Flash issue: INSTALLATION FAILED
19:12:30 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.7.0-1_all.deb with correct checksum, skip downloading.
19:12:30 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/racobit/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.8.0-1_all.deb
19:12:30 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.8.0-1_all.deb with correct checksum, skip downloading.
19:12:30 INFO: Multimedia API - target: verifying checksum of /home/racobit/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.7.3-20221122092958_arm64.deb
19:12:31 INFO: Multimedia API - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.7.3-20221122092958_arm64.deb with correct checksum, skip downloading.
19:12:31 INFO: Nsight Systems CLI - target: verifying checksum of /home/racobit/Downloads/nvidia/sdkm_downloads/nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b_2021.5.4.19-1_arm64.deb
19:12:31 INFO: Nsight Systems CLI - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b_2021.5.4.19-1_arm64.deb with correct checksum, skip downloading.
19:12:31 INFO: TensorRT on Target - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.2.1-1+cuda10.2_all.deb with correct checksum, skip downloading.
19:12:31 INFO: CUDA Toolkit for L4T - target: Found file /home/racobit/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
19:12:43 INFO: Device info before flashing: Jetson TX2 NX | 001/006 | 1-1 | Recovery
19:12:43 DEBUG: running command < true >
19:12:43 INFO: exec_command: true
19:12:43 INFO: command finished successfully
19:12:43 DEBUG: running command < /tmp/device_mode_host_setup.sh >
19:12:43 INFO: exec_command: /tmp/device_mode_host_setup.sh
19:12:43 INFO: Found route default ens33, setting up device mode
19:12:43 INFO: [host] [sudo] password for racobit:
19:12:43 INFO: net.ipv4.ip_forward = 1
19:12:43 INFO: Device mode on host successfully set with DNS 8.8.8.8!
19:12:43 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/racobit/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS
19:12:43 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
19:12:43 INFO: Flash Jetson TX2 - flash: sudo ./nvsdkmanager_flash.sh --nv-auto-config --username racobit
19:12:43 INFO: Flash Jetson TX2 - flash: [OEMPreconfig] SDKM_INSTALL_ERROR Password for L4T new user racobit:
19:12:43 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode ... OK.
19:12:43 INFO: Flash Jetson TX2 - flash: *** Checking target board connection ... 1 connections found.
19:12:43 INFO: Flash Jetson TX2 - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
19:12:43 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM ... "/home/racobit/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x18 --applet "/home/racobit/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery"
19:12:43 INFO: Flash Jetson TX2 - flash: [ 0.0038 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/racobit/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
19:12:43 INFO: Flash Jetson TX2 - flash: [ 0.0078 ] Assuming zero filled SBK key
19:12:43 INFO: Flash Jetson TX2 - flash: [ 0.0264 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
19:12:43 INFO: Flash Jetson TX2 - flash: [ 0.0314 ] RCM version 0X180001
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.0554 ] Applet version 01.00.0000
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.1212 ] Applet version 01.00.0000
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.1798 ] Saved platform info in /home/racobit/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.3195 ] RCM 1 is saved as rcm_1.rcm
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.3218 ] Assuming zero filled SBK key
19:12:45 INFO: Flash Jetson TX2 - flash: [ 2.3407 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
19:12:51 INFO: Flash Jetson TX2 - flash: [ 2.3425 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
19:12:52 INFO: Flash Jetson TX2 - flash: [ 8.5791 ] Applet version 01.00.0000
19:12:52 INFO: Flash Jetson TX2 - flash: [ 8.6458 ] Applet version 01.00.0000
19:12:52 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 17: invalid start byte
19:12:52 ERROR: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
19:12:52 ERROR: Flash Jetson TX2 - flash: command terminated with error
19:12:52 SUMMARY: DateTime Target Setup - target: Depends on failed componentPreformatted text
On your host PC, what do you see from “echo $LANG”?
en_US.UTF-8
The environment probably is not the cause. What was the exact command producing the error? Or was it from an sdkmanager install of the item? Regardless, you’ll need to state which JetPack and/or L4T release is involved.
