Flash JetPack 7.2 into Jetson Orin Nano Developer Kit microSD card issue
Hi all,
I currently have three Jetson Orin Nano Developer Kits. I followed the Quick Start Guide to install the system:
Quick Start Guide — Jetson Orin Nano Developer Kit - User Guide
I downloaded Jetson r39.2, created a Jetson ISO USB installer, upgraded the QSPI firmware, and used the USB device to flash a 64GB microSD card.
However, only one device was installed successfully. The other two devices have issues. Basically, the installation process goes to the end successfully, but on the two failed devices, I cannot see the Ubuntu setup pages after reboot.
By the way, the QSPI firmware has been upgraded as mentioned in the guide.
After reboot, in the Boot Manager, I can see the SD card. After I select it, the screen turns black, and after 1–2 seconds it returns to the Boot Manager. I retried the installation process several times, but the issue remains.
I also selected the UEFI Shell, and the information shown there is different between the successfully installed device and the failed devices, as shown below. I am not sure what this means.
Additional information is also attached below.
Firmware:39.2.0-gcid-45755727
What should be the next step? Could someone please help?
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, it seems that the issue lies in the boot process after flashing the microSD card with JetPack 7.2. The successfully installed device and the failed devices show different information in the UEFI Shell, which might indicate a problem with the boot configuration or the QSPI firmware update.
To troubleshoot this issue, you can try the following steps:
  1. Verify that the QSPI firmware has been updated correctly on the failed devices. Check the firmware version in the Boot Manager or the UEFI Shell to ensure it matches the version on the successfully installed device.
  2. Check the boot configuration on the failed devices. You can try to boot with the Install Jetson ISO r39.2 option in the Boot Manager and see if it completes the installation process.
  3. If the issue persists, try to reflash the microSD card with JetPack 7.2 and repeat the installation process.
  4. If none of the above steps resolve the issue, you can try to use the SDK Manager to flash the device, as mentioned in the Initial Setup Guide.
It’s also recommended to check the serial console log for any error messages or clues that might indicate the cause of the issue.
What is not covered in this response is the specific cause of the issue or a detailed analysis of the UEFI Shell output. Further investigation and troubleshooting may be required to resolve the issue.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Please try this and see if you can boot to Ubuntu desktop:
If yes, please try the ISO image again.
If not, we would suggest re-flash the developer kit through Ubuntu host. The steps are in
Thanks for your quick reply.
I tried the suggested workaround, but the issue still persists.
In my case, the display does not show a noise screen. After selecting the SD card in Boot Manager, the screen turns black for about 1–2 seconds and then returns to Boot Manager. I still cannot reach the Ubuntu setup page.
This issue happens on two Jetson Orin Nano Developer Kits, while the same ISO USB installer and the same installation steps work successfully on another identical kit.
Could you please confirm whether this looks like a bootloader / EFI / QSPI / SD boot issue rather than a display issue?
I will try reflashing through an Ubuntu host as suggested. Before doing that, could you please confirm the recommended flashing command for Jetson Orin Nano Developer Kit with Jetson Linux r39.2 / JetPack 7.2?
Also, is there any log from the UEFI Shell or serial console that you would like me to collect before reflashing?
I follow solution2, Quick Start — NVIDIA Jetson Linux Developer Guide.
Under Force Recovery Mode, reflash SD card, issue solved.
very appreciate for your great help!
Thank you for your feedback.
Please mark the solution so could close the topics.
