Flash fail
I was installing step 3 through sdkmanger, but installed failed.
use nvme storage, have not sd-card.
Can you please check what the problem is?
Here is sdkmanger message.
02:04:23 INFO: Flash Jetson Linux - flash: [ 0.3210 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
02:04:23 INFO: Flash Jetson Linux - flash: [ 0.3251 ] Sending mb1
02:04:24 INFO: Flash Jetson Linux - flash: [ 0.3273 ] Sending psc_bl1
02:04:24 INFO: Flash Jetson Linux - flash: [ 1.3350 ] Sending bct_mb1
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.4055 ] adding BCH for applet_t234_aligned.bin
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.4153 ] Assuming zero filled SBK key
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.4231 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.5882 ] Sending applet
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.7154 ] MB2 Applet version 01.00.0000
02:04:25 INFO: Flash Jetson Linux - flash: [ 1.9638 ] MB2 Applet version 01.00.0000
02:04:25 INFO: Flash Jetson Linux - flash: [ 2.0306 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
02:04:25 INFO: Flash Jetson Linux - flash: [ 2.0316 ] MB2 Applet version 01.00.0000
02:04:25 INFO: Flash Jetson Linux - flash: [ 2.1312 ] Chip minor revision: 1
02:04:25 INFO: Flash Jetson Linux - flash: [ 2.1315 ] Chip Sample: prod
02:04:25 INFO: Flash Jetson Linux - flash: [ 2.1588 ] MB2 Applet version 01.00.0000
02:38:06 INFO: Flash Jetson Linux - flash: [ 2023.1896 ] Usage: tegradevflash_v2 [–instance ] [–pt ]
02:38:06 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 33m44s ]
02:38:06 ERROR: Flash Jetson Linux - flash: command terminated with error
02:38:06 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
There are some errors in the console log (see below).
[0042.955] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0042.960] I> t234-A01-1-Silicon (0x12347) Prod
[0042.964] I> Boot-mode : BPMP Diagnostic
[0042.968] I> Entry timestamp: 0x00000000
[0042.972] I> last_boot_error: 0x0
[0042.975] I> BR-BCT: preprod_dev_sign: 0
[0042.979] I> rst_source: 0x0, rst_level: 0x0
[0042.983] I> Task: Initialize MB2 params
[0042.987] I> MB2-params @ 0x40060000
[0042.991] I> Task: Crypto init
[0042.994] I> Task: Perform MB1 KAT tests
[0042.998] I> Task: NVRNG health check
[0043.001] I> NVRNG: Health check success
[0043.005] I> Task: Secure debug controls
[0043.009] I> Task: strap war set
[0043.012] I> Task: Program NV master stream id
[0043.016] I> Task: Verify boot mode
[0043.022] I> Task: Alias fuses
[0043.025] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0043.032] I> Task: Print SKU type
[0043.035] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0043.040] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0043.045] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0043.049] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0043.053] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0043.057] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0043.062] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0043.066] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0043.071] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0043.075] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0043.079] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0043.083] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0043.087] I> FUSE_SKU_INFO_0 = 0xd5
[0043.091] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0043.095] I> FUSE_PACKAGE_INFO_0 = 0x2
[0043.098] I> SKU: Prod
[0043.101] I> Task: Boost clocks
[0043.104] I> Initializing NAFLL for BPMP_CPU_NIC.
[0043.109] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0043.114] I> BPMP NAFLL lock success.
[0043.118] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0043.122] I> Initializing PLLC2 for AXI_CBB.
[0043.126] I> AXI_CBB : src = 35, divisor = 0
[0043.130] I> Task: Voltage monitor
[0043.134] I> VMON: Vmon re-calibration and fine tuning done
[0043.139] I> Task: UPHY init
[0043.142] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0043.148] I> Task: Boot device init
[0043.151] I> Boot_device: RCM
[0043.154] I> USB configuration success
[0043.158] I> Task: TSC init
[0043.161] I> Task: Enable WDT 5th expiry
[0043.164] I> Task: I2C register
[0043.167] I> Task: Set I2C bus freq
[0043.171] I> Task: Reset FSI
[0043.173] I> Task: Enable clock-mon
[0043.177] I> FMON: Fmon re-programming done
[0043.182] I> Task: Mapper init
[0043.184] I> Task: MB1 fixed firewalls
[0043.191] W> Firewall readback mismatch
[0043.196] I> Task: Load MB2/Applet/FSKP
[0043.200] I> Loading MB2 Applet
[0043.203] I> Slot: 0
[0043.205] I> Binary[21] block-352321536 (partition size: 0x50000)
[0043.211] I> Binary name: MB2-Applet
[0043.214] I> Size of crypto header is 8192
[0043.218] I> Size of crypto header is 8192
[0043.222] I> BCH of MB2-Applet read from storage
[0043.227] I> BCH address is : 0x4004e000
[0043.231] I> MB2-Applet header integrity check is success
[0043.236] I> Binary magic in BCH component 0 is MB2A
[0043.241] I> component binary type is 21
[0043.244] I> Size of crypto header is 8192
[0043.284] I> MB2-Applet binary is read from storage
[0043.289] I> MB2-Applet binary integrity check is success
[0043.294] I> Binary MB2-Applet loaded successfully a4 0x40000000 (0x42440)
[0043.301] I> Task: Prepare MB2 params
[0043.305] I> Task: Misc NV security settings
[0043.309] I> NVDEC sticky bits programming done
[0043.314] I> Successfully powergated NVDEC
[0043.317] I> Task: Disable/Reload WDT
[0043.321] I> Task: Program misc carveouts
[0043.325] I> Task: Disable SCPM/POD reset
[0043.329] I> SLCG Global override status := 0x0
[0043.333] I> MB1: MSS reconfig completed
[0043.337] W> Firewall readback mismatch
[0043.341] W> Firewall readback mismatch
[0043.344] W> Firewall readback mismatch
[0043.348] W> Firewall readback mismatch
[0043.352] W> Firewall readback mismatch
[0043.355] W> Firewall readback mismatch
[0043.359] W> Firewall readback mismatch
[0043.363] W> Firewall readback mismatch
[0043.366] W> Firewall readback mismatch
[0043.370] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-b648c465)
I> Emulation:
I> Task: Pinmux init
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: SDMMC_BOOT instance: 3
E> Error in command_complete 18001 int_status
E> OCR failed, error = 39390706
E> STORAGE: Failed to open SDMMC: 3.
W> Ignoring init failure for device 0-3
I> Secondary storage device: SDMMC_USER instance: 3
E> Error in command_complete 18000 int_status
W> Ignoring init failure for device 1-3
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Register exit handlers
I> Task: Enter 3p server
I> Populate chip info
I> RAM_CODE 0x4000021
I> Populate eeprom info
DevKit/custom board?
L4T/JetPack version?
Export the log as a zip file from SDK Manager, please.
It’s custom board. Here is log of sdk.
sdkm-2024-05-05-19-40-09.zip (24.8 KB)
BSP from SDK Manager is only for DevKits.
Ask the vendor for help when you use custom boards.
I need your help.
what can I do for check?
I said, ask the vendor for help.
This board is not made by us so nothing we can check.
