I am trying to Flash my Nvidia Jetson Xavier Agx Developper kit.
Unfortunently I get an error while trying to flash the device. I have tried several times but the smae problem seems to occur.
I am using Ubuntu 18.04
This is the main error message I get :
“Error in local apt settings”
there’s SDKManager update recently, did you upgrade to the latest release version?
BTW, could you please deselect JetPack SDK components to only installing Jetpack release image for confirmation.
thanks
there’s JetPack release download to your local host, could you please perform flash script to flash the image manually.
for example, ~/nvidia/nvidia_sdk/JetPack_<version>_<platform>/Linux_for_Tegra/
you may also check Basic Flash Script Usage for the commands to flash the target, thanks
It tried the command you suggested ( $ sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1), unfortunately the program seems to freeze at some point again.
Here is the terminal output : flash_mmcblk0p1.txt (51.2 KB)
In general how much time does the flash procedure take ? To know how long it should let the program running before knowing for sure that it has failed.
After I interrupted the program I get this messages in the terminal :
^CTraceback (most recent call last):
File “./tegraflash.py”, line 1296, in
tegraflash_run_commands()
File “./tegraflash.py”, line 1155, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.6/cmd.py”, line 217, in onecmd
return func(arg)
File “./tegraflash.py”, line 216, in do_flash
tegraflash_flash(exports)
File “/home/sebastien/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 269, in tegraflash_flash
tegraflash_send_tboot(tegrarcm_values[‘–signed_list’])
File “/home/sebastien/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2463, in tegraflash_send_tboot
uidlog = run_command(command, True)
File “/home/sebastien/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 202, in run_command
log = print_process(process, enable_print)
File “/home/sebastien/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 161, in print_process
output = process.stdout.read(1)
KeyboardInterrupt
Failed flashing t186ref.
the board communication should return within a second, then you’ll see the image creation and burning process, finally, reboot the board into ubuntuOS.
may I know what’s your environment setups? for example, are you using a virtual machine? is it a Laptop or desktop?
I am using a laptop. I am using a virtual machine running Ubuntu (64-bit) version 18.04.
I got the virtual machine through the Oracle VM VirtualBox virtualisation tool.
this looks just like usb port forwarding issue, which usually related to your environment setups.
please try with native ubuntuOS as your x86 flashing machine environment, for the laptop platform, you should always have power-supply connected, may also try other usb ports for device connection.
