While starting to use the AGX (3550) we are unable to perform the initial flash as the final step of the installation of the SDK.
The error is “cat: /dev/ttyUSB3: Resource temporarily unavailable”.
We tried with 2 different systems and with 2 different AGX targets. Same result.
What could be wrong?
Regards,
Marc.
09:42:24 INFO : Flash Xavier A+B in parallel :
09:42:24 INFO : Flash Xavier A+B in parallel : +++++++++++++++++++++++++++++++++++++++++++++++++
09:42:24 INFO : Flash Xavier A+B in parallel : Aurix Port = /dev/ttyUSB3
09:42:24 INFO : Flash Xavier A+B in parallel : Target rootfs will be flashed into emmc
09:42:24 INFO : Flash Xavier A+B in parallel : ./bootburn.sh -b e3550b03-t194 -B qspi -x /dev/ttyUSB3
09:42:24 INFO : Flash Xavier A+B in parallel : Execute Xavier Script
09:42:24 INFO : Flash Xavier A+B in parallel : Successfully acquired lock over /var/lock/LCK..bootburn
09:42:24 INFO : Flash Xavier A+B in parallel : Successfully acquired lock over /var/lock/LCK..ttyUSB3
09:42:24 INFO : Flash Xavier A+B in parallel : Read skuinfo from InfoRom...
09:42:25 ERROR : Flash Xavier A+B in parallel : cat: /dev/ttyUSB3: Resource temporarily unavailable
09:42:27 ERROR : Flash Xavier A+B in parallel : /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh: line 774: array: bad array subscript
09:42:27 INFO : Flash Xavier A+B in parallel : Disabling SIGINT temporarily
09:42:29 ERROR : Flash Xavier A+B in parallel : Setting Tegra-A on hold... cat: /dev/ttyUSB3
09:42:29 ERROR : Flash Xavier A+B in parallel : : Resource temporarily unavailable
09:42:40 INFO : Flash Xavier A+B in parallel : Could not execute command "tegrareset x1 h" on aurix. Log follows,
09:42:40 INFO : Flash Xavier A+B in parallel : ------------ Stack Trace ------------
09:42:40 INFO : Flash Xavier A+B in parallel : stack frame 0 - 287 AbnormalTermination /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
09:42:40 INFO : Flash Xavier A+B in parallel : stack frame 1 - 426 ExecuteAurixCommand /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh
09:42:40 INFO : Flash Xavier A+B in parallel : stack frame 2 - 452 GetTegrasAssocWithAurix /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh
09:42:40 INFO : Flash Xavier A+B in parallel : stack frame 3 - 511 CheckRecoveryTargets /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh
09:42:40 INFO : Flash Xavier A+B in parallel : stack frame 4 - 965 main /home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh
09:42:40 INFO : Flash Xavier A+B in parallel : -------------------------------------
09:42:40 INFO : Flash Xavier A+B in parallel : error-target-command
09:42:40 INFO : Flash Xavier A+B in parallel : bootburn flashing failed! error code = 15
09:42:40 INFO : Flash Xavier A+B in parallel : exit status 15
09:42:40 INFO : Flash Xavier A+B in parallel : [ Component Install Finished with Error ]
09:42:40 ERROR : Flash Xavier A+B in parallel : NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP command ./pdk_flash.sh -b e3550b03-t194-es finished with error
09:42:40 INFO : Flash Xavier A+B in parallel : [ 66.54 MB used. Disk Avail: 137.23 GB ]
09:42:40 INFO : Flash Xavier A+B in parallel : [ NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP Install took 21s ]
09:42:40 INFO : Flash Xavier A+B in parallel : command ./pdk_flash.sh -b e3550b03-t194-es finished with error
09:42:40 ERROR : Flash Xavier A+B in parallel : command terminated with error
09:42:40 ERROR : Flash Xavier A+B in parallel : install 'Flash Xavier A+B in parallel' failure, command < cd '/home/quintor/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW' ;
