1.txt (94.9 KB)
Hi, can I ask, what could be causing the firmware flashing of Jetpack 7.2 to fail on this board(Jetson AGX Orin 64G)?
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, I found a few potential causes for the flashing failure of Jetpack 7.2 on the Jetson AGX Orin 64G board.
Unsupported JetPack version: In Topic #263037, it is mentioned that AGX Orin 64GB is not supported by JetPack 5.0.2, and the user is advised to use either 5.1.1 or 5.1.2. Although this is not directly related to JetPack 7.2, it’s possible that the issue is related to version compatibility. However, I couldn’t find any information in the provided context that specifically mentions JetPack 7.2 compatibility with the Jetson AGX Orin 64G board.
EEPROM corruption: In Topic #296825, the user experiences a flashing failure due to EEPROM corruption. The solution involves using the
flash.shscript with specific parameters to flash the board and then correcting the checksum bit in the EEPROM usingi2cset. This might be a potential cause for the flashing failure, but I couldn’t find any information in the provided context that specifically mentions EEPROM corruption in the context of JetPack 7.2. -
USB connection issues: In Topic #307341, the user experiences USB-related errors during the flashing process. The solution involves trying different USB cables, connecting via a USB hub, and connecting directly to a USB port on the computer. This might be a potential cause for the flashing failure, but I couldn’t find any information in the provided context that specifically mentions USB connection issues in the context of JetPack 7.2.
To further troubleshoot the issue, I would recommend checking the flashing logs for any specific error messages that might indicate the cause of the failure. Additionally, ensuring that the board is properly connected and configured, and trying different USB cables or connections might help resolve the issue.
I couldn’t find clear support for the specific cause of the flashing failure in the provided Jetson AGX Orin documentation. If you have any further information or logs from the flashing process, I might be able to provide more specific guidance.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Please also record the serial console log during flashing.
1.txt (94.9 KB)
Thanks ~0812
This is not a serial console log. please upload again.
