Flashing fails at 99% showing write checkpoint and then stalls leading to failure. Here are the log files
SDKM_logs_2024-11-07_20-40-47.zip (424.1 KB)
Kindly help debug the issue.
Hi hbhat1,
From log
Info: mount.nfs: access denied by server while mounting
Try:
Disable the firewall setting on the host pc.
And refer to the doc to check whether dev kit in the recovery mode.
Run sdk again.
If the issue persists, try to dump the serial console log from device with this
Jetson Nano & NX Style – Serial Debug Console
Hi David,
Thanks for your reply. I have already disabled my firewall by running sudo ufw disable. For putting the jetson on Recovery mode I long pressed the middle button+power button, plug in USB-C power and then connected to my host ubuntu computer. Upon checking lsusb I could see the Nvidia Corp. stuff. Let me try reproducing the serial console logs.
I can confirm over here that it is running in recovery mode based on that document. Let me know if you need more logs
here is the output after checking the mount:
(base) hive@integration-assembly:~$ ls -a /home/hive/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/
apply_binaries.sh
bootloader
build_l4t_bup.sh
clara-agx-xavier-devkit.conf
e3900-0000+p2888-0004-b00.conf
flash.sh
generate_capsule
holoscan-devkit.conf
igx-orin-devkit.conf
jetson_additional_board_spec.cfg
jetson-agx-orin-devkit-as-jao-32gb.conf
jetson-agx-orin-devkit-as-nano4gb.conf
jetson-agx-orin-devkit-as-nano8gb.conf
jetson-agx-orin-devkit-as-nx-16gb.conf
jetson-agx-orin-devkit-as-nx-8gb.conf
jetson-agx-orin-devkit.conf
jetson-agx-orin-devkit-industrial.conf
jetson-agx-orin-devkit-industrial-maxn.conf
jetson-agx-orin-devkit-maxn.conf
jetson-agx-xavier-devkit.conf
jetson-agx-xavier-ind-noecc.conf
jetson-agx-xavier-industrial.conf
jetson-agx-xavier-industrial-mxn.conf
jetson_board_spec.cfg
jetson-orin-nano-devkit.conf
jetson-orin-nano-devkit-nvme.conf
jetson-xavier.conf
jetson-xavier-maxn.conf
jetson-xavier-nx-devkit.conf
jetson-xavier-nx-devkit-emmc.conf
jetson-xavier-nx-devkit-qspi.conf
jetson-xavier-slvs-ec.conf
kernel
l4t_generate_soc_bup.sh
l4t_sign_image.sh
l4t_uefi_sign_image.sh
nvautoflash.sh
nvmassfusegen.sh
nvsdkmanager_flash.sh
nv_tegra
nv_tools
odmfuse.func
odmfuseread.sh
odmfuse.sh
p2822-0000+p2888-0001.conf
p2822-0000+p2888-0004.conf
p2822-0000+p2888-0008.conf
p2822-0000+p2888-0008-maxn.conf
p2822-0000+p2888-0008-noecc.conf
p2972-0000.conf.common
p2972-0000-devkit-maxn.conf
p2972-0000-devkit-slvs-ec.conf
p2972.conf
p3449-0000+p3668-0000-qspi-sd.conf
p3449-0000+p3668-0001-qspi-emmc.conf
p3509-0000+p3668-0000-qspi.conf
p3509-0000+p3668-0000-qspi-sd.conf
p3509-0000+p3668-0001-qspi-emmc.conf
p3509-a02+p3767-0000.conf
p3509-a02+p3767-0000-maxn.conf
p3668.conf.common
p3701.conf.common
p3711-0000+p3701-0002.conf
p3737-0000+p3701-0000-as-p3701-0004.conf
p3737-0000+p3701-0000-as-p3767-0000.conf
p3737-0000+p3701-0000-as-p3767-0001.conf
p3737-0000+p3701-0000-as-p3767-0003.conf
p3737-0000+p3701-0000-as-p3767-0004.conf
p3737-0000+p3701-0000.conf
p3737-0000+p3701-0000-maxn.conf
p3737-0000+p3701-0008.conf
p3737-0000+p3701-0008-maxn.conf
p3740-0002-b00+p3701-0002.conf
p3740-0002-b01+p3701-0002.conf
p3740-0002-b01+p3701-0002-dgpu-efifb.conf
p3740-0002-c01+p3701-0008.conf
p3740-0002-c01+p3701-0008-dgpu-efifb.conf
p3767.conf.common
p3768-0000+p3767-0000.conf
p3768-0000+p3767-0000-maxn.conf
p3768-0000+p3767-0000-nvme.conf
README_Autoflash.txt
rootfs
source
source_sync.sh
Tegra_Software_License_Agreement-Tegra-Linux.txt
tools
(base) hive@integration-assembly:~$ showmount -e
Export list for integration-assembly:
/srv/nfs/jetson *
(base) hive@integration-assembly:~$ sudo systemctl status nfs-kernel-server
● nfs-server.service - NFS server and services
Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor pr>
Active: active (exited) since Fri 2024-11-08 19:15:38 GMT; 13min ago
Process: 44750 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SU>
Process: 44751 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, stat>
Main PID: 44751 (code=exited, status=0/SUCCESS)
Nov 08 19:15:37 integration-assembly systemd[1]: Starting NFS server and servic>
Nov 08 19:15:38 integration-assembly systemd[1]: Finished NFS server and servic>
(base) hive@integration-assembly:~$ sudo blkid
/dev/nvme0n1p2: UUID="2fa8fee2-a328-404b-b1a7-e6ddc187f632" TYPE="ext4" PARTUUID="2ddd39b9-fe77-4cb0-a8b3-909b6f4fae37"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/nvme0n1p1: UUID="7695-CC9C" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="d3af6295-7d89-4ff4-9cf6-ccec1125fa21"
/dev/loop9: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
/dev/loop23: TYPE="squashfs"
/dev/loop22: TYPE="squashfs"
/dev/loop20: TYPE="squashfs"
/dev/loop21: TYPE="squashfs"
/dev/loop19: TYPE="squashfs"
/dev/loop25: TYPE="squashfs"
/dev/loop24: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop18: TYPE="squashfs"
/dev/loop26: TYPE="squashfs"
/dev/loop27: TYPE="squashfs"
(base) hive@integration-assembly:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 16G 0 16G 0% /dev
tmpfs 3.2G 2.3M 3.2G 1% /run
/dev/nvme0n1p2 468G 202G 243G 46% /
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/loop0 128K 128K 0 100% /snap/bare/5
/dev/loop1 105M 105M 0 100% /snap/core/17200
/dev/loop3 64M 64M 0 100% /snap/core20/2318
/dev/loop4 75M 75M 0 100% /snap/core22/1439
/dev/loop6 56M 56M 0 100% /snap/core18/2829
/dev/loop7 219M 219M 0 100% /snap/gnome-3-34-1804/93
/dev/loop8 576M 576M 0 100% /snap/obs-studio/1302
/dev/loop13 576M 576M 0 100% /snap/obs-studio/1299
/dev/loop10 131M 131M 0 100% /snap/docker/2915
/dev/loop12 183M 183M 0 100% /snap/postman/287
/dev/loop11 486M 486M 0 100% /snap/gnome-42-2204/126
/dev/loop14 41M 41M 0 100% /snap/snapd/20092
/dev/loop20 39M 39M 0 100% /snap/snapd/21759
/dev/loop21 92M 92M 0 100% /snap/gtk-common-themes/1535
/dev/loop23 132M 132M 0 100% /snap/docker/2932
/dev/loop25 13M 13M 0 100% /snap/snap-store/1113
/dev/loop16 174M 174M 0 100% /snap/postman/266
/dev/loop19 347M 347M 0 100% /snap/gnome-3-38-2004/119
/dev/loop17 506M 506M 0 100% /snap/gnome-42-2204/176
/dev/loop22 350M 350M 0 100% /snap/gnome-3-38-2004/143
/dev/loop15 82M 82M 0 100% /snap/gtk-common-themes/1534
/dev/loop24 13M 13M 0 100% /snap/snap-store/959
/dev/loop18 219M 219M 0 100% /snap/gnome-3-34-1804/77
/dev/nvme0n1p1 511M 5.3M 506M 2% /boot/efi
tmpfs 3.2G 88K 3.2G 1% /run/user/1002
/dev/loop26 56M 56M 0 100% /snap/core18/2846
/dev/loop27 64M 64M 0 100% /snap/core20/2434
/dev/loop9 74M 74M 0 100% /snap/core22/1663
/dev/loop2 67M 67M 0 100% /snap/core24/609
/dev/loop5 10M 10M 0 100% /snap/nmap/3582
Hi hbhat1,
To gather more information, please answer the following questions:
- Is your host machine a virtual machine or a physical device?
- Is your device a dev kit or a custom carrier board?
Additionally, please capture and share the serial console log during the flashing process. Also, provide the SDK export log as well.
Hi David,
- I’m using Ubuntu 20.04 physical host
- The board is a devkit not a custom carrier board.
I will try to capture serial console logs. The above logs I provided are logs which it generates after flash fails. Do you have other process to export the SDK logs?
Cannot seem to recognize the minicom mentioned in the article for collecting logs.
hive@integration~$ minicom -D /dev/ttyACM0 -8 -b 115200
minicom: cannot open /dev/ttyACM0: No such file or directory
hive@integration:~$ sudo adduser $USER dialout
The user `hive' is already a member of `dialout'.
The SDK manager detects the AGX board but not seen by minicom. Could you help me with understanding why is this issue?
PFA, the SDK manager logs requested:
SDKM_logs_2024-11-12_17-07-12.zip (533.4 KB)
Minicom logs are not available as minicom cannot detect the usb connection
With the log provided,
16:57:06.974 - Info: [ 0.3384 ] Sending bct_br
16:57:12.142 - Info: [ 0.3857 ] ERROR: might be timeout in USB write.
Please try the following steps:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
And run the sdk manager again
Regarding Minicom, try running dmesg
command after plugging in the USB to check for any related information. Alternatively, try using a different cable to connect.
with dmesg, I can see nvidia detected but minicom cannot get any ttyUSB0 or ttyACM0. Is there any alternative to collecting serial console logs?
You have to connect the micro usb port on the Orin AGX devkit so that it will give you a ttyXXX on host PC to get the log.
