Hi All,
I am working on JP5.1.1, and check AGX ORIN CSI camera CSI6/7.
Some topics refer to some bug at RCE firmware.
And I follow the step to update the firmware, then flash orin dev.
please note that, the latest JP-5 release is JetPack 5.1.3 (r35.5.0) which include several bug fixes.
why you stay-on JP-5.1.1 (r35.3.1) for development, is it feasible for moving to the latest release version for verification?
you might review your device tree settings since the failure has reported an invalid NVCSI stream ID.
please see-also Port Index section, even though there’re 8 CSI ports, it’s support up-to 6 streams for the VI.
please see-also Topic 69753 for more details of NVCSI/VI port-index.
for example,
if you had a sensor connect to CSI-G, the port-index device tree property should be indicate as below.
