Flash fails after modifying kernel version via menuconfig
I modified kernel configuration via menuconfig and added version string prefix.
Now my flash fails (JP 5.1.3)
log:
flash.log (17.1 KB)
flash script needs to retrieve the version using this command
BASE_KERNEL_VERSION="$(strings "${base_l4t_dir}/kernel/Image" | grep -oE "Linux version [0-9a-zA-Z\.\-]+[+]* " | cut -d\  -f 3)"
If you can modify the kernel so that the above command work then it would be ok.
Thank you for your answer.
  1. Where this variable is defined? can I modify the command to match my needs?
  2. I edit the version by simply adding a. so now the version is:
Linux version 5.10.192a-tegra
The problem is that now the boot fails. If I flash again without adding the ‘a’ char, the boot succeeds.
boot log:
failed_boot.log (123.5 KB)
It’s located in Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_make_recovery_img_dtb.sh.
Then what’s the issue now?
I don’t think something like 5.10.192a-tegra is allowed. It is causing the regular expression mentioned earlier to fail.
You can only add your custom suffix after the hyphen.
if i add only ‘a’ the strings command succeeds:
bsp@bsp-host:~/Desktop/Workspace_5_1_3/Linux_for_Tegra/kernel$ echo "$(strings “./Image” | grep -oE “Linux version [0-9a-zA-Z.-]+[+]* " )”
The problem is that if I flash the target it won’t boot (I attached the log)
P.S
If I add custom string after the hypen, strings command don’t find the version.
even though it exists:
bsp@bsp-host:~/Desktop/Workspace_5_1_3/Linux_for_Tegra/kernel$ echo “$(strings “./Image” )” | grep custom
Linux version 5.10.192-custom_string-tegra (root@bsp-host) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #4 SMP PREEMPT Wed Mar 27 11:07:22 IST 2024
5.10.192-custom_string-tegra SMP preempt mod_unload modversions aarch64
Anyway, it’s just a warning and you can turn off it.
It the new kernel is able to boot up then it’s fine.
its not booting up
I don’t think it’s a Jetson problem.
Like you can try the same thing on an x86 VM.
you say that on a VM, if i modify the kernel sting (add local version) via menuconfig, it won’t boot as well? like a common problem in Linux kernel itself? (sounds unlikely)
YES, you can do some experiments like that.
