP: 12288( 3 blks) ==> 70285824:12300
212: RAW: 303104( 74 blks) ==> 70285836:303116
213: SKP: 8192( 2 blks) ==> 70588952:8204
214: RAW: 270336( 66 blks) ==> 70588964:270348
215: SKP: 53248( 13 blks) ==> 70859312:53260
216: RAW: 167936( 41 blks) ==> 70859324:167948
217: SKP: 36864( 9 blks) ==> 71027272:36876
218: RAW: 24576( 6 blks) ==> 71027284:24588
219: SKP: 12288( 3 blks) ==> 71051872:12300
220: RAW: 237568( 58 blks) ==> 71051884:237580
221: SKP: 8192( 2 blks) ==> 71289464:8204
222: RAW: 24576( 6 blks) ==> 71289476:24588
223: SKP: 8192( 2 blks) ==> 71314064:8204
224: RAW: 237568( 58 blks) ==> 71314076:237580
225: SKP: 12288( 3 blks) ==> 71551656:12300
226: RAW: 20480( 5 blks) ==> 71551668:20492
227: SKP: 12288( 3 blks) ==> 71572160:12300
228: RAW: 237568( 58 blks) ==> 71572172:237580
229: SKP: 8192( 2 blks) ==> 71809752:8204
230: RAW: 24576( 6 blks) ==> 71809764:24588
231: SKP: 24576( 6 blks) ==> 71834352:24588
232: RAW: 258048( 63 blks) ==> 71834364:258060
233: SKP: 8192( 2 blks) ==> 72092424:8204
234: RAW: 270336( 66 blks) ==> 72092436:270348
235: SKP: 12288( 3 blks) ==> 72362784:12300
236: RAW: 237568( 58 blks) ==> 72362796:237580
237: SKP: 8192( 2 blks) ==> 72600376:8204
238: RAW: 24576( 6 blks) ==> 72600388:24588
239: SKP: 8192( 2 blks) ==> 72624976:8204
240: RAW: 270336( 66 blks) ==> 72624988:270348
241: SKP: 28672( 7 blks) ==> 72895336:28684
242: RAW: 204800( 50 blks) ==> 72895348:204812
243: SKP: 24576( 6 blks) ==> 73100160:24588
244: RAW: 24576( 6 blks) ==> 73100172:24588
245: SKP: 12288( 3 blks) ==> 73124760:12300
246: RAW: 233472( 57 blks) ==> 73124772:233484
247: SKP: 12288( 3 blks) ==> 73358256:12300
248: RAW: 303104( 74 blks) ==> 73358268:303116
249: SKP: 12288( 3 blks) ==> 73661384:12300
250: RAW: 221184( 54 blks) ==> 73661396:221196
251: SKP: 24576( 6 blks) ==> 73882592:24588
252: RAW: 24576( 6 blks) ==> 73882604:24588
253: SKP: 24576( 6 blks) ==> 73907192:24588
254: RAW: 208896( 51 blks) ==> 73907204:208908
255: SKP: 24576( 6 blks) ==> 74116112:24588
256: RAW: 20480( 5 blks) ==> 74116124:20492
257: SKP: 57344( 14 blks) ==> 74136616:57356
258: RAW: 147456( 36 blks) ==> 74136628:147468
259: SKP: 53248( 13 blks) ==> 74284096:53260
260: RAW: 274432( 67 blks) ==> 74284108:274444
261: SKP: 8192( 2 blks) ==> 74558552:8204
262: RAW: 303104( 74 blks) ==> 74558564:303116
263: SKP: 24576( 6 blks) ==> 74861680:24588
264: RAW: 208896( 51 blks) ==> 74861692:208908
265: SKP: 24576( 6 blks) ==> 75070600:24588
266: RAW: 307200( 75 blks) ==> 75070612:307212
267: SKP: 24576( 6 blks) ==> 75377824:24588
268: RAW: 221184( 54 blks) ==> 75377836:221196
269: SKP: 12288( 3 blks) ==> 75599032:12300
270: RAW: 303104( 74 blks) ==> 75599044:303116
271: SKP: 8192( 2 blks) ==> 75902160:8204
272: RAW: 225280( 55 blks) ==> 75902172:225292
273: SKP: 24576( 6 blks) ==> 76127464:24588
274: RAW: 20480( 5 blks) ==> 76127476:20492
275: SKP: 28672( 7 blks) ==> 76147968:28684
276: RAW: 192512( 47 blks) ==> 76147980:192524
277: SKP: 36864( 9 blks) ==> 76340504:36876
278: RAW: 24576( 6 blks) ==> 76340516:24588
279: SKP: 24576( 6 blks) ==> 76365104:24588
280: RAW: 208896( 51 blks) ==> 76365116:208908
281: SKP: 24576( 6 blks) ==> 76574024:24588
282: RAW: 303104( 74 blks) ==> 76574036:303116
283: SKP: 12288( 3 blks) ==> 76877152:12300
284: RAW: 237568( 58 blks) ==> 76877164:237580
285: SKP: 8192( 2 blks) ==> 77114744:8204
286: RAW: 24576( 6 blks) ==> 77114756:24588
287: SKP: 8192( 2 blks) ==> 77139344:8204
288: RAW: 237568( 58 blks) ==> 77139356:237580
289: SKP: 12288( 3 blks) ==> 77376936:12300
290: RAW: 24576( 6 blks) ==> 77376948:24588
291: SKP: 8192( 2 blks) ==> 77401536:8204
292: RAW: 237568( 58 blks) ==> 77401548:237580
293: SKP: 12288( 3 blks) ==> 77639128:12300
294: RAW: 20480( 5 blks) ==> 77639140:20492
295: SKP: 53248( 13 blks) ==> 77659632:53260
296: RAW: 151552( 37 blks) ==> 77659644:151564
297: SKP: 53248( 13 blks) ==> 77811208:53260
298: RAW: 413696( 101 blks) ==> 77811220:413708
299: SKP: 12288( 3 blks) ==> 78224928:12300
300: RAW: 1114112( 272 blks) ==> 78224940:1114124
301: SKP: 8192( 2 blks) ==> 79339064:8204
302: RAW: 237568( 58 blks) ==> 79339076:237580
303: SKP: 12288( 3 blks) ==> 79576656:12300
304: RAW: 24576( 6 blks) ==> 79576668:24588
305: SKP: 8192( 2 blks) ==> 79601256:8204
306: RAW: 237568( 58 blks) ==> 79601268:237580
307: SKP: 12288( 3 blks) ==> 79838848:12300
308: RAW: 20480( 5 blks) ==> 79838860:20492
309: SKP: 12288( 3 blks) ==> 79859352:12300
310: RAW: 237568( 58 blks) ==> 79859364:237580
311: SKP: 8192( 2 blks) ==> 80096944:8204
312: RAW: 24576( 6 blks) ==> 80096956:24588
313: SKP: 24576( 6 blks) ==> 80121544:24588
314: RAW: 208896( 51 blks) ==> 80121556:208908
315: SKP: 24576( 6 blks) ==> 80330464:24588
316: RAW: 20480( 5 blks) ==> 80330476:20492
317: SKP: 24576( 6 blks) ==> 80350968:24588
318: RAW: 258048( 63 blks) ==> 80350980:258060
319: SKP: 12288( 3 blks) ==> 80609040:12300
320: RAW: 270336( 66 blks) ==> 80609052:270348
321: SKP: 28672( 7 blks) ==> 80879400:28684
322: RAW: 499712( 122 blks) ==> 80879412:499724
323: SKP: 8192( 2 blks) ==> 81379136:8204
324: RAW: 303104( 74 blks) ==> 81379148:303116
325: SKP: 28672( 7 blks) ==> 81682264:28684
326: RAW: 204800( 50 blks) ==> 81682276:204812
327: SKP: 24576( 6 blks) ==> 81887088:24588
328: RAW: 307200( 75 blks) ==> 81887100:307212
329: SKP: 36864( 9 blks) ==> 82194312:36876
330: RAW: 180224( 44 blks) ==> 82194324:180236
331: SKP: 40960( 10 blks) ==> 82374560:40972
332: RAW: 20480( 5 blks) ==> 82374572:20492
333: SKP: 12288( 3 blks) ==> 82395064:12300
334: RAW: 270336( 66 blks) ==> 82395076:270348
335: SKP: 53248( 13 blks) ==> 82665424:53260
336: RAW: 151552( 37 blks) ==> 82665436:151564
337: SKP: 53248( 13 blks) ==> 82817000:53260
338: RAW: 24576( 6 blks) ==> 82817012:24588
339: SKP: 36864( 9 blks) ==> 82841600:36876
340: RAW: 180224( 44 blks) ==> 82841612:180236
341: SKP: 40960( 10 blks) ==> 83021848:40972
342: RAW: 20480( 5 blks) ==> 83021860:20492
343: SKP: 8192( 2 blks) ==> 83042352:8204
344: RAW: 229376( 56 blks) ==> 83042364:229388
345: SKP: 20480( 5 blks) ==> 83271752:20492
346: RAW: 270336( 66 blks) ==> 83271764:270348
347: SKP: 12288( 3 blks) ==> 83542112:12300
348: RAW: 270336( 66 blks) ==> 83542124:270348
349: SKP: 8192( 2 blks) ==> 83812472:8204
350: RAW: 24576( 6 blks) ==> 83812484:24588
351: SKP: 12288( 3 blks) ==> 83837072:12300
352: RAW: 233472( 57 blks) ==> 83837084:233484
353: SKP: 12288( 3 blks) ==> 84070568:12300
354: RAW: 32768( 8 blks) ==> 84070580:32780
355: SKP: 24576( 6 blks) ==> 84103360:24588
356: RAW: 225280( 55 blks) ==> 84103372:225292
357: SKP: 8192( 2 blks) ==> 84328664:8204
358: RAW: 552960( 135 blks) ==> 84328676:552972
359: SKP: 8192( 2 blks) ==> 84881648:8204
360: RAW: 552960( 135 blks) ==> 84881660:552972
361: SKP: 8192( 2 blks) ==> 85434632:8204
362: RAW: 585728( 143 blks) ==> 85434644:585740
363: SKP: 12288( 3 blks) ==> 86020384:12300
364: RAW: 237568( 58 blks) ==> 86020396:237580
365: SKP: 8192( 2 blks) ==> 86257976:8204
366: RAW: 585728( 143 blks) ==> 86257988:585740
367: SKP: 24576( 6 blks) ==> 86843728:24588
368: RAW: 208896( 51 blks) ==> 86843740:208908
369: SKP: 24576( 6 blks) ==> 87052648:24588
370: RAW: 303104( 74 blks) ==> 87052660:303116
371: SKP: 12288( 3 blks) ==> 87355776:12300
372: RAW: 237568( 58 blks) ==> 87355788:237580
373: SKP: 8192( 2 blks) ==> 87593368:8204
374: RAW: 24576( 6 blks) ==> 87593380:24588
375: SKP: 8192( 2 blks) ==> 87617968:8204
376: RAW: 241664( 59 blks) ==> 87617980:241676
377: SKP: 8192( 2 blks) ==> 87859656:8204
378: RAW: 24576( 6 blks) ==> 87859668:24588
379: SKP: 36864( 9 blks) ==> 87884256:36876
380: RAW: 180224( 44 blks) ==> 87884268:180236
381: SKP: 40960( 10 blks) ==> 88064504:40972
382: RAW: 303104( 74 blks) ==> 88064516:303116
383: SKP: 24576( 6 blks) ==> 88367632:24588
384: RAW: 221184( 54 blks) ==> 88367644:221196
385: SKP: 12288( 3 blks) ==> 88588840:12300
386: RAW: 20480( 5 blks) ==> 88588852:20492
387: SKP: 24576( 6 blks) ==> 88609344:24588
388: RAW: 196608( 48 blks) ==> 88609356:196620
389: SKP: 36864( 9 blks) ==> 88805976:36876
390: RAW: 270336( 66 blks) ==> 88805988:270348
391: SKP: 12288( 3 blks) ==> 89076336:12300
392: RAW: 585728( 143 blks) ==> 89076348:585740
393: SKP: 8192( 2 blks) ==> 89662088:8204
394: RAW: 237568( 58 blks) ==> 89662100:237580
395: SKP: 12288( 3 blks) ==> 89899680:12300
396: RAW: 20480( 5 blks) ==> 89899692:20492
397: SKP: 40960( 10 blks) ==> 89920184:40972
398: RAW: 192512( 47 blks) ==> 89920196:192524
399: SKP: 24576( 6 blks) ==> 90112720:24588
400: RAW: 24576( 6 blks) ==> 90112732:24588
401: SKP: 40960( 10 blks) ==> 90137320:40972
402: RAW: 180224( 44 blks) ==> 90137332:180236
403: SKP: 36864( 9 blks) ==> 90317568:36876
404: RAW: 24576( 6 blks) ==> 90317580:24588
405: SKP: 8192( 2 blks) ==> 90342168:8204
406: RAW: 270336( 66 blks) ==> 90342180:270348
407: SKP: 12288( 3 blks) ==> 90612528:12300
408: RAW: 561152( 137 blks) ==> 90612540:561164
409: SKP: 8192( 2 blks) ==> 91173704:8204
410: RAW: 282624( 69 blks) ==> 91173716:282636
411: SKP: 8192( 2 blks) ==> 91456352:8204
412: RAW: 237568( 58 blks) ==> 91456364:237580
413: SKP: 12288( 3 blks) ==> 91693944:12300
414: RAW: 20480( 5 blks) ==> 91693956:20492
415: SKP: 12288( 3 blks) ==> 91714448:12300
416: RAW: 237568( 58 blks) ==> 91714460:237580
417: SKP: 8192( 2 blks) ==> 91952040:8204
418: RAW: 24576( 6 blks) ==> 91952052:24588
419: SKP: 53248( 13 blks) ==> 91976640:53260
420: RAW: 151552( 37 blks) ==> 91976652:151564
421: SKP: 53248( 13 blks) ==> 92128216:53260
422: RAW: 32768( 8 blks) ==> 92128228:32780
423: SKP: 8192( 2 blks) ==> 92161008:8204
424: RAW: 237568( 58 blks) ==> 92161020:237580
425: SKP: 12288( 3 blks) ==> 92398600:12300
426: RAW: 1114112( 272 blks) ==> 92398612:1114124
427: SKP: 8192( 2 blks) ==> 93512736:8204
428: RAW: 270336( 66 blks) ==> 93512748:270348
429: SKP: 12288( 3 blks) ==> 93783096:12300
430: RAW: 32768( 8 blks) ==> 93783108:32780
431: SKP: 8192( 2 blks) ==> 93815888:8204
432: RAW: 237568( 58 blks) ==> 93815900:237580
433: SKP: 12288( 3 blks) ==> 94053480:12300
434: RAW: 303104( 74 blks) ==> 94053492:303116
435: SKP: 24576( 6 blks) ==> 94356608:24588
436: RAW: 208896( 51 blks) ==> 94356620:208908
437: SKP: 24576( 6 blks) ==> 94565528:24588
438: RAW: 303104( 74 blks) ==> 94565540:303116
439: SKP: 12288( 3 blks) ==> 94868656:12300
440: RAW: 237568( 58 blks) ==> 94868668:237580
441: SKP: 8192( 2 blks) ==> 95106248:8204
442: RAW: 24576( 6 blks) ==> 95106260:24588
443: SKP: 8192( 2 blks) ==> 95130848:8204
444: RAW: 237568( 58 blks) ==> 95130860:237580
445: SKP: 12288( 3 blks) ==> 95368440:12300
446: RAW: 20480( 5 blks) ==> 95368452:20492
447: SKP: 40960( 10 blks) ==> 95388944:40972
448: RAW: 163840( 40 blks) ==> 95388956:163852
449: SKP: 53248( 13 blks) ==> 95552808:53260
450: RAW: 24576( 6 blks) ==> 95552820:24588
451: SKP: 12288( 3 blks) ==> 95577408:12300
452: RAW: 270336( 66 blks) ==> 95577420:270348
453: SKP: 24576( 6 blks) ==> 95847768:24588
454: RAW: 208896( 51 blks) ==> 95847780:208908
455: SKP: 24576( 6 blks) ==> 96056688:24588
456: RAW: 20480( 5 blks) ==> 96056700:20492
457: SKP: 40960( 10 blks) ==> 96077192:40972
458: RAW: 180224( 44 blks) ==> 96077204:180236
459: SKP: 36864( 9 blks) ==> 96257440:36876
460: RAW: 24576( 6 blks) ==> 96257452:24588
461: SKP: 24576( 6 blks) ==> 96282040:24588
462: RAW: 192512( 47 blks) ==> 96282052:192524
463: SKP: 40960( 10 blks) ==> 96474576:40972
464: RAW: 270336( 66 blks) ==> 96474588:270348
465: SKP: 12288( 3 blks) ==> 96744936:12300
466: RAW: 20480( 5 blks) ==> 96744948:20492
467: SKP: 8192( 2 blks) ==> 96765440:8204
468: RAW: 241664( 59 blks) ==> 96765452:241676
469: SKP: 8192( 2 blks) ==> 97007128:8204
470: RAW: 24576( 6 blks) ==> 97007140:24588
471: SKP: 24576( 6 blks) ==> 97031728:24588
472: RAW: 208896( 51 blks) ==> 97031740:208908
473: SKP: 24576( 6 blks) ==> 97240648:24588
474: RAW: 20480( 5 blks) ==> 97240660:20492
475: SKP: 40960( 10 blks) ==> 97261152:40972
476: RAW: 180224( 44 blks) ==> 97261164:180236
477: SKP: 36864( 9 blks) ==> 97441400:36876
478: RAW: 270336( 66 blks) ==> 97441412:270348
479: SKP: 12288( 3 blks) ==> 97711760:12300
480: RAW: 24576( 6 blks) ==> 97711772:24588
481: SKP: 8192( 2 blks) ==> 97736360:8204
482: RAW: 270336( 66 blks) ==> 97736372:270348
483: SKP: 12288( 3 blks) ==> 98006720:12300
484: RAW: 548864( 134 blks) ==> 98006732:548876
485: SKP: 12288( 3 blks) ==> 98555608:12300
486: RAW: 270336( 66 blks) ==> 98555620:270348
487: SKP: 12288( 3 blks) ==> 98825968:12300
488: RAW: 233472( 57 blks) ==> 98825980:233484
489: SKP: 12288( 3 blks) ==> 99059464:12300
490: RAW: 24576( 6 blks) ==> 99059476:24588
491: SKP: 4096( 1 blks) ==> 99084064:4108
492: RAW: 229376( 56 blks) ==> 99084076:229388
493: SKP: 24576( 6 blks) ==> 99313464:24588
494: RAW: 548864( 134 blks) ==> 99313476:548876
495: SKP: 12288( 3 blks) ==> 99862352:12300
496: RAW: 24576( 6 blks) ==> 99862364:24588
497: SKP: 24576( 6 blks) ==> 99886952:24588
498: RAW: 221184( 54 blks) ==> 99886964:221196
499: SKP: 12288( 3 blks) ==> 100108160:12300
500: RAW: 20480( 5 blks) ==> 100108172:20492
501: SKP: 12288( 3 blks) ==> 100128664:12300
502: RAW: 237568( 58 blks) ==> 100128676:237580
503: SKP: 8192( 2 blks) ==> 100366256:8204
504: RAW: 303104( 74 blks) ==> 100366268:303116
505: SKP: 28672( 7 blks) ==> 100669384:28684
506: RAW: 208896( 51 blks) ==> 100669396:208908
507: SKP: 20480( 5 blks) ==> 100878304:20492
508: RAW: 24576( 6 blks) ==> 100878316:24588
509: SKP: 53248( 13 blks) ==> 100902904:53260
510: RAW: 151552( 37 blks) ==> 100902916:151564
511: SKP: 53248( 13 blks) ==> 101054480:53260
512: RAW: 24576( 6 blks) ==> 101054492:24588
513: SKP: 36864( 9 blks) ==> 101079080:36876
514: RAW: 196608( 48 blks) ==> 101079092:196620
515: SKP: 24576( 6 blks) ==> 101275712:24588
516: RAW: 20480( 5 blks) ==> 101275724:20492
517: SKP: 12288( 3 blks) ==> 101296216:12300
518: RAW: 278528( 68 blks) ==> 101296228:278540
519: SKP: 24576( 6 blks) ==> 101574768:24588
520: RAW: 208896( 51 blks) ==> 101574780:208908
521: SKP: 24576( 6 blks) ==> 101783688:24588
522: RAW: 303104( 74 blks) ==> 101783700:303116
523: SKP: 12288( 3 blks) ==> 102086816:12300
524: RAW: 237568( 58 blks) ==> 102086828:237580
525: SKP: 8192( 2 blks) ==> 102324408:8204
526: RAW: 24576( 6 blks) ==> 102324420:24588
527: SKP: 12288( 3 blks) ==> 102349008:12300
528: RAW: 233472( 57 blks) ==> 102349020:233484
529: SKP: 12288( 3 blks) ==> 102582504:12300
530: RAW: 24576( 6 blks) ==> 102582516:24588
531: SKP: 8192( 2 blks) ==> 102607104:8204
532: RAW: 790528( 193 blks) ==> 102607116:790540
533: SKP: 12288( 3 blks) ==> 103397656:12300
534: RAW: 249856( 61 blks) ==> 103397668:249868
535: SKP: 36864( 9 blks) ==> 103647536:36876
536: RAW: 24576( 6 blks) ==> 103647548:24588
537: SKP: 53248( 13 blks) ==> 103672136:53260
538: RAW: 151552( 37 blks) ==> 103672148:151564
539: SKP: 53248( 13 blks) ==> 103823712:53260
540: RAW: 303104( 74 blks) ==> 103823724:303116
541: SKP: 12288( 3 blks) ==> 104126840:12300
542: RAW: 237568( 58 blks) ==> 104126852:237580
543: SKP: 8192( 2 blks) ==> 104364432:8204
544: RAW: 24576( 6 blks) ==> 104364444:24588
545: SKP: 53248( 13 blks) ==> 104389032:53260
546: RAW: 135168( 33 blks) ==> 104389044:135180
547: SKP: 69632( 17 blks) ==> 104524224:69644
548: RAW: 20480( 5 blks) ==> 104524236:20492
549: SKP: 40960( 10 blks) ==> 104544728:40972
550: RAW: 180224( 44 blks) ==> 104544740:180236
551: SKP: 36864( 9 blks) ==> 104724976:36876
552: RAW: 24576( 6 blks) ==> 104724988:24588
553: SKP: 53248( 13 blks) ==> 104749576:53260
554: RAW: 151552( 37 blks) ==> 104749588:151564
555: SKP: 53248( 13 blks) ==> 104901152:53260
556: RAW: 585728( 143 blks) ==> 104901164:585740
557: SKP: 8192( 2 blks) ==> 105486904:8204
558: RAW: 552960( 135 blks) ==> 105486916:552972
559: SKP: 12288( 3 blks) ==> 106039888:12300
560: RAW: 548864( 134 blks) ==> 106039900:548876
561: SKP: 24576( 6 blks) ==> 106588776:24588
562: RAW: 196608( 48 blks) ==> 106588788:196620
563: SKP: 36864( 9 blks) ==> 106785408:36876
564: RAW: 585728( 143 blks) ==> 106785420:585740
565: SKP: 69632( 17 blks) ==> 107371160:69644
566: RAW: 151552( 37 blks) ==> 107371172:151564
567: SKP: 36864( 9 blks) ==> 107522736:36876
568: RAW: 24576( 6 blks) ==> 107522748:24588
569: SKP: 8192( 2 blks) ==> 107547336:8204
570: RAW: 270336( 66 blks) ==> 107547348:270348
571: SKP: 57344( 14 blks) ==> 107817696:57356
572: RAW: 163840( 40 blks) ==> 107817708:163852
573: SKP: 36864( 9 blks) ==> 107981560:36876
574: RAW: 24576( 6 blks) ==> 107981572:24588
575: SKP: 12288( 3 blks) ==> 108006160:12300
576: RAW: 548864( 134 blks) ==> 108006172:548876
577: SKP: 12288( 3 blks) ==> 108555048:12300
578: RAW: 237568( 58 blks) ==> 108555060:237580
579: SKP: 8192( 2 blks) ==> 108792640:8204
580: RAW: 585728( 143 blks) ==> 108792652:585740
581: SKP: 24576( 6 blks) ==> 109378392:24588
582: RAW: 208896( 51 blks) ==> 109378404:208908
583: SKP: 24576( 6 blks) ==> 109587312:24588
584: RAW: 303104( 74 blks) ==> 109587324:303116
585: SKP: 12288( 3 blks) ==> 109890440:12300
586: RAW: 221184( 54 blks) ==> 109890452:221196
587: SKP: 24576( 6 blks) ==> 110111648:24588
588: RAW: 24576( 6 blks) ==> 110111660:24588
589: SKP: 12288( 3 blks) ==> 110136248:12300
590: RAW: 233472( 57 blks) ==> 110136260:233484
591: SKP: 12288( 3 blks) ==> 110369744:12300
592: RAW: 303104( 74 blks) ==> 110369756:303116
593: SKP: 53248( 13 blks) ==> 110672872:53260
594: RAW: 151552( 37 blks) ==> 110672884:151564
595: SKP: 53248( 13 blks) ==> 110824448:53260
596: RAW: 24576( 6 blks) ==> 110824460:24588
597: SKP: 24576( 6 blks) ==> 110849048:24588
598: RAW: 536576( 131 blks) ==> 110849060:536588
599: SKP: 4096( 1 blks) ==> 111385648:4108
600: RAW: 249856( 61 blks) ==> 111385660:249868
601: SKP: 4096( 1 blks) ==> 111635528:4108
602: RAW: 831488( 203 blks) ==> 111635540:831500
603: SKP: 12288( 3 blks) ==> 112467040:12300
604: RAW: 24576( 6 blks) ==> 112467052:24588
605: SKP: 8192( 2 blks) ==> 112491640:8204
606: RAW: 237568( 58 blks) ==> 112491652:237580
607: SKP: 12288( 3 blks) ==> 112729232:12300
608: RAW: 20480( 5 blks) ==> 112729244:20492
609: SKP: 12288( 3 blks) ==> 112749736:12300
610: RAW: 237568( 58 blks) ==> 112749748:237580
611: SKP: 8192( 2 blks) ==> 112987328:8204
612: RAW: 24576( 6 blks) ==> 112987340:24588
613: SKP: 24576( 6 blks) ==> 113011928:24588
614: RAW: 212992( 52 blks) ==> 113011940:213004
615: SKP: 20480( 5 blks) ==> 113224944:20492
616: RAW: 270336( 66 blks) ==> 113224956:270348
617: SKP: 8192( 2 blks) ==> 113495304:8204
618: RAW: 585728( 143 blks) ==> 113495316:585740
619: SKP: 12288( 3 blks) ==> 114081056:12300
620: RAW: 552960( 135 blks) ==> 114081068:552972
621: SKP: 36864( 9 blks) ==> 114634040:36876
622: RAW: 180224( 44 blks) ==> 114634052:180236
623: SKP: 40960( 10 blks) ==> 114814288:40972
624: RAW: 20480( 5 blks) ==> 114814300:20492
625: SKP: 12288( 3 blks) ==> 114834792:12300
626: RAW: 237568( 58 blks) ==> 114834804:237580
627: SKP: 8192( 2 blks) ==> 115072384:8204
628: RAW: 24576( 6 blks) ==> 115072396:24588
629: SKP: 8192( 2 blks) ==> 115096984:8204
630: RAW: 270336( 66 blks) ==> 115096996:270348
631: SKP: 28672( 7 blks) ==> 115367344:28684
632: RAW: 200704( 49 blks) ==> 115367356:200716
633: SKP: 28672( 7 blks) ==> 115568072:28684
634: RAW: 24576( 6 blks) ==> 115568084:24588
635: SKP: 12288( 3 blks) ==> 115592672:12300
636: RAW: 270336( 66 blks) ==> 115592684:270348
637: SKP: 8192( 2 blks) ==> 115863032:8204
638: RAW: 241664( 59 blks) ==> 115863044:241676
639: SKP: 8192( 2 blks) ==> 116104720:8204
640: RAW: 303104( 74 blks) ==> 116104732:303116
641: SKP: 8192( 2 blks) ==> 116407848:8204
642: RAW: 237568( 58 blks) ==> 116407860:237580
643: SKP: 12288( 3 blks) ==> 116645440:12300
644: RAW: 24576( 6 blks) ==> 116645452:24588
645: SKP: 8192( 2 blks) ==> 116670040:8204
646: RAW: 237568( 58 blks) ==> 116670052:237580
647: SKP: 12288( 3 blks) ==> 116907632:12300
648: RAW: 20480( 5 blks) ==> 116907644:20492
649: SKP: 12288( 3 blks) ==> 116928136:12300
650: RAW: 237568( 58 blks) ==> 116928148:237580
651: SKP: 8192( 2 blks) ==> 117165728:8204
652: RAW: 303104( 74 blks) ==> 117165740:303116
653: SKP: 12288( 3 blks) ==> 117468856:12300
654: RAW: 241664( 59 blks) ==> 117468868:241676
655: SKP: 4096( 1 blks) ==> 117710544:4108
656: RAW: 24576( 6 blks) ==> 117710556:24588
657: SKP: 12288( 3 blks) ==> 117735144:12300
658: RAW: 233472( 57 blks) ==> 117735156:233484
659: SKP: 12288( 3 blks) ==> 117968640:12300
660: RAW: 24576( 6 blks) ==> 117968652:24588
661: SKP: 8192( 2 blks) ==> 117993240:8204
662: RAW: 237568( 58 blks) ==> 117993252:237580
663: SKP: 12288( 3 blks) ==> 118230832:12300
664: RAW: 581632( 142 blks) ==> 118230844:581644
665: SKP: 28672( 7 blks) ==> 118812488:28684
666: RAW: 221184( 54 blks) ==> 118812500:221196
667: SKP: 8192( 2 blks) ==> 119033696:8204
668: RAW: 24576( 6 blks) ==> 119033708:24588
669: SKP: 12288( 3 blks) ==> 119058296:12300
670: RAW: 221184( 54 blks) ==> 119058308:221196
671: SKP: 24576( 6 blks) ==> 119279504:24588
672: RAW: 24576( 6 blks) ==> 119279516:24588
673: SKP: 8192( 2 blks) ==> 119304104:8204
674: RAW: 225280( 55 blks) ==> 119304116:225292
675: SKP: 24576( 6 blks) ==> 119529408:24588
676: RAW: 585728( 143 blks) ==> 119529420:585740
677: SKP: 8192( 2 blks) ==> 120115160:8204
678: RAW: 270336( 66 blks) ==> 120115172:270348
679: SKP: 40960( 10 blks) ==> 120385520:40972
680: RAW: 200704( 49 blks) ==> 120385532:200716
681: SKP: 16384( 4 blks) ==> 120586248:16396
682: RAW: 24576( 6 blks) ==> 120586260:24588
683: SKP: 8192( 2 blks) ==> 120610848:8204
684: RAW: 237568( 58 blks) ==> 120610860:237580
685: SKP: 12288( 3 blks) ==> 120848440:12300
686: RAW: 303104( 74 blks) ==> 120848452:303116
687: SKP: 24576( 6 blks) ==> 121151568:24588
688: RAW: 208896( 51 blks) ==> 121151580:208908
689: SKP: 24576( 6 blks) ==> 121360488:24588
690: RAW: 303104( 74 blks) ==> 121360500:303116
691: SKP: 69632( 17 blks) ==> 121663616:69644
692: RAW: 122880( 30 blks) ==> 121663628:122892
693: SKP: 65536( 16 blks) ==> 121786520:65548
694: RAW: 24576( 6 blks) ==> 121786532:24588
695: SKP: 36864( 9 blks) ==> 121811120:36876
696: RAW: 241664( 59 blks) ==> 121811132:241676
697: SKP: 12288( 3 blks) ==> 122052808:12300
698: RAW: 237568( 58 blks) ==> 122052820:237580
699: SKP: 8192( 2 blks) ==> 122290400:8204
700: RAW: 270336( 66 blks) ==> 122290412:270348
701: SKP: 12288( 3 blks) ==> 122560760:12300
702: RAW: 24576( 6 blks) ==> 122560772:24588
703: SKP: 36864( 9 blks) ==> 122585360:36876
704: RAW: 241664( 59 blks) ==> 122585372:241676
705: SKP: 12288( 3 blks) ==> 122827048:12300
706: RAW: 221184( 54 blks) ==> 122827060:221196
707: SKP: 24576( 6 blks) ==> 123048256:24588
708: RAW: 24576( 6 blks) ==> 123048268:24588
709: SKP: 40960( 10 blks) ==> 123072856:40972
710: RAW: 196608( 48 blks) ==> 123072868:196620
711: SKP: 20480( 5 blks) ==> 123269488:20492
712: RAW: 24576( 6 blks) ==> 123269500:24588
713: SKP: 8192( 2 blks) ==> 123294088:8204
714: RAW: 270336( 66 blks) ==> 123294100:270348
715: SKP: 12288( 3 blks) ==> 123564448:12300
716: RAW: 1392640( 340 blks) ==> 123564460:1392652
717: SKP: 24576( 6 blks) ==> 124957112:24588
718: RAW: 208896( 51 blks) ==> 124957124:208908
719: SKP: 24576( 6 blks) ==> 125166032:24588
720: RAW: 307200( 75 blks) ==> 125166044:307212
721: SKP: 8192( 2 blks) ==> 125473256:8204
722: RAW: 221184( 54 blks) ==> 125473268:221196
723: SKP: 28672( 7 blks) ==> 125694464:28684
724: RAW: 303104( 74 blks) ==> 125694476:303116
725: SKP: 65536( 16 blks) ==> 125997592:65548
726: RAW: 139264( 34 blks) ==> 125997604:139276
727: SKP: 53248( 13 blks) ==> 126136880:53260
728: RAW: 20480( 5 blks) ==> 126136892:20492
729: SKP: 12288( 3 blks) ==> 126157384:12300
730: RAW: 237568( 58 blks) ==> 126157396:237580
731: SKP: 8192( 2 blks) ==> 126394976:8204
732: RAW: 307200( 75 blks) ==> 126394988:307212
733: SKP: 53248( 13 blks) ==> 126702200:53260
734: RAW: 151552( 37 blks) ==> 126702212:151564
735: SKP: 53248( 13 blks) ==> 126853776:53260
736: RAW: 548864( 134 blks) ==> 126853788:548876
737: SKP: 12288( 3 blks) ==> 127402664:12300
738: RAW: 20480( 5 blks) ==> 127402676:20492
739: SKP: 12288( 3 blks) ==> 127423168:12300
740: RAW: 221184( 54 blks) ==> 127423180:221196
741: SKP: 24576( 6 blks) ==> 127644376:24588
742: RAW: 299008( 73 blks) ==> 127644388:299020
743: SKP: 8192( 2 blks) ==> 127943408:8204
744: RAW: 557056( 136 blks) ==> 127943420:557068
745: SKP: 8192( 2 blks) ==> 128500488:8204
746: RAW: 237568( 58 blks) ==> 128500500:237580
747: SKP: 12288( 3 blks) ==> 128738080:12300
748: RAW: 552960( 135 blks) ==> 128738092:552972
749: SKP: 8192( 2 blks) ==> 129291064:8204
750: RAW: 24576( 6 blks) ==> 129291076:24588
751: SKP: 24576( 6 blks) ==> 129315664:24588
752: RAW: 208896( 51 blks) ==> 129315676:208908
753: SKP: 24576( 6 blks) ==> 129524584:24588
754: RAW: 270336( 66 blks) ==> 129524596:270348
755: SKP: 8192( 2 blks) ==> 129794944:8204
756: RAW: 24576( 6 blks) ==> 129794956:24588
757: SKP: 12288( 3 blks) ==> 129819544:12300
758: RAW: 233472( 57 blks) ==> 129819556:233484
759: SKP: 12288( 3 blks) ==> 130053040:12300
760: RAW: 24576( 6 blks) ==> 130053052:24588
761: SKP: 24576( 6 blks) ==> 130077640:24588
762: RAW: 192512( 47 blks) ==> 130077652:192524
763: SKP: 40960( 10 blks) ==> 130270176:40972
764: RAW: 20480( 5 blks) ==> 130270188:20492
765: SKP: 12288( 3 blks) ==> 130290680:12300
766: RAW: 237568( 58 blks) ==> 130290692:237580
767: SKP: 8192( 2 blks) ==> 130528272:8204
768: RAW: 24576( 6 blks) ==> 130528284:24588
769: SKP: 8192( 2 blks) ==> 130552872:8204
770: RAW: 237568( 58 blks) ==> 130552884:237580
771: SKP: 12288( 3 blks) ==> 130790464:12300
772: RAW: 20480( 5 blks) ==> 130790476:20492
773: SKP: 40960( 10 blks) ==> 130810968:40972
774: RAW: 180224( 44 blks) ==> 130810980:180236
775: SKP: 36864( 9 blks) ==> 130991216:36876
776: RAW: 24576( 6 blks) ==> 130991228:24588
777: SKP: 24576( 6 blks) ==> 131015816:24588
778: RAW: 208896( 51 blks) ==> 131015828:208908
779: SKP: 24576( 6 blks) ==> 131224736:24588
780: RAW: 32768( 8 blks) ==> 131224748:32780
781: SKP: 40960( 10 blks) ==> 131257528:40972
782: RAW: 208896( 51 blks) ==> 131257540:208908
783: SKP: 8192( 2 blks) ==> 131466448:8204
784: RAW: 303104( 74 blks) ==> 131466460:303116
785: SKP: 53248( 13 blks) ==> 131769576:53260
786: RAW: 151552( 37 blks) ==> 131769588:151564
787: SKP: 53248( 13 blks) ==> 131921152:53260
788: RAW: 24576( 6 blks) ==> 131921164:24588
789: SKP: 24576( 6 blks) ==> 131945752:24588
790: RAW: 192512( 47 blks) ==> 131945764:192524
791: SKP: 40960( 10 blks) ==> 132138288:40972
792: RAW: 20480( 5 blks) ==> 132138300:20492
793: SKP: 28672( 7 blks) ==> 132158792:28684
794: RAW: 212992( 52 blks) ==> 132158804:213004
795: SKP: 16384( 4 blks) ==> 132371808:16396
796: RAW: 585728( 143 blks) ==> 132371820:585740
797: SKP: 12288( 3 blks) ==> 132957560:12300
798: RAW: 237568( 58 blks) ==> 132957572:237580
799: SKP: 8192( 2 blks) ==> 133195152:8204
800: RAW: 24576( 6 blks) ==> 133195164:24588
801: SKP: 8192( 2 blks) ==> 133219752:8204
802: RAW: 241664( 59 blks) ==> 133219764:241676
803: SKP: 8192( 2 blks) ==> 133461440:8204
804: RAW: 270336( 66 blks) ==> 133461452:270348
805: SKP: 12288( 3 blks) ==> 133731800:12300
806: RAW: 20480( 5 blks) ==> 133731812:20492
807: SKP: 12288( 3 blks) ==> 133752304:12300
808: RAW: 237568( 58 blks) ==> 133752316:237580
809: SKP: 8192( 2 blks) ==> 133989896:8204
810: RAW: 24576( 6 blks) ==> 133989908:24588
811: SKP: 8192( 2 blks) ==> 134014496:8204
812: RAW: 237568( 58 blks) ==> 134014508:237580
813: SKP: 12288( 3 blks) ==> 134252088:12300
814: RAW: 20480( 5 blks) ==> 134252100:20492
815: SKP: 24576( 6 blks) ==> 134272592:24588
816: RAW: 258048( 63 blks) ==> 134272604:258060
817: SKP: 12288( 3 blks) ==> 134530664:12300
818: RAW: 233472( 57 blks) ==> 134530676:233484
819: SKP: 12288( 3 blks) ==> 134764160:12300
820: RAW: 303104( 74 blks) ==> 134764172:303116
821: SKP: 12288( 3 blks) ==> 135067288:12300
822: RAW: 221184( 54 blks) ==> 135067300:221196
823: SKP: 24576( 6 blks) ==> 135288496:24588
824: RAW: 1146880( 280 blks) ==> 135288508:1146892
825: SKP: 12288( 3 blks) ==> 136435400:12300
826: RAW: 237568( 58 blks) ==> 136435412:237580
827: SKP: 8192( 2 blks) ==> 136672992:8204
828: RAW: 307200( 75 blks) ==> 136673004:307212
829: SKP: 8192( 2 blks) ==> 136980216:8204
830: RAW: 237568( 58 blks) ==> 136980228:237580
831: SKP: 12288( 3 blks) ==> 137217808:12300
832: RAW: 20480( 5 blks) ==> 137217820:20492
833: SKP: 12288( 3 blks) ==> 137238312:12300
834: RAW: 278528( 68 blks) ==> 137238324:278540
835: SKP: 12288( 3 blks) ==> 137516864:12300
836: RAW: 233472( 57 blks) ==> 137516876:233484
837: SKP: 12288( 3 blks) ==> 137750360:12300
838: RAW: 24576( 6 blks) ==> 137750372:24588
839: SKP: 8192( 2 blks) ==> 137774960:8204
840: RAW: 270336( 66 blks) ==> 137774972:270348
841: SKP: 12288( 3 blks) ==> 138045320:12300
842: RAW: 237568( 58 blks) ==> 138045332:237580
843: SKP: 8192( 2 blks) ==> 138282912:8204
844: RAW: 24576( 6 blks) ==> 138282924:24588
845: SKP: 12288( 3 blks) ==> 138307512:12300
846: RAW: 233472( 57 blks) ==> 138307524:233484
847: SKP: 12288( 3 blks) ==> 138541008:12300
848: RAW: 270336( 66 blks) ==> 138541020:270348
849: SKP: 12288( 3 blks) ==> 138811368:12300
850: RAW: 20480( 5 blks) ==> 138811380:20492
851: SKP: 12288( 3 blks) ==> 138831872:12300
852: RAW: 270336( 66 blks) ==> 138831884:270348
853: SKP: 8192( 2 blks) ==> 139102232:8204
854: RAW: 1884160( 460 blks) ==> 139102244:1884172
855: SKP: 8192( 2 blks) ==> 140986416:8204
856: RAW: 225280( 55 blks) ==> 140986428:225292
857: SKP: 24576( 6 blks) ==> 141211720:24588
858: RAW: 20480( 5 blks) ==> 141211732:20492
859: SKP: 40960( 10 blks) ==> 141232224:40972
860: RAW: 106496( 26 blks) ==> 141232236:106508
861: SKP: 8192( 2 blks) ==> 141338744:8204
862: RAW: 98304( 24 blks) ==> 141338756:98316
863: SKP: 4096( 1 blks) ==> 141437072:4108
864: RAW: 303104( 74 blks) ==> 141437084:303116
865: SKP: 40960( 10 blks) ==> 141740200:40972
866: RAW: 180224( 44 blks) ==> 141740212:180236
867: SKP: 36864( 9 blks) ==> 141920448:36876
868: RAW: 307200( 75 blks) ==> 141920460:307212
869: SKP: 36864( 9 blks) ==> 142227672:36876
870: RAW: 180224( 44 blks) ==> 142227684:180236
871: SKP: 40960( 10 blks) ==> 142407920:40972
872: RAW: 20480( 5 blks) ==> 142407932:20492
873: SKP: 98304( 24 blks) ==> 142428424:98316
874: RAW: 65536( 16 blks) ==> 142428436:65548
875: SKP: 94208( 23 blks) ==> 142493984:94220
876: RAW: 585728( 143 blks) ==> 142493996:585740
877: SKP: 24576( 6 blks) ==> 143079736:24588
878: RAW: 208896( 51 blks) ==> 143079748:208908
879: SKP: 24576( 6 blks) ==> 143288656:24588
880: RAW: 24576( 6 blks) ==> 143288668:24588
881: SKP: 24576( 6 blks) ==> 143313256:24588
882: RAW: 221184( 54 blks) ==> 143313268:221196
883: SKP: 12288( 3 blks) ==> 143534464:12300
884: RAW: 864256( 211 blks) ==> 143534476:864268
885: SKP: 12288( 3 blks) ==> 144398744:12300
886: RAW: 270336( 66 blks) ==> 144398756:270348
887: SKP: 8192( 2 blks) ==> 144669104:8204
888: RAW: 237568( 58 blks) ==> 144669116:237580
889: SKP: 12288( 3 blks) ==> 144906696:12300
890: RAW: 270336( 66 blks) ==> 144906708:270348
891: SKP: 12288( 3 blks) ==> 145177056:12300
892: RAW: 303104( 74 blks) ==> 145177068:303116
893: SKP: 8192( 2 blks) ==> 145480184:8204
894: RAW: 237568( 58 blks) ==> 145480196:237580
895: SKP: 12288( 3 blks) ==> 145717776:12300
896: RAW: 20480( 5 blks) ==> 145717788:20492
897: SKP: 12288( 3 blks) ==> 145738280:12300
898: RAW: 221184( 54 blks) ==> 145738292:221196
899: SKP: 24576( 6 blks) ==> 145959488:24588
900: RAW: 24576( 6 blks) ==> 145959500:24588
901: SKP: 53248( 13 blks) ==> 145984088:53260
902: RAW: 167936( 41 blks) ==> 145984100:167948
903: SKP: 36864( 9 blks) ==> 146152048:36876
904: RAW: 24576( 6 blks) ==> 146152060:24588
905: SKP: 8192( 2 blks) ==> 146176648:8204
906: RAW: 237568( 58 blks) ==> 146176660:237580
907: SKP: 12288( 3 blks) ==> 146414240:12300
908: RAW: 585728( 143 blks) ==> 146414252:585740
909: SKP: 20480( 5 blks) ==> 146999992:20492
910: RAW: 208896( 51 blks) ==> 147000004:208908
911: SKP: 28672( 7 blks) ==> 147208912:28684
912: RAW: 20480( 5 blks) ==> 147208924:20492
913: SKP: 53248( 13 blks) ==> 147229416:53260
914: RAW: 151552( 37 blks) ==> 147229428:151564
915: SKP: 53248( 13 blks) ==> 147380992:53260
916: RAW: 24576( 6 blks) ==> 147381004:24588
917: SKP: 8192( 2 blks) ==> 147405592:8204
918: RAW: 237568( 58 blks) ==> 147405604:237580
919: SKP: 12288( 3 blks) ==> 147643184:12300
920: RAW: 557056( 136 blks) ==> 147643196:557068
921: SKP: 4096( 1 blks) ==> 148200264:4108
922: RAW: 303104( 74 blks) ==> 148200276:303116
923: SKP: 24576( 6 blks) ==> 148503392:24588
924: RAW: 225280( 55 blks) ==> 148503404:225292
925: SKP: 8192( 2 blks) ==> 148728696:8204
926: RAW: 1150976( 281 blks) ==> 148728708:1150988
927: SKP: 12288( 3 blks) ==> 149879696:12300
928: RAW: 237568( 58 blks) ==> 149879708:237580
929: SKP: 8192( 2 blks) ==> 150117288:8204
930: RAW: 307200( 75 blks) ==> 150117300:307212
931: SKP: 36864( 9 blks) ==> 150424512:36876
932: RAW: 180224( 44 blks) ==> 150424524:180236
933: SKP: 40960( 10 blks) ==> 150604760:40972
934: RAW: 20480( 5 blks) ==> 150604772:20492
935: SKP: 12288( 3 blks) ==> 150625264:12300
936: RAW: 237568( 58 blks) ==> 150625276:237580
937: SKP: 8192( 2 blks) ==> 150862856:8204
938: RAW: 303104( 74 blks) ==> 150862868:303116
939: SKP: 40960( 10 blks) ==> 151165984:40972
940: RAW: 180224( 44 blks) ==> 151165996:180236
941: SKP: 36864( 9 blks) ==> 151346232:36876
942: RAW: 24576( 6 blks) ==> 151346244:24588
943: SKP: 24576( 6 blks) ==> 151370832:24588
944: RAW: 208896( 51 blks) ==> 151370844:208908
945: SKP: 24576( 6 blks) ==> 151579752:24588
946: RAW: 32768( 8 blks) ==> 151579764:32780
947: SKP: 12288( 3 blks) ==> 151612544:12300
948: RAW: 233472( 57 blks) ==> 151612556:233484
949: SKP: 12288( 3 blks) ==> 151846040:12300
950: RAW: 303104( 74 blks) ==> 151846052:303116
951: SKP: 12288( 3 blks) ==> 152149168:12300
952: RAW: 237568( 58 blks) ==> 152149180:237580
953: SKP: 8192( 2 blks) ==> 152386760:8204
954: RAW: 552960( 135 blks) ==> 152386772:552972
955: SKP: 8192( 2 blks) ==> 152939744:8204
956: RAW: 24576( 6 blks) ==> 152939756:24588
957: SKP: 4096( 1 blks) ==> 152964344:4108
958: RAW: 229376( 56 blks) ==> 152964356:229388
959: SKP: 24576( 6 blks) ==> 153193744:24588
960: RAW: 303104( 74 blks) ==> 153193756:303116
961: SKP: 12288( 3 blks) ==> 153496872:12300
962: RAW: 270336( 66 blks) ==> 153496884:270348
963: SKP: 36864( 9 blks) ==> 153767232:36876
964: RAW: 180224( 44 blks) ==> 153767244:180236
965: SKP: 40960( 10 blks) ==> 153947480:40972
966: RAW: 864256( 211 blks) ==> 153947492:864268
967: SKP: 12288( 3 blks) ==> 154811760:12300
968: RAW: 270336( 66 blks) ==> 154811772:270348
969: SKP: 8192( 2 blks) ==> 155082120:8204
970: RAW: 274432( 67 blks) ==> 155082132:274444
971: SKP: 36864( 9 blks) ==> 155356576:36876
972: RAW: 180224( 44 blks) ==> 155356588:180236
973: SKP: 40960( 10 blks) ==> 155536824:40972
974: RAW: 20480( 5 blks) ==> 155536836:20492
975: SKP: 69632( 17 blks) ==> 155557328:69644
976: RAW: 122880( 30 blks) ==> 155557340:122892
977: SKP: 65536( 16 blks) ==> 155680232:65548
978: RAW: 303104( 74 blks) ==> 155680244:303116
979: SKP: 12288( 3 blks) ==> 155983360:12300
980: RAW: 237568( 58 blks) ==> 155983372:237580
981: SKP: 8192( 2 blks) ==> 156220952:8204
982: RAW: 24576( 6 blks) ==> 156220964:24588
983: SKP: 12288( 3 blks) ==> 156245552:12300
984: RAW: 233472( 57 blks) ==> 156245564:233484
985: SKP: 12288( 3 blks) ==> 156479048:12300
986: RAW: 585728( 143 blks) ==> 156479060:585740
987: SKP: 24576( 6 blks) ==> 157064800:24588
988: RAW: 208896( 51 blks) ==> 157064812:208908
989: SKP: 24576( 6 blks) ==> 157273720:24588
990: RAW: 40960( 10 blks) ==> 157273732:40972
991: SKP: 12288( 3 blks) ==> 157314704:12300
992: RAW: 233472( 57 blks) ==> 157314716:233484
993: SKP: 12288( 3 blks) ==> 157548200:12300
994: RAW: 24576( 6 blks) ==> 157548212:24588
995: SKP: 36864( 9 blks) ==> 157572800:36876
996: RAW: 180224( 44 blks) ==> 157572812:180236
997: SKP: 40960( 10 blks) ==> 157753048:40972
998: RAW: 20480( 5 blks) ==> 157753060:20492
999: SKP: 24576( 6 blks) ==> 157773552:24588
1000: RAW: 208896( 51 blks) ==> 157773564:208908
1001: SKP: 24576( 6 blks) ==> 157982472:24588
1002: RAW: 24576( 6 blks) ==> 157982484:24588
1003: SKP: 24576( 6 blks) ==> 158007072:24588
1004: RAW: 221184( 54 blks) ==> 158007084:221196
1005: SKP: 12288( 3 blks) ==> 158228280:12300
1006: RAW: 24576( 6 blks) ==> 158228292:24588
1007: SKP: 8192( 2 blks) ==> 158252880:8204
1008: RAW: 843776( 206 blks) ==> 158252892:843788
1009: SKP: 24576( 6 blks) ==> 159096680:24588
1010: RAW: 208896( 51 blks) ==> 159096692:208908
1011: SKP: 24576( 6 blks) ==> 159305600:24588
1012: RAW: 20480( 5 blks) ==> 159305612:20492
1013: SKP: 12288( 3 blks) ==> 159326104:12300
1014: RAW: 552960( 135 blks) ==> 159326116:552972
1015: SKP: 8192( 2 blks) ==> 159879088:8204
1016: RAW: 237568( 58 blks) ==> 159879100:237580
1017: SKP: 12288( 3 blks) ==> 160116680:12300
1018: RAW: 20480( 5 blks) ==> 160116692:20492
1019: SKP: 53248( 13 blks) ==> 160137184:53260
1020: RAW: 167936( 41 blks) ==> 160137196:167948
1021: SKP: 36864( 9 blks) ==> 160305144:36876
1022: RAW: 24576( 6 blks) ==> 160305156:24588
1023: SKP: 8192( 2 blks) ==> 160329744:8204
1024: RAW: 270336( 66 blks) ==> 160329756
