I want to reflash a Jetson Orin Nano with Jetpack 6.2
Host Machine OS: Ubuntu 20.04
I was following this guide. Everything worked fine unitl flashing.
18:41:57 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition /dev/nvme0n1p6: 64.76 GB ]
18:41:57 INFO: Flash Jetson Linux - flash: Installing component 'Flash Jetson Linux' (NV_L4T_FLASH_JETSON_LINUX_COMP)
18:41:57 INFO: Flash Jetson Linux - flash: change working directory to /home/sasika/Downloads/jetson_new/folder2/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
18:41:57 INFO: Flash Jetson Linux - flash: [ Component Install Started ]
18:41:57 INFO: Flash Jetson Linux - flash: current working directory is /home/sasika/Downloads/jetson_new/folder2/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
18:41:57 INFO: Flash Jetson Linux - flash: exec_command [host]:
18:41:57 INFO: Flash Jetson Linux - flash: **********************
18:41:57 INFO: Flash Jetson Linux - flash: set -e
18:41:57 INFO: Flash Jetson Linux - flash: unset LC_ALL
18:41:57 INFO: Flash Jetson Linux - flash: FlashOptions=$(echo "--storage nvme0n1p1" | sed s/mmcblk1p1/mmcblk0p1/)
18:41:57 INFO: Flash Jetson Linux - flash: echo sudo ./nvsdkmanager_flash.sh $FlashOptions
18:41:57 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh $FlashOptions
18:41:57 INFO: Flash Jetson Linux - flash: sleep 20
18:41:57 INFO: Flash Jetson Linux - flash: if [[ '--storage nvme0n1p1' == *'--nv-auto-config'* ]]; then
18:41:57 INFO: Flash Jetson Linux - flash: sleep 40
18:41:57 INFO: Flash Jetson Linux - flash: fi
18:41:57 INFO: Flash Jetson Linux - flash: exec_command: /home/sasika/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh
18:41:58 INFO: Flash Jetson Linux - flash: *** Reading EEPROM ... "/home/sasika/Downloads/jetson_new/folder2/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x23 --applet "/home/sasika/Downloads/jetson_new/folder2/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --skipuid --cmd "dump eeprom cvm cvm.bin; reboot recovery"
18:41:58 INFO: Flash Jetson Linux - flash: Welcome to Tegra Flash
18:41:58 INFO: Flash Jetson Linux - flash: version 1.0.0
18:41:58 INFO: Flash Jetson Linux - flash: Type ? or help for help and q or quit to exit
18:41:58 INFO: Flash Jetson Linux - flash: Use ! to execute system commands
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0161 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0168 ] File rcm_state open failed
18:41:58 ERROR: Flash Jetson Linux - flash: [ 0.0171 ] ERROR: failed to read rcm_state
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0171 ]
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0180 ] tegrasign_v3.py --key None --getmode mode.txt
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0175 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0248 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0337 ] Parsing partition layout
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0785 ] adding BCH for mb2_t234_aligned.bin
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0960 ] Filling MB1 storage info
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.0961 ] Parsing dev params for multi chains
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1029 ] Generating br-bct
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1330 ] WARNING: boot chain is not completed. set to 0
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1491 ] Offset :4608 Len :3584
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1497 ] Generating SHA2 Hash
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1507 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1511 ] Assuming zero filled SBK key
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1609 ] Offset :68 Len :8124
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1872 ] Generating recovery mb1-bct
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1886 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1900 ] MB1-BCT version: 0.13
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1935 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1939 ] Added Platform Config 9 data with size :- 100
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1939 ] Updating mb1-bct with firmware information
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1954 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.1987 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2001 ] Generating SHA2 Hash for mb1bct
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2038 ] Sha saved in mb1_bct_MB1_aligned.sha
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2071 ] Sha saved in mb1_bct_MB1.sha
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2079 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2093 ] adding BCH for mb1_bct_MB1_aligned.bct
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2116 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2148 ] Warning: pub_key.key is not found
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2155 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2179 ] Info: Skip generating mem_bct because sdram_config is not defined
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2179 ] Copying signatures
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2194 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2280 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2283 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2283 ] Boot Rom communication
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2298 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2313 ] BR_CID: 0x80012344705DD7D97400000003018240
18:41:58 INFO: Flash Jetson Linux - flash: [ 0.2628 ] Sending bct_br
18:42:08 ERROR: Flash Jetson Linux - flash: [ 0.3061 ] ERROR: might be timeout in USB write.
18:42:08 ERROR: Flash Jetson Linux - flash: Error: Return value 3
18:42:08 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
18:42:08 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
18:42:08 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
18:42:08 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/sasika/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: *** ERROR: Parsing boardid failed
18:42:08 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
18:42:08 INFO: Flash Jetson Linux - flash: [host] [ 93.65 MB used. Disk Avail on Partition /dev/nvme0n1p6: 64.67 GB ]
18:42:08 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 11s ]
18:42:08 ERROR: Flash Jetson Linux - flash: command terminated with error
18:42:08 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
This is the error that I got. I cannot figure out what this error message is telling. Could you please help me on how to correctly reflash the jetson orin nano. Thank you in advance! (Please consider the fact that I am new to working with jetson devices)
The Error Log files
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_8GB_2025-03-01_17-08-52.zip (51.4 KB)
