Flash jetpack7.2 success on eMMC but it failed when I try to flash to nvme!
Hi, there:
I can flash the jetpack 7.2 to eMMC successfully.
Later I try to flash to a 2TB Samsung nvme it hangs at waiting for bootup.
Any idea!
This is my trace!
[0114.015] I> MB1 (version: 1.0.1.17-t234-54845784-9b0d5809)
[0114.020] I> t234-A01-1-Silicon (0x12347) Prod
[0114.024] I> Boot-mode : BPMP Diagnostic
[0114.028] I> Entry timestamp: 0x00000000
[0114.032] I> last_boot_error: 0x0
[0114.035] I> BR-BCT: preprod_dev_sign: 0
[0114.039] C> rst_source: 0xb, rst_level: 0x1
[0114.043] I> Task: Initialize MB2 params
[0114.047] I> MB2-params @ 0x40060000
[0114.050] I> Task: Crypto init
[0114.053] I> Task: Perform MB1 KAT tests
[0114.057] I> Task: NVRNG health check
[0114.061] I> NVRNG: Health check success
[0114.064] I> Task: Check ECID against ECID in fuses
[0114.069] I> Task: Secure debug controls
[0114.073] I> Task: strap war set
[0114.076] I> Task: Program NV master stream id
[0114.080] I> Task: Verify boot mode
[0114.086] I> Task: Alias fuses
[0114.090] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0114.097] I> Task: Print SKU type
[0114.100] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0114.105] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0114.109] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0114.114] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0114.118] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0114.122] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0114.127] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0114.131] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0114.135] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0114.140] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0114.144] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0114.148] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0114.152] I> FUSE_SKU_INFO_0 = 0xd0
[0114.155] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0114.160] I> FUSE_PACKAGE_INFO_0 = 0x2
[0114.163] I> SKU: Prod
[0114.165] I> Task: Boost clocks
[0114.168] I> Initializing NAFLL for BPMP_CPU_NIC.
[0114.174] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0114.179] I> BPMP NAFLL lock success.
[0114.182] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0114.187] I> Initializing PLLC2 for AXI_CBB.
[0114.191] I> AXI_CBB : src = 35, divisor = 0
[0114.195] I> Task: Voltage monitor
[0114.199] I> VMON: Vmon re-calibration and fine tuning done
[0114.204] I> Task: UPHY init
[0114.207] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0114.213] I> Task: Boot device init
[0114.216] I> Boot_device: RCM
[0114.219] I> USB configuration success
[0114.223] I> Task: TSC init
[0114.226] I> Task: Enable WDT 5th expiry
[0114.229] I> Task: I2C register
[0114.232] I> Task: Set I2C bus freq
[0114.236] I> Task: Reset FSI
[0114.239] I> FSI Reset successful
[0114.242] I> Task: Enable clock-mon
[0114.256] I> FMON: Fmon re-programming done
[0114.260] I> Task: Mapper init
[0114.263] I> Task: MB1 fixed firewalls
[0114.268] I> Task: Load MB2/Applet/FSKP
[0114.272] I> Loading MB2 Applet
[0114.275] I> Chain: 0
[0114.277] I> Binary[21] block-352321536 (partition size: 0x50000)
[0114.283] I> Binary name: MB2-Applet
[0114.287] I> Size of crypto header is 8192
[0114.291] I> Size of crypto header is 8192
[0114.295] I> BCH of MB2-Applet read from storage
[0114.299] I> BCH address is : 0x4004e000
[0114.303] I> component binary type is 21
[0114.307] I> MB2-Applet header integrity check is success
[0114.312] I> Binary magic in BCH component 0 is MB2A
[0114.317] I> component binary type is 21
[0114.321] I> Size of crypto header is 8192
[0114.325] I> component binary type is 21
[0114.355] I> MB2-Applet binary is read from storage
[0114.360] I> MB2-Applet binary integrity check is success
[0114.365] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x42680)
[0114.372] I> Task: Prepare MB2 params
[0114.376] I> Task: Misc NV security settings
[0114.381] I> NVDEC sticky bits programming done
[0114.385] I> Successfully powergated NVDEC
[0114.389] I> Task: Disable/Reload WDT
[0114.392] I> Task: Disable SCPM/POD reset
[0114.396] I> SLCG Global override status := 0x0
[0114.401] I> MB1: MSS reconfig completed
I> Applet (version: 0.0.0.0-t234-54845784-a13d47e4)
I> Emulation:
I> Task: Pinmux init
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI Flash: Macronix 64MB at index: 5
I> QSPI-0l initialized successfully
I> Secondary storage device: SDMMC_BOOT instance: 3
I> sdmmc DDR50 mode
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc bdev is already initialized
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Register exit handlers
I> Task: Enter 3p server
I> Reading fuses
I> Read fuse successfully
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Populate chip info
C> RAM_CODE 0x3
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> command: dump sub-command: 0
I> dump bct
I> BRBCT integrity check is success
I> Validation passed for 1 copy of BRBCT @ 0
I> Rebooting : reboot-recovery
[0316.332] I> MB1 (version: 1.0.1.17-t234-54845784-9b0d5809)
[0316.337] I> t234-A01-1-Silicon (0x12347) Prod
[0316.341] I> Boot-mode : Coldboot
[0316.345] I> Entry timestamp: 0x00000000
[0316.348] I> last_boot_error: 0x0
[0316.352] I> BR-BCT: preprod_dev_sign: 0
[0316.355] C> rst_source: 0xb, rst_level: 0x1
[0316.359] I> Total boot-chains: 2 Active-chain: 0|A - BR-BCT based selection
[0316.367] I> Default chain: 0|A
[0316.370] I> Task: SE error check
[0316.373] I> Task: Bootchain select WAR set
[0316.377] I> Task: Update Boot chain markers
[0316.381] I> Task: Send error information to MCU
[0316.385] I> Task: Enable SLCG
[0316.388] I> Task: CRC check
[0316.391] I> Task: Initialize MB2 params
[0316.395] I> MB2-params @ 0x40060000
[0316.399] I> Task: Crypto init
[0316.402] I> Task: Perform MB1 KAT tests
[0316.406] I> Task: NVRNG health check
[0316.409] I> NVRNG: Health check success
[0316.413] I> Task: Check ECID against ECID in fuses
[0316.418] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0316.424] I> Task: Enabling and initialization of Bandwidth limiter
[0316.430] I> No request to configure MBWT settings for any PC!
[0316.435] I> Task: Secure debug controls
[0316.439] I> Task: strap war set
[0316.442] I> Task: Initialize SOC Therm
[0316.446] I> Task: Program NV master stream id
[0316.450] I> Task: Verify boot mode
[0316.456] I> Task: Alias fuses
[0316.459] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0316.466] I> Task: Print SKU type
[0316.470] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0316.475] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0316.479] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0316.483] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0316.488] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0316.492] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0316.496] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0316.501] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0316.505] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0316.509] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0316.514] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0316.518] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0316.522] I> FUSE_SKU_INFO_0 = 0xd0
[0316.525] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0316.529] I> FUSE_PACKAGE_INFO_0 = 0x2
[0316.533] I> SKU: Prod
[0316.535] I> Task: Boost clocks
[0316.538] I> Initializing NAFLL for BPMP_CPU_NIC.
[0316.543] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0316.549] I> BPMP NAFLL lock success.
[0316.552] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0316.557] I> Initializing PLLC2 for AXI_CBB.
[0316.561] I> AXI_CBB : src = 35, divisor = 0
[0316.565] I> Task: Voltage monitor
[0316.568] I> VMON: Vmon re-calibration and fine tuning done
[0316.574] I> Task: UPHY init
[0316.579] I> HSIO UPHY init done
[0316.582] W> Skipping GBE UPHY config
[0316.585] I> Task: Boot device init
[0316.589] I> Boot_device: RCM
[0316.592] I> USB configuration success
[0316.610] I> Task: TSC init
[0316.613] I> Task: Load membct
[0316.616] I> RAM_CODE 0x4000031
[0316.619] I> Loading MEMBCT
[0316.622] I> Chain: 0
[0316.624] I> Binary[0] block-0 (partition size: 0x40000)
[0316.629] I> Binary name: MEM-BCT-0
[0316.632] I> Size of crypto header is 8192
[0316.636] I> Size of crypto header is 8192
[0316.640] I> BCH of MEM-BCT-0 read from storage
[0316.645] I> BCH address is : 0x40050000
[0316.649] I> component binary type is 0
[0316.652] I> MEM-BCT-0 header integrity check is success
[0316.658] I> Binary magic in BCH component 0 is MEM0
[0316.662] I> component binary type is 0
[0316.666] I> component binary type is 0
[0316.689] I> MEM-BCT-0 binary is read from storage
[0316.694] I> MEM-BCT-0 binary integrity check is success
[0316.699] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0316.705] I> RAM_CODE 0x4000031
[0316.711] I> RAM_CODE 0x4000031
[0316.714] I> Task: Load Page retirement list
[0316.718] I> Task: SDRAM params override
[0316.722] I> Task: Save mem-bct info
[0316.726] E> GPCDMA: TZ to non-TZ or vice versa memcpy using DMA is not supported.
[0316.734] E> GPCDMA: Failed DMA xfer.
[0316.739] E> GPCDMA: TZ to non-TZ or vice versa memcpy using DMA is not supported.
[0316.747] E> GPCDMA: Failed DMA xfer.
[0316.750] I> Task: Carveout allocate
[0316.754] I> Update CCPLEX IST carveout from MB1-BCT
[0316.758] I> ECC region[0]: Start:0x0, End:0x0
[0316.763] I> ECC region[1]: Start:0x0, End:0x0
[0316.767] I> ECC region[2]: Start:0x0, End:0x0
[0316.771] I> ECC region[3]: Start:0x0, End:0x0
[0316.776] I> ECC region[4]: Start:0x0, End:0x0
[0316.780] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0316.786] I> Non-ECC region[1]: Start:0x0, End:0x0
[0316.790] I> Non-ECC region[2]: Start:0x0, End:0x0
[0316.795] I> Non-ECC region[3]: Start:0x0, End:0x0
[0316.800] I> Non-ECC region[4]: Start:0x0, End:0x0
[0316.810] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0316.818] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0316.825] I> allocated(CO:28) base:0x103c000000 size:0x4000000 align: 0x2000000
[0316.832] I> allocated(CO:43) base:0x1038000000 size:0x4000000 align: 0x200000
[0316.839] I> allocated(CO:39) base:0x1035e00000 size:0x2200000 align: 0x10000
[0316.846] I> allocated(CO:15) base:0x1033e00000 size:0x2000000 align: 0x100000
[0316.853] I> allocated(CO:20) base:0x1030000000 size:0x2000000 align: 0x2000000
[0316.861] I> allocated(CO:21) base:0x102e000000 size:0x2000000 align: 0x2000000
[0316.868] I> allocated(CO:24) base:0x102c000000 size:0x2000000 align: 0x2000000
[0316.875] I> allocated(CO:29) base:0x102a000000 size:0x2000000 align: 0x2000000
[0316.882] I> allocated(CO:35) base:0x1028000000 size:0x2000000 align: 0x100000
[0316.889] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0316.897] I> allocated(CO:41) base:0x1032e00000 size:0x1000000 align: 0x100000
[0316.904] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0316.911] I> allocated(CO:03) base:0x1032000000 size:0x800000 align: 0x800000
[0316.918] I> allocated(CO:06) base:0x1027800000 size:0x800000 align: 0x800000
[0316.925] I> allocated(CO:56) base:0x1027000000 size:0x800000 align: 0x200000
[0316.932] I> allocated(CO:07) base:0x1032800000 size:0x400000 align: 0x400000
[0316.939] I> allocated(CO:33) base:0x1026c00000 size:0x400000 align: 0x200000
[0316.946] I> allocated(CO:19) base:0x1026980000 size:0x280000 align: 0x10000
[0316.953] I> allocated(CO:17) base:0x1032c00000 size:0x200000 align: 0x200000
[0316.960] I> allocated(CO:23) base:0x1026600000 size:0x200000 align: 0x200000
[0316.967] I> allocated(CO:01) base:0x1026800000 size:0x100000 align: 0x100000
[0316.974] I> allocated(CO:04) base:0x1026500000 size:0x100000 align: 0x100000
[0316.981] I> allocated(CO:05) base:0x1026400000 size:0x100000 align: 0x100000
[0316.988] I> allocated(CO:08) base:0x1026300000 size:0x100000 align: 0x100000
[0316.995] I> allocated(CO:09) base:0x1026200000 size:0x100000 align: 0x100000
[0317.002] I> allocated(CO:12) base:0x1026100000 size:0x100000 align: 0x100000
[0317.009] I> allocated(CO:27) base:0x1026000000 size:0x100000 align: 0x100000
[0317.016] I> allocated(CO:42) base:0x1025f00000 size:0x100000 align: 0x100000
[0317.023] I> allocated(CO:54) base:0x1026900000 size:0x80000 align: 0x80000
[0317.030] I> allocated(CO:52) base:0x1025ed0000 size:0x30000 align: 0x10000
[0317.037] I> allocated(CO:34) base:0x1025ec0000 size:0x10000 align: 0x10000
[0317.044] I> allocated(CO:72) base:0x1025cc0000 size:0x200000 align: 0x10000
[0317.051] I> allocated(CO:46) base:0x1000000000 size:0x20000000 align: 0x20000000
[0317.058] I> allocated(CO:47) base:0x1021c00000 size:0x4000000 align: 0x200000
[0317.065] I> allocated(CO:50) base:0x1021a00000 size:0x200000 align: 0x100000
[0317.072] I> allocated(CO:48) base:0x1025ca0000 size:0x20000 align: 0x10000
[0317.079] I> allocated(CO:69) base:0x1025c80000 size:0x20000 align: 0x10000
[0317.086] I> allocated(CO:49) base:0x1025c70000 size:0x10000 align: 0x10000
[0317.093] I> NSDRAM base: 0x80000000, end: 0x1025cc0000, size: 0xfa5cc0000
[0317.100] I> Task: Thermal check
[0317.103] I> (MB1 SKU-specific) max_chip_limit = 105
[0317.108] I> (MB1 SKU-specific) min_chip_limit = -28
[0317.112] I> (MB1 BCT) max_chip_limit = 105
[0317.116] I> (MB1 BCT) min_chip_limit = -28
[0317.120] I> max temp read = 43
[0317.123] I> min temp read = 43
[0317.126] I> Task: Update FSI SCR with thermal fuse data
[0317.132] I> Task: Enable WDT 5th expiry
[0317.135] I> Task: I2C register
[0317.138] I> Task: Set I2C bus freq
[0317.142] I> Task: Reset FSI
[0317.145] I> FSI Reset successful
[0317.148] I> Task: Pad voltage init
[0317.151] I> Task: Pinmux init
[0317.154] I> Task: Prod config init
[0317.158] I> Task: Prod init
[0317.161] I> Task: Program rst req config reg
[0317.165] I> Task: Common rail init
[0317.169] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0317.180] I> DONE: Thermal config
[0317.184] I> DONE: SOC rail config
[0317.188] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0317.195] I> DONE: MEMIO rail config
[0317.198] I> DONE: GPU rail info
[0317.203] I> DONE: CV rail info
[0317.205] I> Task: Mem clock src
[0317.209] I> Task: Misc. board config
[0317.213] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0317.218] I> Task: SDRAM init
[0317.221] I> MemoryType: 4 MemBctRevision: 8
[0317.228] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0317.235] I> MSS CAR: Init PLLM
[0317.238] I> MSS CAR: Init PLLHUB
[0317.243] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0317.255] I> SDRAM initialized!
[0317.258] I> SDRAM Size in Total 0x1000000000
[0317.262] I> Task: Dram Ecc scrub
[0317.265] I> Task: DRAM alias check
[0317.277] I> Task: Program NSDRAM carveout
[0317.281] I> NSDRAM carveout encryption is enabled
[0317.285] I> Program NSDRAM carveout
[0317.289] I> Task: Check MSS settings
[0317.292] I> Task: MSS Encrypt status check
[0317.297] I> Task: Register checker
[0317.300] I> Task: Enable clock-mon
[0317.314] I> FMON: Fmon re-programming done
[0317.318] I> Task: Mapper init
[0317.321] I> Task: SC7 Context Init
[0317.325] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0317.330] I> Task: CCPLEX IST init
[0317.334] I> Task: CPU WP0
[0317.337] I> Loading MCE
[0317.340] I> Chain: 0
[0317.342] I> Binary[8] block-134217728 (partition size: 0x80000)
[0317.348] I> Binary name: MCE
[0317.351] I> Size of crypto header is 8192
[0317.355] I> Size of crypto header is 8192
[0327.626] I> BCH of MCE read from storage
[0327.630] I> BCH address is : 0x4003e000
[0327.633] I> component binary type is 8
[0327.637] I> MCE header integrity check is success
[0327.642] I> Binary magic in BCH component 0 is MTSM
[0327.647] I> component binary type is 8
[0327.650] I> Size of crypto header is 8192
[0327.654] I> component binary type is 8
[0327.658] I> MCE binary is read from storage
[0327.663] I> MCE binary integrity check is success
[0327.667] I> Binary MCE loaded successfully at 0x40000000 (0x2bbc0)
[0327.674] I> Size of crypto header is 8192
[0327.678] I> Sending WP0 mailbox command to PSC
[0327.687] I> Task: XUSB Powergate
[0327.690] I> Skipping powergate XUSB.
[0327.693] I> Task: MB1 fixed firewalls
[0327.699] I> Task: Load bpmp-fw
[0327.702] I> Chain: 0
[0327.704] I> Binary[15] block-251658240 (partition size: 0x180000)
[0327.710] I> Binary name: BPMP_FW
[0327.713] I> Size of crypto header is 8192
[0327.717] I> Size of crypto header is 8192
[0327.721] I> BCH of BPMP_FW read from storage
[0327.725] I> BCH address is : 0x807fe000
[0327.729] I> component binary type is 15
[0327.733] I> BPMP_FW header integrity check is success
[0327.738] I> Binary magic in BCH component 0 is BPMF
[0327.743] I> component binary type is 15
[0327.747] I> Size of crypto header is 8192
[0327.750] I> component binary type is 15
[0327.755] I> BPMP_FW binary is read from storage
[0327.762] I> BPMP_FW binary integrity check is success
[0327.767] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0327.773] I> Chain: 0
[0327.775] I> Binary[16] block-268435456 (partition size: 0x400000)
[0327.781] I> Binary name: BPMP_FW_DTB
[0327.785] I> Size of crypto header is 8192
[0327.789] I> Size of crypto header is 8192
[0327.793] I> BCH of BPMP_FW_DTB read from storage
[0327.797] I> BCH address is : 0x807fc000
[0327.801] I> component binary type is 16
[0327.805] I> BPMP_FW_DTB header integrity check is success
[0327.810] I> Binary magic in BCH component 0 is BPMD
[0327.815] I> component binary type is 16
[0327.819] I> Size of crypto header is 8192
[0327.823] I> component binary type is 16
[0327.827] I> BPMP_FW_DTB binary is read from storage
[0327.832] I> BPMP_FW_DTB binary integrity check is success
[0327.837] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd5b0 (0x3ea40)
[0327.844] I> Task: Load psc-fw
[0327.847] I> Chain: 0
[0327.849] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0327.855] I> Binary name: PSC_FW
[0327.858] I> Size of crypto header is 8192
[0327.862] I> Size of crypto header is 8192
[0327.866] I> BCH of PSC_FW read from storage
[0327.870] I> BCH address is : 0x80ffe000
[0327.874] I> component binary type is 17
[0327.878] I> PSC_FW header integrity check is success
[0327.883] I> Binary magic in BCH component 0 is PFWP
[0327.888] I> component binary type is 17
[0327.891] I> Size of crypto header is 8192
[0327.895] I> component binary type is 17
[0327.899] I> PSC_FW binary is read from storage
[0327.905] I> PSC_FW binary integrity check is success
[0327.909] I> Binary PSC_FW loaded successfully at 0x80fac6c0 (0x51940)
[0327.916] I> SCRATCH_PSC_FW_LOADADDR: 0x80fac6c0
[0327.920] I> Task: Load nvdec-fw
[0327.924] I> Chain: 0
[0327.926] I> Binary[7] block-117440512 (partition size: 0x100000)
[0327.932] I> Binary name: NVDEC
[0327.935] I> Size of crypto header is 8192
[0327.938] I> Size of crypto header is 8192
[0327.942] I> BCH of NVDEC read from storage
[0327.947] I> BCH address is : 0x800fe000
[0327.950] I> component binary type is 7
[0327.954] I> NVDEC header integrity check is success
[0327.959] I> Binary magic in BCH component 0 is NDEC
[0327.964] I> component binary type is 7
[0327.967] I> Size of crypto header is 8192
[0327.971] I> component binary type is 7
[0327.975] I> NVDEC binary is read from storage
[0327.980] I> NVDEC binary integrity check is success
[0327.985] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0327.994] I> Task: Load tsec-fw
[0327.997] I> Chain: 0
[0327.999] I> Binary[19] block-318767104 (partition size: 0x100000)
[0328.005] I> Binary name: TSEC
[0328.008] I> Size of crypto header is 8192
[0328.012] I> Size of crypto header is 8192
[0328.016] I> BCH of TSEC read from storage
[0328.020] I> BCH address is : 0x800fe000
[0328.023] I> component binary type is 19
[0328.027] I> TSEC header integrity check is success
[0328.032] I> Binary magic in BCH component 0 is TSEC
[0328.037] I> component binary type is 19
[0328.040] I> Size of crypto header is 8192
[0328.044] I> component binary type is 19
[0328.048] I> TSEC binary is read from storage
[0328.053] I> TSEC binary integrity check is success
[0328.058] I> Binary TSEC loaded successfully at 0x80000000 (0x2d000)
[0328.066] I> Task: GPIO interrupt map
[0328.070] I> Task: SC7 context save
[0328.074] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0328.080] I> Task: Load MB2/Applet/FSKP
[0328.084] I> Loading MB2
[0328.086] I> Chain: 0
[0328.088] I> Binary[6] block-100663296 (partition size: 0x80000)
[0328.094] I> Binary name: MB2
[0328.097] I> Size of crypto header is 8192
[0328.101] I> Size of crypto header is 8192
[0328.105] I> BCH of MB2 read from storage
[0328.109] I> BCH address is : 0x8007e000
[0328.112] I> component binary type is 6
[0328.116] I> MB2 header integrity check is success
[0328.121] I> Binary magic in BCH component 0 is MB2B
[0328.126] I> component binary type is 6
[0328.129] I> Size of crypto header is 8192
[0328.133] I> component binary type is 6
[0328.137] I> MB2 binary is read from storage
[0328.142] I> MB2 binary integrity check is success
[0328.147] I> Binary MB2 loaded successfully at 0x80000000 (0x69410)
[0328.153] I> Task: Map CCPLEX SHARED carveout
[0328.157] I> Task: Prepare MB2 params
[0328.161] I> Task: Dram ecc test
[0328.164] I> Task: Misc NV security settings
[0328.168] I> NVDEC sticky bits programming done
[0328.173] I> Successfully powergated NVDEC
[0328.177] I> Task: Disable/Reload WDT
[0328.180] I> Task: Program misc carveouts
[0328.184] I> Task: Disable SCPM/POD reset
[0328.188] I> SLCG Global override status := 0x0
[0328.193] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-5b8edbc4-01Jun26-131747-0700)
I> Boot-mode : RCM BOOT
I> Entry timestamp: 0x13903016
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x1027000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: Set blob address
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM not enabled
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x103c000000
I> Task: Load Misc-Config
I> Skip loading MISC-Config
I> Task: Configure OEM set LA/PTSA values
I> LA/PTSA updates are done from mb2-bct
I> Task: Validity check on SPE UART instance
I> Task: Load AUXP FWs
I> Unpowergating APE
I> Unpowergate done
I> Skipping FSI FW load
I> spe ratchet check pass
I> rce ratchet check pass
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x1026300000
I> dce ratchet check pass
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x1032c00000
I> ape ratchet check pass
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1030000000
I> xusb ratchet check pass
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x1032800000
I> pva-fw ratchet check pass
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x1026400000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x1026980000
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON
I> FSI VMON: recalibration done
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Prepare eeprom data
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Restore OEM firewalls to restrict Flush control
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
▒▒▒▒spe: early_init
▒▒▒▒vic initialized
▒▒▒▒tsc initialized
▒▒▒▒aon lic initialized
▒▒▒▒spe: tag is aba4fbe46f5cf77a32ef5977211b71e5
▒▒▒▒spe: SafeRTOS v8.4
▒▒▒▒spe: init
▒▒▒▒scheduler initialized
▒▒▒▒aon hsp initialized
▒▒▒▒tag initialized
▒▒▒▒tcu initialized
▒▒▒▒bpmp ipc initialized
▒▒▒▒spe: late init
▒▒▒▒cpu_nic clock initialized
▒▒▒▒apb clock initialized
▒▒▒▒pm initialized
▒▒▒▒bpmp hsp initialized
▒▒▒▒top1 hsp initialized
▒▒▒▒ccplex ipc initialized
▒▒▒▒spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> cpubl ratchet check pass
I> tos ratchet check pass
I> NSDRAM co base 0x80000000 size 0xfa5cc0000
I> cpubl nsdram co▒▒
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is bfff9e30f72531a69d7e98af55204154
bpmp: combined binary md5 is 684d9490f24f1c33cad8d07bf1ffd106
bpmp: firmware tag is 684d9490f24f1c33cad8-bfff9e30f72
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
[TS▒▒[ 12.095778] Camera-FW on t234-rce-safe (FuSa) started
▒▒:16168▒▒TCU early console enabled.
▒▒96462132609024]DCE Started
[TS:1618952106494918656]DCE_R5_Init
[TS:1621187443698958336]MPU enabled
[TS:1623314174064984064]DCE_SW_Init
[TS:1623683055921135616][dce_mem_ini▒▒initialized avfs_clk_platform
initialized powergate
▒▒=1 encryption=1
▒▒t_from_gsc] Failed to get ast region 2 mapping rc=:0x184549380
[TS▒▒initialized dvs
▒▒:16▒▒initialized clk_mach_config
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
▒▒I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x1021c00000
▒▒24471676341190656]Using fdt from dce_fw
▒▒I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103bd325c0
I> OPTEE dtb: 0x103beff400->0x1038040020 sz 0x3068
I> [0] 0x80000000 sz 0xfa5cc0000
I> [1] 0x103c000000 sz 0x4000000
I> NS mem ranges set
I> eks ratchet check pass
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x1038020000
I> EKB detected (length: 0x410) @ VA:0x1038020000
I> Task: Compute cpubl params hash
I> ▒▒initialized emc
initialized emc_mrq
▒▒Added cpubl params hash.
▒▒initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
▒▒I> Tas▒▒initialized uphy
▒▒k: Unhalt▒▒initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
▒▒ FSI
I> FSI unhalt skipped
I> Task: Trigger load TSEC leyblob
I> Task: Load and aut▒▒initialized clk_cal_late
initialized noc_late
initialized cvc
▒▒henticate registered FWs
I> Task: Pre▒▒initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable usb2_trk
enable xusb_ss_dev
enable xusb_fs_dev
enable xusb_falcon
enable dsi_lp
enable xusb_core_mux
enable xusb_core_dev
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
▒▒[ 12.324866] Camera-FW on t234-rce-safe ready (crt 12.991 ms, total boot 306.903 ms)
▒▒[TS:1651899651026059264]Admin Task Init
[TS:16519430130▒▒pare TOS params
▒▒15879680]Admin Task Init complete
[TS:1651986563984261120]▒▒I> EKB blob set in OPTEE dtb
▒▒Print Task Init
[TS:1652028783512780800]RM Task Init
[TS:1652066025174204416]SHA Task Init
[TS:1652097842291933184]SHA INIT
[TS:384668780]Admin Task Started
[TS:384677653]DCE SC7 SHA Disabled
[TS:384699297]RM Task Started
[TS:384705955]RM Task Running [id:2]
[TS:384931036]Print Task Started [id:4]
[TS:384939608]Print Task Running
[TS:384940849]SHA Task S▒▒I> OPTEE arg3: 0x1038040020
▒▒tarted
[TS:384941704]SHA Task Running [id:3]
▒▒I> NVRNG: Health check success
▒▒[TS:384942588]SHA Read-Only complete
[TS:38▒▒I> NVRNG: Health check success
▒▒5003296]Posting event
[TS:385005335]DCE: FW▒▒I> Task: Cleanup MISC config loader handler
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
▒▒ Boot Complete
[TS:385042870]Admin Task▒▒I> Task: SMMU init
▒▒ Running [id:1]
▒▒I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Clear dec source key
I> MB2 finished
▒▒NOTICE: BL31: v2.13.0(release):d65e852
NOTICE: BL31: Built : 13:14:59, Jun 1 2026
▒▒RCE FW sha: dfa4cae1
▒▒I/TC:
I/TC: Non-secure external DT found
I/TC: Switching console to device: /serial@0c198000
I/TC: OP-TEE version: 4.6 (gcc version 13.2.0 (crosstool-NG 1.26.0)) #2 Mon Jun 1 20:22:4 0 UTC 2026 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_gu idelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported .
I/TC: Primary CPU switching to normal world boot
t23x_general UEFI firmware (version 39.2.0-gcid-45755727 built on 2026-06-01T20:15:56+00 :00)
L4TLauncher: Attempting RCM Boot
EFI stub: Booting Linux Kernel…
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Measured initrd data into PCR 9
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services…
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 6.8.12-1021-tegra (buildbrain@03d5624e-58e4-4d2e-841c-817f5277e6d6-bv5r-zgps2) (aarch64-none-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT Mon Jun 1 13:25:46 PDT 2026 ()
[ 0.000000] KASLR enabled
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.7 by EDK II
[ 0.000000] efi: RTPROP=0xffcacf798 TPMFinalLog=0xff8d00000 SMBIOS=0xffff0000 SMBIOS 3.0=0xffc630000 MEMATTR=0xff7ce5018 TPMEventLog=0xff4fa9018 INITRD=0xff4faaf18 RNG=0xff4fa7018 MEMRESERVE=0xff4faaf98
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001001a00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000001001a00000..0x00000010219fffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000001025cc0000..0x0000001025ebffff (2048 KiB) nomap non-reusable ramoops_carveout
[ 0.000000] OF: reserved mem: 0x0000001026980000..0x0000001026bfffff (2560 KiB) map non-reusable pva-carveout
[ 0.000000] OF: reserved mem: 0x0000001032e00000..0x0000001033dfffff (16384 KiB) nomap non-reusable fsi-carveout
[ 0.000000] OF: reserved mem: 0x0000001035e00000..0x000000103666ffff (8640 KiB) nomap non-reusable framebuffer@10,35E00000
[ 0.000000] OF: reserved mem: 0x0000001049800000..0x000000107fffffff (892928 KiB) nomap non-reusable vpr-carveout
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x000000103fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1025b13b00-0x1025b16fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000103fffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000ff5bbffff]
[ 0.000000] node 0: [mem 0x0000000ff5bc0000-0x0000000ff7cbffff]
[ 0.000000] node 0: [mem 0x0000000ff7cc0000-0x0000000ff7cfffff]
[ 0.000000] node 0: [mem 0x0000000ff7d00000-0x0000000ff7d0ffff]
[ 0.000000] node 0: [mem 0x0000000ff7d10000-0x0000000ff8cfffff]
[ 0.000000] node 0: [mem 0x0000000ff8d00000-0x0000000ff8d0ffff]
[ 0.000000] node 0: [mem 0x0000000ff8d10000-0x0000000ffab8ffff]
[ 0.000000] node 0: [mem 0x0000000ffab90000-0x0000000ffcacffff]
[ 0.000000] node 0: [mem 0x0000000ffcad0000-0x00000010219fffff]
[ 0.000000] node 0: [mem 0x0000001021a00000-0x0000001021bfffff]
[ 0.000000] node 0: [mem 0x0000001021c00000-0x0000001025c6ffff]
[ 0.000000] node 0: [mem 0x000000103c000000-0x000000103fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000103fffffff]
[ 0.000000] On node 0, zone Normal: 25488 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 31 pages/cpu s89256 r8192 d29528 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected QARMA5 algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 efi=runtime bl_prof_dataptr=2031616@0x1021A10000 bl_prof_ro_ptr=65536@0x1021A00000
[ 0.000000] Unknown kernel command line parameters “bl_prof_dataptr=2031616@0x1021A10000 bl_prof_ro_ptr=65536@0x1021A00000”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16166000
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 16.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 63763336K/65696192K available (21248K kernel code, 5878K rwdata, 13332K rodata, 11584K init, 640K bss, 1408568K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.000000] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000343] Console: colour dummy device 80x25
[ 0.000389] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000393] pid_max: default: 32768 minimum: 301
[ 0.000436] LSM: initializing lsm=capability,landlock,yama,apparmor,integrity
[ 0.000444] landlock: Up and running.
[ 0.000444] Yama: becoming mindful.
[ 0.000474] AppArmor: AppArmor initialized
[ 0.000542] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000586] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001636] rcu: Hierarchical SRCU implementation.
[ 0.001638] rcu: Max phase no-delay instances is 1000.
[ 0.003072] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[ 0.004271] Remapping and enabling EFI services.
[ 0.004897] smp: Bringing up secondary CPUs …
[ 0.005159] Detected PIPT I-cache on CPU1
[ 0.005192] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005207] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.005458] Detected PIPT I-cache on CPU2
[ 0.005476] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.005485] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.005714] Detected PIPT I-cache on CPU3
[ 0.005732] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.005740] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.007861] Detected PIPT I-cache on CPU4
[ 0.007897] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.007913] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.008171] Detected PIPT I-cache on CPU5
[ 0.008190] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.008200] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.008450] Detected PIPT I-cache on CPU6
[ 0.008470] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.008480] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.008720] Detected PIPT I-cache on CPU7
[ 0.008741] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.008750] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.010871] Detected PIPT I-cache on CPU8
[ 0.010910] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.010925] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.011184] Detected PIPT I-cache on CPU9
[ 0.011205] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.011215] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.011458] Detected PIPT I-cache on CPU10
[ 0.011480] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.011489] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.011729] Detected PIPT I-cache on CPU11
[ 0.011751] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.011761] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.011799] smp: Brought up 1 node, 12 CPUs
[ 0.011801] SMP: Total of 12 processors activated.
[ 0.011802] CPU: All CPU(s) started at EL2
[ 0.011804] CPU features: detected: 32-bit EL0 Support
[ 0.011804] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.011806] CPU features: detected: Common not Private translations
[ 0.011806] CPU features: detected: CRC32 instructions
[ 0.011807] CPU features: detected: Data cache clean to Point of Persistence
[ 0.011809] CPU features: detected: Generic authentication (architected QARMA5 algorithm)
[ 0.011810] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.011811] CPU features: detected: LSE atomic instructions
[ 0.011812] CPU features: detected: Privileged Access Never
[ 0.011813] CPU features: detected: RAS Extension Support
[ 0.011814] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.011863] alternatives: applying system-wide alternatives
[ 0.014475] CPU features: detected: Hardware dirty bit management on CPU0-11
[ 0.015611] devtmpfs: initialized
[ 0.026340] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.026347] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.028916] pinctrl core: initialized pinctrl subsystem
[ 0.030152] SMBIOS 3.6.0 present.
[ 0.030157] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 39.2.0-gcid-45755727 06/01/2026
[ 0.030431] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.031101] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[ 0.031350] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.031591] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.031602] audit: initializing netlink subsys (disabled)
[ 0.031671] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[ 0.032435] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.032437] thermal_sys: Registered thermal governor ‘user_space’
[ 0.032439] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.032457] cpuidle: using governor menu
[ 0.032535] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.032612] ASID allocator initialised with 32768 entries
[ 0.033350] Serial: AMBA PL011 UART driver
[ 0.038127] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000
[ 0.038133] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000
[ 0.038136] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00
[ 0.038139] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00
[ 0.038142] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00
[ 0.038145] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903900
[ 0.038148] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903800
[ 0.038150] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903300
[ 0.038153] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903200
[ 0.038156] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903100
[ 0.038158] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903000
[ 0.038161] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200
[ 0.038163] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000
[ 0.038166] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600
[ 0.038169] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400
[ 0.038172] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200
[ 0.038174] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000
[ 0.038177] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200
[ 0.038180] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500
[ 0.038182] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300
[ 0.038185] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100
[ 0.038189] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.038192] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000
[ 0.038196] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 0.038202] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038210] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038218] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038226] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038235] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038242] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038249] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038257] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038264] /bus@0/aconnect@2900000/ahub@2900800/amx@2903000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038272] /bus@0/aconnect@2900000/ahub@2900800/amx@2903100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038280] /bus@0/aconnect@2900000/ahub@2900800/amx@2903200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038289] /bus@0/aconnect@2900000/ahub@2900800/amx@2903300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038297] /bus@0/aconnect@2900000/ahub@2900800/adx@2903800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038305] /bus@0/aconnect@2900000/ahub@2900800/adx@2903900: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038313] /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038321] /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038329] /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038337] /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038346] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038353] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038360] /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038371] /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038382] /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.038428] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.038449] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.038453] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.038457] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.038461] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.038484] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 0.038488] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 0.038496] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 0.038500] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 0.038509] /bus@0/interrupt-controller@f400000: Fixed dependency cycle(s) with /bus@0/interrupt-controller@f400000
[ 0.038551] /bus@0/aon@c000000: Fixed dependency cycle(s) with /bus@0/aon@c000000
[ 0.039033] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000
[ 0.039038] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000
[ 0.039041] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00
[ 0.039044] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00
[ 0.039047] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00
[ 0.039050] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903900
[ 0.039053] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/adx@2903800
[ 0.039056] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903300
[ 0.039058] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903200
[ 0.039061] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903100
[ 0.039064] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/amx@2903000
[ 0.039067] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200
[ 0.039069] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000
[ 0.039072] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600
[ 0.039075] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400
[ 0.039077] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200
[ 0.039080] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000
[ 0.039083] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200
[ 0.039086] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500
[ 0.039088] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300
[ 0.039091] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100
[ 0.039094] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.039097] /bus@0/aconnect@2900000/ahub@2900800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000
[ 0.039100] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 0.039109] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039118] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039127] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039137] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901500: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039146] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039155] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039164] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902400: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039172] /bus@0/aconnect@2900000/ahub@2900800/sfc@2902600: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039181] /bus@0/aconnect@2900000/ahub@2900800/amx@2903000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039191] /bus@0/aconnect@2900000/ahub@2900800/amx@2903100: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039200] /bus@0/aconnect@2900000/ahub@2900800/amx@2903200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039209] /bus@0/aconnect@2900000/ahub@2900800/amx@2903300: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039219] /bus@0/aconnect@2900000/ahub@2900800/adx@2903800: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039228] /bus@0/aconnect@2900000/ahub@2900800/adx@2903900: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039238] /bus@0/aconnect@2900000/ahub@2900800/adx@2903a00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039247] /bus@0/aconnect@2900000/ahub@2900800/adx@2903b00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039257] /bus@0/aconnect@2900000/ahub@2900800/dmic@2904200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039266] /bus@0/aconnect@2900000/ahub@2900800/processing-engine@2908000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039275] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039284] /bus@0/aconnect@2900000/ahub@2900800/mvc@290a200: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039293] /bus@0/aconnect@2900000/ahub@2900800/amixer@290bb00: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039304] /bus@0/aconnect@2900000/ahub@2900800/admaif@290f000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039317] /bus@0/aconnect@2900000/ahub@2900800/asrc@2910000: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800
[ 0.039656] tegra-mc 2c00000.memory-controller: unknown: writ@0x00000000500604e0 @0x00000000500604e0: Security violation (TrustZone violation)
[ 0.040111] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 15, base_baud = 0) is a SBSA
[ 0.040255] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 0.040925] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.040930] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.040935] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 0.040939] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 0.042761] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 0.042765] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 0.042769] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 0.042772] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 0.044682] /bus@0/aon@c000000: Fixed dependency cycle(s) with /bus@0/aon@c000000
[ 0.045264] /bus@0/memory-controller@2c00000/external-memory-controller@2c60000: Fixed dependency cycle(s) with /bpmp
[ 0.045305] /bpmp: Fixed dependency cycle(s) with /bus@0/memory-controller@2c00000/external-memory-controller@2c60000
[ 0.047983] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.047985] Modules: 0 pages in range for non-PLT usage
[ 0.047986] Modules: 511056 pages in range for PLT usage
[ 0.048215] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.048217] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.048218] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.048219] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.048220] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.048221] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.048221] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.048222] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.048684] ACPI: Interpreter disabled.
[ 0.049755] iommu: Default domain type: Translated
[ 0.049757] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.054768] SCSI subsystem initialized
[ 0.054855] usbcore: registered new interface driver usbfs
[ 0.054863] usbcore: registered new interface driver hub
[ 0.054872] usbcore: registered new device driver usb
[ 0.055181] pps_core: LinuxPPS API ver. 1 registered
[ 0.055182] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.055185] PTP clock support registered
[ 0.055228] EDAC MC: Ver: 3.0.0
[ 0.055488] ARM FF-A: FFA_VERSION returned not supported
[ 0.055499] scmi_core: SCMI protocol bus registered
[ 0.055566] efivars: Registered efivars operations
[ 0.055876] FPGA manager framework
[ 0.055916] Advanced Linux Sound Architecture Driver Initialized.
[ 0.056144] vgaarb: loaded
[ 0.056268] clocksource: Switched to clocksource arch_sys_counter
[ 0.056373] VFS: Disk quotas dquot_6.6.0
[ 0.056383] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.056588] AppArmor: AppArmor Filesystem Enabled
[ 0.056596] pnp: PnP ACPI: disabled
[ 0.057902] NET: Registered PF_INET protocol family
[ 0.058004] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.060842] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.061031] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.061041] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.062489] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.063206] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.063247] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.063768] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.064340] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.064446] RPC: Registered named UNIX socket transport module.
[ 0.064447] RPC: Registered udp transport module.
[ 0.064448] RPC: Registered tcp transport module.
[ 0.064448] RPC: Registered tcp-with-tls transport module.
[ 0.064449] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.064455] PCI: CLS 0 bytes, default 64
[ 0.064519] Unpacking initramfs…
[ 0.068404] kvm [1]: IPA Size Limit: 48 bits
[ 0.068413] kvm [1]: GICv3: no GICV resource entry
[ 0.068415] kvm [1]: disabling GICv2 emulation
[ 0.068427] kvm [1]: GIC system register CPU interface enabled
[ 0.068437] kvm [1]: vgic interrupt IRQ9
[ 0.068454] kvm [1]: VHE mode initialized successfully
[ 0.068881] Initialise system trusted keyrings
[ 0.068888] Key type blacklist registered
[ 0.068932] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.069064] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.069147] NFS: Registering the id_resolver key type
[ 0.069152] Key type id_resolver registered
[ 0.069154] Key type id_legacy registered
[ 0.069159] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.069163] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.069169] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.069207] 9p: Installing v9fs 9p2000 file system support
[ 0.069256] integrity: Platform Keyring initialized
[ 0.081169] Key type asymmetric registered
[ 0.081171] Asymmetric key parser ‘x509’ registered
[ 0.081187] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.081189] io scheduler mq-deadline registered
[ 0.081190] io scheduler kyber registered
[ 0.081206] io scheduler bfq registered
[ 0.090137] EINJ: ACPI disabled.
[ 0.099795] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.100815] msm_serial: driver initialized
[ 0.100942] SuperH (H)SCI(F) driver initialized
[ 0.101008] STM32 USART driver initialized
[ 0.101319] printk: legacy console [ttyTCU0] enabled
[ 0.430433] Freeing initrd memory: 26092K
[ 0.436619] arm-smmu 8000000.iommu: probing hardware configuration…
[ 2.921569] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.926201] arm-smmu 8000000.iommu: stage 1 translation
[ 2.931623] arm-smmu 8000000.iommu: stage 2 translation
[ 2.936959] arm-smmu 8000000.iommu: nested translation
[ 2.942039] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.949125] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.955776] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 2.962335] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.968636] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.975201] arm-smmu 8000000.iommu: preserved 0 boot mappings
[ 2.981626] arm-smmu 10000000.iommu: probing hardware configuration…
[ 2.987450] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.992087] arm-smmu 10000000.iommu: stage 1 translation
[ 2.997423] arm-smmu 10000000.iommu: stage 2 translation
[ 3.002760] arm-smmu 10000000.iommu: nested translation
[ 3.008273] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 3.015450] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 3.022099] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 3.028573] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.035050] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.041564] arm-smmu 10000000.iommu: preserved 0 boot mappings
[ 3.047734] arm-smmu 12000000.iommu: probing hardware configuration…
[ 3.053950] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.058674] arm-smmu 12000000.iommu: stage 1 translation
[ 3.064097] arm-smmu 12000000.iommu: stage 2 translation
[ 3.069523] arm-smmu 12000000.iommu: nested translation
[ 3.074861] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.082124] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.088862] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 3.095423] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.101985] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.108588] arm-smmu 12000000.iommu: preserved 0 boot mappings
[ 3.117225] loop: module loaded
[ 3.118062] megasas: 07.727.03.00-rc1
[ 3.123555] tun: Universal TUN/TAP device driver, 1.6
[ 3.126915] thunder_xcv, ver 1.0
[ 3.130000] thunder_bgx, ver 1.0
[ 3.133320] nicpf, ver 1.0
[ 3.136573] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 3.143285] hns3: Copyright (c) 2017 Huawei Corporation.
[ 3.148722] hclge is initializing
[ 3.152132] e1000: Intel(R) PRO/1000 Network Driver
[ 3.157024] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 3.162806] e1000e: Intel(R) PRO/1000 Network Driver
[ 3.167784] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.173830] igb: Intel(R) Gigabit Ethernet Network Driver
[ 3.179335] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.185030] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 3.191323] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.197129] sky2: driver version 1.30
[ 3.200921] PPP generic driver version 2.4.2
[ 3.204899] VFIO - User Level meta-driver version: 0.3
[ 3.211194] usbcore: registered new interface driver usb-storage
[ 3.216988] i2c_dev: i2c /dev entries driver
[ 3.221074] pps_ldisc: PPS line discipline registered
[ 3.226898] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 3.234934] sdhci: Secure Digital Host Controller Interface driver
[ 3.240238] sdhci: Copyright(c) Pierre Ossman
[ 3.244992] Synopsys Designware Multimedia Card Interface Driver
[ 3.250863] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.257988] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.262736] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000001
[ 3.268942] tegra-bpmp bpmp: Adding to iommu group 0
[ 3.274113] tegra-bpmp bpmp: firmware: 684d9490f24f1c33cad8-bfff9e30f72
▒▒debugfs initialized
▒▒[ 4.435909] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 4.436226] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 4.436517] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 4.436868] hid: raw HID events driver (C) Jiri Kosina
[ 4▒▒▒▒.43▒▒I/▒▒715▒▒TC:▒▒2] ▒▒ Re▒▒usb▒▒ser▒▒cor▒▒ved▒▒e: ▒▒ s▒▒reg▒▒har▒▒ist▒▒ed ▒▒ere▒▒mem▒▒d n▒▒ory▒▒ew ▒▒ is▒▒int▒▒ d▒▒erf▒▒isa▒▒ace▒▒ble▒▒ dr▒▒d
▒▒C: ▒▒▒▒r u▒▒▒▒sbh▒▒I/T▒▒id
▒▒re ▒▒▒▒Dy▒▒[ ▒▒nam▒▒ 4▒▒ic▒▒.43▒▒ sh▒▒730▒▒are▒▒4] ▒▒d m▒▒usb▒▒emo▒▒hid▒▒ry ▒▒: U▒▒is▒▒SB ▒▒ en▒▒HID▒▒abl▒▒ co▒▒ed
▒▒dri▒▒▒▒ver▒▒I/T▒▒
▒▒rte▒▒[ ▒▒No▒▒ 4▒▒rma▒▒.44▒▒l W▒▒264▒▒orl▒▒9] ▒▒d v▒▒hw ▒▒irt▒▒per▒▒ual▒▒fev▒▒iz▒▒ent▒▒ati▒▒s: ▒▒on ▒▒ena▒▒sup▒▒ble▒▒por▒▒d w▒▒t i▒▒ith▒▒s ▒▒ ar▒▒dis▒▒mv8▒▒abl▒▒_co▒▒ed
▒▒ a▒▒ ▒▒x_a▒▒▒▒78 ▒▒I/T▒▒PMU▒▒C: ▒▒ dr▒▒Asy▒▒ive▒▒nch▒▒r, ▒▒ron▒▒7 c▒▒ou▒▒oun▒▒s n▒▒ter▒▒oti▒▒s a▒▒fic▒▒vai▒▒ati▒▒lab▒▒ons▒▒le
▒▒re▒▒[ ▒▒ di▒▒ 4▒▒sab▒▒.44▒▒led▒▒410▒▒
▒▒0] optee: probing for conduit method.
[ 4.444221] optee: revision 4.6 (565c76420cf641dd)
[ 4.504107] optee: dynamic shared memory is enabled
[ 4.504477] optee: initialized driver
[ 4.504597] Driver ‘optee’ was unable to register with bus_type ‘arm_ffa’ because the bus was not initialized.
[ 4.505804] usbcore: registered new interface driver snd-usb-audio
[ 4.506309] u32 classifier
[ 4.506381] input device check on
[ 4.506473] Actions configured
[ 4.506617] NET: Registered PF_PACKET protocol family
[ 4.506777] 9pnet: Installing 9P2000 support
[ 4.506916] Key type dns_resolver registered
[ 4.509444] registered taskstats version 1
[ 4.509637] Loading compiled-in X.509 certificates
[ 4.510617] Loaded X.509 cert ‘Build time autogenerated kernel key: 2aa084e2fd6866a7534b775c8350e9356665cce0’
[ 4.515677] AppArmor: AppArmor sha256 policy hashing enabled
[ 4.528904] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.529671] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 4.534379] serial-tegra 3100000.serial: Adding to iommu group 1
[ 4.539900] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 133, base_baud = 0) is a TEGRA_UART
[ 4.549298] serial-tegra 3110000.serial: RX in PIO mode
[ 4.553713] serial-tegra 3110000.serial: TX in PIO mode
[ 4.558870] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 134, base_baud = 0) is a TEGRA_UART
[ 4.575819] [drm] Initialized simpledrm 1.0.0 20200625 for chosen:framebuffer on minor 0
[ 4.586579] Console: switching to colour frame buffer device 240x67
[ 4.591243] simple-framebuffer chosen:framebuffer: [drm] fb0: simpledrmdrmfb frame buffer device
[ 4.592490] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.595696] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.602161] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.609079] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.614679] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 4.619372] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.624847] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 4.630315] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 4.635644] /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000: Fixed dependency cycle(s) with /bus@0/i2c@31e0000/audio-codec@1c
[ 4.646399] /bus@0/i2c@31e0000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@2900000/ahub@2900800/i2s@2901000
[ 4.658126] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.664028] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 4.673757] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 4.684512] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 4.695273] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 4.706281] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.717302] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 4.723955] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 4.735598] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 4.740354] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-0
[ 4.748464] mmc0: CQHCI version 5.10
[ 4.749887] /bus@0/padctl@3520000/ports/usb2-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 4.764208] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb2-1
[ 4.774821] /bus@0/padctl@3520000/ports/usb2-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 4.785677] /bus@0/i2c@c240000/typec@8/connector@0: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-0
[ 4.796171] /bus@0/padctl@3520000/ports/usb3-0: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@0
[ 4.797767] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 4.806669] /bus@0/i2c@c240000/typec@8/connector@1: Fixed dependency cycle(s) with /bus@0/padctl@3520000/ports/usb3-1
[ 4.824868] /bus@0/padctl@3520000/ports/usb3-1: Fixed dependency cycle(s) with /bus@0/i2c@c240000/typec@8/connector@1
[ 4.835849] tegra-xusb 3610000.usb: Adding to iommu group 3
[ 4.855286] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 4.855532] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.856100] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 4.864334] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000000810
[ 4.872993] tegra-xusb 3610000.usb: irq 145, io mem 0x03610000
[ 4.879100] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.884447] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 4.891974] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.900325] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[ 4.907465] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.910624] mmc0: Command Queue Engine enabled
[ 4.914807] usb usb1: Product: xHCI Host Controller
[ 4.914809] usb usb1: Manufacturer: Linux 6.8.12-1021-tegra xhci-hcd
[ 4.914810] usb usb1: SerialNumber: 3610000.usb
[ 4.919272] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.924736] hub 1-0:1.0: USB hub found
[ 4.930855] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 4.935486] hub 1-0:1.0: 4 ports detected
[ 4.945848] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.951855] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[ 4.954331] mmcblk0boot0: mmc0:0001 DG4064 4.00 MiB
[ 4.960659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.960661] usb usb2: Product: xHCI Host Controller
[ 4.960662] usb usb2: Manufacturer: Linux 6.8.12-1021-tegra xhci-hcd
[ 4.969164] mmcblk0boot1: mmc0:0001 DG4064 4.00 MiB
[ 4.973782] usb usb2: SerialNumber: 3610000.usb
[ 4.974138] hub 2-0:1.0: USB hub found
[ 4.981298] mmcblk0rpmb: mmc0:0001 DG4064 4.00 MiB, chardev (509:0)
[ 4.986233] hub 2-0:1.0: 4 ports detected
[ 5.018858] sdhci-tegra 3400000.mmc: Adding to iommu group 4
[ 5.022668] irq: IRQ154: trimming hierarchy from :bus@0:pmc@c360000
[ 5.028826] irq: IRQ156: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 5.028861] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 5.036860] irq: IRQ157: trimming hierarchy from :bus@0:pmc@c360000
[ 5.046720] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.053830] clk: Disabling unused clocks
[ 5.103564] ALSA device list:
[ 5.103648] No soundcards found.
▒▒inv▒▒124019] irq: IRQ158: trimming hierarchy from :bus@0:interrupt-contro▒▒▒▒lle▒▒E/T▒▒r@f▒▒C:?▒▒400▒▒? ▒▒000▒▒00 ▒▒-1
▒▒ok▒▒[ ▒▒e_c▒▒ 5▒▒omm▒▒.12▒▒and▒▒463▒▒:4▒▒1] ▒▒11 ▒▒mmc▒▒Jet▒▒1: ▒▒son▒▒SDH▒▒ us▒▒CI ▒▒er ▒▒con▒▒key▒▒tro▒▒ P▒▒lle▒▒TA ▒▒r o▒▒is ▒▒n 3▒▒una▒▒400▒▒vai▒▒000▒▒lab▒▒.mm▒▒le▒▒c [▒▒
▒▒3400000.mmc] using ADMA 64-bit
[ 5.126237] Freeing unused kernel memory: 11584K
[ 5.126393] Run /init as init process
[ 5.156613] Checking overlayfs setting…
[ 5.164941] Overlayfs is disabled…
[ 5.165075] Loading modules dependency
insmod /lib/modules/6.8.12-1021-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
[ 5.219935] r8168: loading out-of-tree module taints kernel.
insmod /lib/modules/6.8.12-1021-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
[ 5.227941] Running nv init script
/init: line 198: warning: command substitution: ignored null byte in input
[ 5.229513] Starting flashing kernel
enable_remote_access
enable remote access
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
[ 5.236284] usb 1-3: new full-speed USB device number 2 using tegra-xusb
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
[ 5.241717] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 5.242665] irq: IRQ183: trimming hierarchy from :bus@0:pmc@c360000
[ 5.245045] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 5.245251] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff → 0x2080000000
[ 5.245456] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff → 0x0040000000
[ 5.245662] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff → 0x0030100000
[ 5.246528] tegra194-pcie 14100000.pcie: iATU: unroll T, 8 ob, 2 ib, align 64K, limit 32G
[ 5.352406] tegra194-pcie 14100000.pcie: PCIe Gen.1 x1 link up
[ 5.355893] tegra194-pcie 14100000.pcie: PCIe Gen.1 x1 link up
[ 5.356332] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.356504] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.356641] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 5.356849] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 5.357123] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 5.357402] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400 PCIe Root Port
[ 5.357625] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.357760] pci 0001:00:00.0: bridge window [io 0x0000-0x0fff]
[ 5.357929] pci 0001:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 5.358105] pci 0001:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 5.359108] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 5.362473] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000 PCIe Endpoint
[ 5.363159] pci 0001:01:00.0: BAR 0 [io 0x0000-0x00ff]
[ 5.363937] pci 0001:01:00.0: BAR 2 [mem 0x20a8000000-0x20a800ffff 64bit]
[ 5.371458] pci 0001:01:00.0: supports D1 D2
[ 5.375010] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.389764] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 5.389983] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.392479] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]: assigned
[ 5.397502] usb 1-3: Product: Bluetooth Radio
[ 5.405198] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]: assigned
[ 5.409660] usb 1-3: Manufacturer: Realtek
[ 5.416398] pci 0001:01:00.0: BAR 2 [mem 0x20a8000000-0x20a800ffff 64bit]: assigned
[ 5.420597] usb 1-3: SerialNumber: 00e04c000001
[ 5.428483] pci 0001:01:00.0: BAR 0 [io 0x1000-0x10ff]: assigned
[ 5.439436] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.444487] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 5.450612] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 5.457791] pci_bus 0001:00: resource 4 [mem 0x2080000000-0x20a7ffffff pref]
[ 5.464696] pci_bus 0001:00: resource 5 [mem 0x20a8000000-0x20afffffff]
[ 5.471521] pci_bus 0001:00: resource 6 [io 0x0000-0xfffff]
[ 5.477210] pci_bus 0001:01: resource 0 [io 0x1000-0x1fff]
[ 5.482984] pci_bus 0001:01: resource 1 [mem 0x20a8000000-0x20a80fffff]
[ 5.489788] pcieport 0001:00:00.0: Adding to iommu group 5
[ 5.495132] pcieport 0001:00:00.0: PME: Signaling with IRQ 184
[ 5.501313] pcieport 0001:00:00.0: AER: enabled with IRQ 184
[ 5.506754] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 5.513456] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 5.515493] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 5.527704] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff → 0x2140000000
[ 5.536363] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff → 0x0040000000
[ 5.544760] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff → 0x0036100000
[ 5.553964] tegra194-pcie 14160000.pcie: iATU: unroll T, 8 ob, 2 ib, align 64K, limit 32G
[ 5.561621] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 5.569700] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.576960] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 5.581683] usb 2-3: Manufacturer: Generic
[ 5.596200] hub 2-3:1.0: USB hub found
[ 5.598561] hub 2-3:1.0: 4 ports detected
[ 5.668399] tegra194-pcie 14160000.pcie: PCIe Gen.4 x4 link up
[ 5.671737] tegra194-pcie 14160000.pcie: PCIe Gen.4 x4 link up
[ 5.671931] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.672111] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.672254] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 5.672462] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.672734] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 5.673006] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400 PCIe Root Port
[ 5.673220] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.673358] pci 0004:00:00.0: bridge window [io 0x0000-0x0fff]
[ 5.673519] pci 0004:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 5.673719] pci 0004:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 5.678563] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 5.680405] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 5.686417] pci 0004:01:00.0: [144d:a80c] type 00 class 0x010802 PCIe Endpoint
[ 5.698385] pci 0004:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[ 5.716437] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]: assigned
[ 5.716632] pci 0004:01:00.0: BAR 0 [mem 0x2428000000-0x2428003fff 64bit]: assigned
[ 5.720095] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.725277] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 5.732452] pci_bus 0004:00: resource 4 [mem 0x2140000000-0x2427ffffff pref]
[ 5.739535] pci_bus 0004:00: resource 5 [mem 0x2428000000-0x242fffffff]
[ 5.746271] pci_bus 0004:00: resource 6 [io 0x100000-0x1fffff]
[ 5.752310] pci_bus 0004:01: resource 1 [mem 0x2428000000-0x24280fffff]
[ 5.759103] pcieport 0004:00:00.0: Adding to iommu group 6
[ 5.764529] pcieport 0004:00:00.0: PME: Signaling with IRQ 186
[ 5.770898] pcieport 0004:00:00.0: AER: enabled with IRQ 186
[ 5.776382] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 5.860970] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 5.861188] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.861375] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 5.861499] usb 1-4: Manufacturer: Generic
[ 5.864313] hub 1-4:1.0: USB hub found
[ 5.865766] hub 1-4:1.0: 4 ports detected
[ 5.889822] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[ 5.890027] tegra194-pcie 141a0000.pcie: MEM 0x2800000000..0x2b27ffffff → 0x2800000000
[ 5.890251] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff → 0x0040000000
[ 5.890473] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff → 0x003a100000
[ 5.891346] tegra194-pcie 141a0000.pcie: iATU: unroll T, 8 ob, 2 ib, align 64K, limit 32G
[ 6.588399] usb 1-4.1: new low-speed USB device number 4 using tegra-xusb
[ 6.705163] usb 1-4.1: New USB device found, idVendor=0461, idProduct=3f41, bcdDevice= 1.21
[ 6.705392] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.705593] usb 1-4.1: Product: HP Wired Desktop 320K Keyboard
[ 6.705759] usb 1-4.1: Manufacturer: Primax
[ 6.715671] input: Primax HP Wired Desktop 320K Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.0/0003:0461:3F41.0001/input/input1
[ 6.836881] hid-generic 0003:0461:3F41.0001: input,hidraw0: USB HID v1.11 Keyboard [Primax HP Wired Desktop 320K Keyboard] on usb-3610000.usb-4.1/input0
[ 6.842898] input: Primax HP Wired Desktop 320K Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.1/0003:0461:3F41.0002/input/input2
[ 6.900838] input: Primax HP Wired Desktop 320K Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.1/1-4.1:1.1/0003:0461:3F41.0002/input/input3
[ 6.902057] hid-generic 0003:0461:3F41.0002: input,hidraw1: USB HID v1.11 Device [Primax HP Wired Desktop 320K Keyboard] on usb-3610000.usb-4.1/input1
[ 6.984398] usb 1-4.2: new low-speed USB device number 5 using tegra-xusb
[ 6.997687] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 7.093293] usb 1-4.2: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[ 7.093529] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.093712] usb 1-4.2: Product: USB Optical Mouse
[ 7.093830] usb 1-4.2: Manufacturer: Logitech
[ 7.099220] input: Logitech USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-4/1-4.2/1-4.2:1.0/0003:046D:C077.0003/input/input4
[ 7.100377] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.usb-4.2/input0
[ 7.999150] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 7.999352] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.999538] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.999687] pci_bus 0005:00: root bus resource [mem 0x2800000000-0x2b27ffffff pref]
[ 7.999891] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.000178] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 8.000466] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400 PCIe Root Port
[ 8.000697] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 8.000853] pci 0005:00:00.0: bridge window [io 0x0000-0x0fff]
[ 8.001017] pci 0005:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 8.001240] pci 0005:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 8.002510] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 8.005582] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 8.005722] pci_bus 0005:00: resource 4 [mem 0x2800000000-0x2b27ffffff pref]
[ 8.005897] pci_bus 0005:00: resource 5 [mem 0x2b28000000-0x2b2fffffff]
[ 8.011523] pci_bus 0005:00: resource 6 [io 0x200000-0x2fffff]
[ 8.017618] pcieport 0005:00:00.0: Adding to iommu group 7
[ 8.023050] pcieport 0005:00:00.0: PME: Signaling with IRQ 188
[ 8.029409] pcieport 0005:00:00.0: AER: enabled with IRQ 188
[ 8.035167] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 8.040732] pci_bus 0005:00: busn_res: [bus 00-ff] is released
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/nvme/host/nvme.ko
[ 8.063582] nvme 0004:01:00.0: Adding to iommu group 6
[ 8.066051] nvme nvme0: pci function 0004:01:00.0
[ 8.070264] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 8.079458] nvme nvme0: Shutdown timeout set to 10 seconds
[ 8.082334] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 8.087893] hwmon hwmon0: temp2_input not attached to any thermal zone
[ 8.094424] hwmon hwmon0: temp3_input not attached to any thermal zone
[ 8.102415] nvme nvme0: 12/0/0 default/read/poll queues
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/hwmon/pwm-fan.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/gadget/libcomposite.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/typec/typec.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
[ 8.160132] irq: IRQ203: trimming hierarchy from :bus@0:pmc@c360000
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
[ 8.211999] tegra-xudc 3550000.usb: Adding to iommu group 8
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/usb/storage/uas.ko
[ 8.218532] usbcore: registered new interface driver uas
insmod /lib/modules/6.8.12-1021-tegra/kernel/net/ipv6/ipv6.ko
[ 8.228294] NET: Registered PF_INET6 protocol family
[ 8.229049] Segment Routing with IPv6
[ 8.229142] In-situ OAM (IOAM) with IPv6
insmod /lib/modules/6.8.12-1021-tegra/updates/drivers/nvpps/nvpps.ko
[ 8.233272] nvpps c6a0000.nvpps: nvpps_probe
[ 8.233448] nvpps c6a0000.nvpps: primary-emac : ethernet@6800000
[ 8.233599] nvpps c6a0000.nvpps: sec-emac node not found
[ 8.233913] nvpps c6a0000.nvpps: ts-capture-interval set to 1000ms
[ 8.234076] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[ 8.241126] nvpps c6a0000.nvpps: Initial operating mode selected as TIMER
[ 8.248024] nvpps c6a0000.nvpps: nvpps cdev(505:0)
[ 8.252790] nvpps c6a0000.nvpps: tsc_res_ns(32)
insmod /lib/modules/6.8.12-1021-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
[ 8.272044] nvethernet 6800000.ethernet: Adding to iommu group 9
[ 8.272652] nvethernet 6800000.ethernet: Virtualization is not enabled
[ 8.278953] nvethernet 6800000.ethernet: failed to read skip mac reset flag, default 0
[ 8.286920] nvethernet 6800000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[ 8.299064] nvethernet 6800000.ethernet: setting to default DMA bit mask
[ 8.305814] nvethernet 6800000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 8.313643] nvethernet 6800000.ethernet: failed to read or invalid MDC CR - default to 5
[ 8.321562] nvethernet 6800000.ethernet: failed to read or invalid force-restart-lane-bringup - default to 0
[ 8.721267] nvethernet 6800000.ethernet: macsec parameter is missing or disabled
[ 8.721466] nvethernet 6800000.ethernet: Macsec not supported/Not enabled
[ 8.725178] nvethernet 6800000.ethernet: eth0 created with 10 DMA channels
insmod /lib/modules/6.8.12-1021-tegra/kernel/drivers/spi/spi-tegra210-quad.ko
[ 8.731011] tegra-qspi 3270000.spi: Adding to iommu group 10
modprobe: FATAL: Module mods not found in directory /lib/modules/6.8.12-1021-tegra
Finding UDC
[ 9.788718] configfs-gadget.l4t gadget.0: HOST MAC 06:d4:0f:7d:b0:a3
[ 9.788909] configfs-gadget.l4t gadget.0: MAC 2a:a7:61:fa:8d:ba
[ 9.789081] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.2# [ 19.936827] tegra-mc 2c00000.memory-controller: sync_state() pending due to bus@0:aconnect@2900000
[ 19.937092] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to bus@0:aconnect@2900000
[ 19.937381] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 3510000.hda
[ 19.937645] tegra-mc 2c00000.memory-controller: sync_state() pending due to 3510000.hda
[ 19.937872] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 13e00000.host1x
[ 19.938122] tegra-mc 2c00000.memory-controller: sync_state() pending due to 13e00000.host1x
[ 19.938347] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 17000000.gpu
[ 19.938600] tegra-mc 2c00000.memory-controller: sync_state() pending due to 17000000.gpu
[ 19.938890] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to 13800000.display
[ 19.940327] tegra-mc 2c00000.memory-controller: sync_state() pending due to 13800000.display
[ 19.941612] tegra186-emc 2c60000.external-memory-controller: sync_state() pending due to bc00000.rtcpu
[ 19.944574] tegra-mc 2c00000.memory-controller: sync_state() pending due to bc00000.rtcpu
[ 19.952890] tegra-pmc c360000.pmc: sync_state() pending due to 4-003c
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
The issue you’re experiencing is likely due to the mechanism for flashing eMMC and NVMe/USB drives being different. The flash.sh command is used for flashing eMMC, while initrd flash is used for NVMe/USB drives.
To flash to an NVMe drive, you can try using the initrd flash method. Here’s an example command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-agx-orin-devkit internal
This command assumes that your NVMe drive is recognized as /dev/nvme0n1p1. You may need to adjust the device name accordingly.
Alternatively, you can try setting up the NVMe drive manually for booting, as described in the Flashing Support — Jetson Linux Developer Guide documentation.
If you’re still experiencing issues, please provide more details about your setup and the error messages you’re seeing.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
It doesn’t work.
I keeps have seeing this: It even not go at far as using SDKManager:
*** no-flash flag enabled. Exiting now… ***
This is NVIDA Jetson AGX Orin develop kit. I had another develop kit. No problem to flash the NVME.
Hi @jin.yu5,
The *** no-flash flag enabled. Exiting now... *** message can appear during the image-generation stage of initrd flashing and is not, by itself, the flash failure.
Your serial log shows that the board boots into the initrd flashing kernel and detects the Samsung NVMe as nvme0. Since the host remains at Waiting for target to boot-up, this appears to be failing during communication between the host and the initrd environment.
While the host is stopped at that message, please run the following command on the host and share the complete output:
ping -6 -c 3 fc00:1:1::2
The initrd flash process uses NFS and SSH over the fc00:1:1::/48 IPv6 range, so this result will show whether the host can reach the target. Please also refer to the Jetson Linux 39.2 initrd flash requirements.
Hello @jin.yu5 ,
Can you please share the steps you used to flash the devices?
We have a guide for this scenario but for JP6, maybe it is worth a try for JP7, guide here: NVIDIA Jetson Orin AGX - Flashing the Filesystem
Be sure to format the NVME before.
As carolyuu mentioned, you need to use l4t_initrd_flash.sh for that scenario.
If when you flashed mmc/internal and can boot and logon to Orin. Does sudo nvbootctrl dump-slots-info return: Current version: 39.2.0 ?
If so you could first try
sudo ./tools/kernel_flash/l4t_initrd_flash.sh  --external-only --external-device nvme0n1 jetson-agx-orin-devkit external
If that fails, then try
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
  -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs \
  --network usb0 \
Format the branch new SSD did the trick. Thanks Jin
