I have problem with my Xavier, recently I had an power outage and my Xavier was runing, after the electricity went up again the Xavier didn’t boot. No video output, dosen’t show on network when connected by Ethernet cable.
So I thought somethin bad went with file system and tried to use SDKManager to flash it in manual mode. Everything went good until Raw to Sparse Image Converter . Most of the messages after are errors.
Info: [ Disk Avail:800.80 GB ]
Info: change working directory to /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
Info: [ Component PreInstall Started ]
Info: current working directory is /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
Info: exec_command: sudo apt-get install -y python
Reading package lists...
Building dependency tree...
Reading state information...
python is already the newest version (2.7.15~rc1-1).
The following packages were automatically installed and are no longer required:
efibootmgr fonts-liberation2 fonts-opensymbol gir1.2-gudev-1.0
gir1.2-udisks-2.0 grilo-plugins-0.3-base gstreamer1.0-gtk3 libcdr-0.1-1
libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5 libcolamd2
libdazzle-1.0-0 libdc1394-22-dev libe-book-0.1-1 libedataserverui-1.2-2
libeot0 libepubgen-0.1-1 libetonyek-0.1-1 libevent-2.1-6 libexif-dev
libexif-doc libexiv2-14 libfreerdp-client2-2 libfreerdp2-2 libfwup1 libgc1c2
libgdcm2-dev libgee-0.8-2 libgexiv2-2 libgom-1.0-0 libgpgmepp6
libgphoto2-dev libgpod-common libgpod4 libilmbase-dev liblangtag-common
liblangtag1 liblept5 liblirc-client0 liblua5.3-0 libmediaart-2.0-0
libmspub-0.1-1 libodfgen-0.1-1 libopencv-contrib3.2 libopencv-objdetect3.2
libopencv-photo3.2 libopencv-shape3.2 libopencv-stitching3.2
libopencv-superres3.2 libopencv-video3.2 libopencv-videostab3.2
libopencv-viz3.2 libopencv3.2-java libopencv3.2-jni libopenexr-dev
libqqwing2v5 libraw1394-dev libraw1394-tools librevenge-0.0-0 libsgutils2-2
libssh-4 libsuitesparseconfig5 libtesseract4 libvncclient1 libwinpr2-2
libxapian30 libxmlsec1 libxmlsec1-nss lp-solve media-player-info
python3-mako python3-markupsafe syslinux syslinux-common syslinux-legacy
usb-creator-common
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Info: [ Component PreInstall Finished Successfully ]
Info: [ Component Install Started ]
Info: exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 3.1
# Target Board Information:
# Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
copying soft_fuses(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0437 ] Generating RCM messages
[ 0.0776 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0803 ] Header already present for /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.1154 ]
[ 0.1455 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.1489 ] Assuming zero filled SBK key
[ 0.1756 ]
[ 0.1782 ] tegrasign_v2 --key None --file /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.1803 ] Assuming zero filled SBK key
[ 0.1816 ]
[ 0.1840 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.1955 ]
[ 0.2240 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.2495 ]
[ 0.2545 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.2602 ] RCM 0 is saved as rcm_0.rcm
[ 0.2977 ] RCM 1 is saved as rcm_1.rcm
[ 0.3005 ] RCM 2 is saved as rcm_2.rcm
[ 0.3024 ] List of rcm files are saved in rcm_list.xml
[ 0.3169 ]
[ 0.3170 ] Signing RCM messages
[ 0.3201 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.3241 ] Assuming zero filled SBK key
[ 0.3242 ]
[ 0.3242 ] Copying signature to RCM mesages
[ 0.3268 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.3303 ]
[ 0.3304 ] Boot Rom communication
[ 0.3329 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.3350 ] RCM version 0X190001
[ 0.3363 ] Boot Rom communication completed
[ 1.3515 ]
[ 2.3588 ] tegrarcm_v2 --isapplet
[ 2.3651 ] Applet version 01.00.0000
[ 2.3840 ]
[ 2.3904 ] tegrarcm_v2 --ismb2
[ 2.4156 ]
[ 2.4242 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.4438 ]
[ 2.4526 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.4605 ] adding BCH for nvtboot_applet_t194.bin
[ 2.4815 ]
[ 2.4870 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.4897 ] Assuming zero filled SBK key
[ 2.4908 ]
[ 2.5478 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.5514 ]
[ 2.5530 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.5544 ] Applet version 01.00.0000
[ 2.5749 ] Sending mb2
[ 2.5751 ] [................................................] 100%
[ 2.5886 ]
[ 2.5905 ] tegrarcm_v2 --boot recovery
[ 2.5922 ] Applet version 01.00.0000
[ 2.6102 ]
[ 3.6182 ] tegrarcm_v2 --isapplet
[ 3.6449 ]
[ 3.6515 ] tegrarcm_v2 --ismb2
[ 3.6587 ] MB2 Applet version 01.00.0000
[ 3.6764 ]
[ 3.6859 ] tegrarcm_v2 --ismb2
[ 3.6919 ] MB2 Applet version 01.00.0000
[ 3.7131 ]
[ 3.7173 ] Retrieving EEPROM data
[ 3.7178 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 3.7221 ] MB2 Applet version 01.00.0000
[ 3.7455 ] Saved platform info in /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
[ 3.7802 ]
[ 3.7803 ] Rebooting to recovery mode
[ 3.7818 ] tegrarcm_v2 --ismb2
[ 3.7830 ] MB2 Applet version 01.00.0000
[ 3.7994 ]
[ 3.7995 ] Rebooting to recovery mode
[ 3.8009 ] tegrarcm_v2 --reboot recovery
[ 3.8026 ] MB2 Applet version 01.00.0000
[ 3.8535 ]
creating dummy /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin
copying bctfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
version 1.0.0
[ 0.0040 ] Generating signature
[ 0.0052 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0067 ] Assuming zero filled SBK key
[ 0.0072 ]
[ 0.0074 ] header_magic: 805514
[ 0.0093 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0105 ]
[ 0.0119 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0132 ] adding BCH for 1_Image
[ 1.0261 ]
[ 1.0281 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 1.0291 ] Assuming zero filled SBK key
[ 1.0787 ]
[ 1.0815 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.8923 ]
[ 1.9753 ] Signed file: /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
Generate header for Image_sigheader.encrypt
Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
Remove temporary file
done.
populating initrd to rootfs... done.
populating /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
version 1.0.0
[ 0.0036 ] Generating signature
[ 0.0050 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0063 ] Assuming zero filled SBK key
[ 0.0069 ]
[ 0.0070 ] header_magic: d00dfeed
[ 0.0085 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0099 ]
[ 0.0112 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0123 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0203 ]
[ 0.0220 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0233 ] Assuming zero filled SBK key
[ 0.0241 ]
[ 0.0267 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0334 ]
[ 0.0342 ] Signed file: /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
Making system.img...
populating rootfs from /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
done.
system.img built successfully.
Existing tbcfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
saving flash command in /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0302 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0341 ] Assuming zero filled SBK key
[ 0.0610 ]
[ 0.0612 ] Generating RCM messages
[ 0.0844 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0867 ] Header already present for mb1_t194_prod.bin
[ 0.1029 ]
[ 0.1059 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.1072 ] Assuming zero filled SBK key
[ 0.1076 ]
[ 0.1091 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.1106 ] Assuming zero filled SBK key
[ 0.1117 ]
[ 0.1133 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.1204 ]
[ 0.1417 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.1732 ]
[ 0.1961 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.1980 ] RCM 0 is saved as rcm_0.rcm
[ 0.2018 ] RCM 1 is saved as rcm_1.rcm
[ 0.2019 ] RCM 2 is saved as rcm_2.rcm
[ 0.2019 ] List of rcm files are saved in rcm_list.xml
[ 0.2019 ]
[ 0.2019 ] Signing RCM messages
[ 0.2032 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.2043 ] Assuming zero filled SBK key
[ 0.2050 ]
[ 0.2051 ] Copying signature to RCM mesages
[ 0.2063 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.2084 ]
[ 0.2084 ] Parsing partition layout
[ 0.2256 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.2290 ]
[ 0.2291 ] Creating list of images to be signed
[ 0.2305 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.2321 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2335 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2347 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2377 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2384 ] adding BCH for spe_t194.bin
[ 0.2531 ] adding BCH for spe_t194.bin
[ 0.2554 ] adding BCH for nvtboot_t194.bin
[ 0.2883 ] adding BCH for nvtboot_t194.bin
[ 0.2944 ] Header already present for preboot_c10_prod_cr.bin
[ 0.3665 ] Header already present for preboot_c10_prod_cr.bin
[ 0.3672 ] Header already present for mce_c10_prod_cr.bin
[ 0.3681 ] Header already present for mce_c10_prod_cr.bin
[ 0.3705 ] adding BCH for mts_c10_prod_cr.bin
[ 0.4265 ] adding BCH for mts_c10_prod_cr.bin
[ 0.5260 ] adding BCH for cboot_t194.bin
[ 0.6431 ] adding BCH for cboot_t194.bin
[ 0.6553 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.6675 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.6762 ] adding BCH for tos-trusty_t194.img
[ 0.7297 ] adding BCH for tos-trusty_t194.img
[ 0.7387 ] adding BCH for eks.img
[ 0.7592 ] adding BCH for eks.img
[ 0.7594 ] adding BCH for bpmp_t194.bin
[ 0.8017 ] adding BCH for bpmp_t194.bin
[ 0.8256 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.8901 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.9040 ] adding BCH for camera-rtcpu-rce.img
[ 0.9350 ] adding BCH for camera-rtcpu-rce.img
[ 0.9443 ] adding BCH for adsp-fw.bin
[ 0.9525 ] adding BCH for adsp-fw.bin
[ 0.9554 ] Header already present for warmboot_t194_prod.bin
[ 0.9606 ] Header already present for warmboot_t194_prod.bin
[ 0.9617 ] adding BCH for boot.img
[ 0.9974 ] adding BCH for boot.img
[ 2.1279 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.7459 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.9476 ]
[ 3.9477 ] Filling MB1 storage info
[ 3.9477 ] Generating br-bct
[ 3.9519 ] Performing cfg overlay
[ 3.9519 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.9554 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg
[ 4.5188 ]
[ 4.5190 ] Updating dev and MSS params in BR BCT
[ 4.5190 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.5959 ]
[ 4.5959 ] Updating bl info
[ 4.5974 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 4.6006 ]
[ 4.6006 ] Generating signatures
[ 4.6018 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 4.6029 ] Assuming zero filled SBK key
[ 5.4095 ]
[ 5.4097 ] Generating br-bct
[ 5.4146 ] Performing cfg overlay
[ 5.4146 ] ['/home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg']
[ 5.4147 ] Updating dev and MSS params in BR BCT
[ 5.4149 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.5098 ]
[ 5.5099 ] Updating bl info
[ 5.5112 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.5156 ]
[ 5.5157 ] Updating smd info
[ 5.5169 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 5.5190 ]
[ 5.5190 ] Updating Odmdata
[ 5.5203 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 5.5220 ]
[ 5.5220 ] Get Signed section of bct
[ 5.5233 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 5.5249 ]
[ 5.5260 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 5.5272 ] Assuming zero filled SBK key
[ 5.5276 ]
[ 5.5276 ] Updating BCT with signature
[ 5.5293 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 5.5309 ]
[ 5.5310 ] Generating coldboot mb1-bct
[ 5.5454 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 5.5495 ] MB1-BCT version: 0x1
[ 5.5499 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 5.5507 ] Added Platform Config 0 data with size :- 3008
[ 5.5546 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 5.5550 ] Added Platform Config 1 data with size :- 19640
[ 5.6018 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 5.6024 ] Added Platform Config 2 data with size :- 24
[ 5.6027 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 5.6030 ] Added Platform Config 4 data with size :- 348
[ 5.6032 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 5.6036 ] Added Platform Config 3 data with size :- 92
[ 5.6240 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 5.6244 ] Added Platform Config 5 data with size :- 56
[ 5.6247 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 5.6252 ] Added Platform Config 7 data with size :- 392
[ 5.6260 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 5.6264 ] Added Platform Config 8 data with size :- 12
[ 5.6264 ]
[ 5.6264 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 5.6264 ] Added Platform Config 9 data with size :- 32
[ 5.6264 ]
[ 5.6264 ] Updating mb1-bct with firmware information
[ 5.6283 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.6300 ] MB1-BCT version: 0x1
[ 5.6306 ]
[ 5.6306 ] Updating mb1-bct with storage information
[ 5.6320 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.6334 ] MB1-BCT version: 0x1
[ 5.6391 ]
[ 5.6403 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 5.6418 ]
[ 5.6429 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 5.6441 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 5.6451 ]
[ 5.6491 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.6507 ] Assuming zero filled SBK key
[ 5.6511 ]
[ 5.6533 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 5.6551 ]
[ 5.6551 ] Generating recovery mb1-bct
[ 5.6566 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 5.6579 ] MB1-BCT version: 0x1
[ 5.6583 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 5.6590 ] Added Platform Config 0 data with size :- 3008
[ 5.6628 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 5.6641 ] Added Platform Config 1 data with size :- 19640
[ 5.6849 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 5.6867 ] Added Platform Config 2 data with size :- 24
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 5.6878 ] Added Platform Config 4 data with size :- 348
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 5.6878 ] Added Platform Config 3 data with size :- 92
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 5.6878 ] Added Platform Config 5 data with size :- 56
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 5.6878 ] Added Platform Config 7 data with size :- 392
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 5.6878 ] Added Platform Config 8 data with size :- 12
[ 5.6878 ]
[ 5.6878 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 5.6878 ] Added Platform Config 9 data with size :- 32
[ 5.6878 ]
[ 5.6878 ] Updating mb1-bct with firmware information
[ 5.6891 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.6905 ] MB1-BCT version: 0x1
[ 5.7162 ]
[ 5.7162 ] Updating mb1-bct with storage information
[ 5.7181 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.7198 ] MB1-BCT version: 0x1
[ 5.7531 ]
[ 5.7543 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 5.7557 ]
[ 5.7568 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 5.7579 ] adding BCH for mb1_bct_MB1.bct
[ 5.7589 ]
[ 5.7603 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.7615 ] Assuming zero filled SBK key
[ 5.7619 ]
[ 5.7640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 5.7658 ]
[ 5.7659 ] Generating coldboot mem-bct
[ 5.7670 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --membct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_4.bct
[ 5.7682 ] Packing sdram param for instance[0]
[ 5.8626 ] Packing sdram param for instance[1]
[ 5.8629 ] Packing sdram param for instance[2]
[ 5.8633 ] Packing sdram param for instance[3]
[ 5.8633 ] Packing sdram param for instance[4]
[ 5.8633 ] Packing sdram param for instance[5]
[ 5.8633 ] Packing sdram param for instance[6]
[ 5.8633 ] Packing sdram param for instance[7]
[ 5.8633 ] Packing sdram param for instance[8]
[ 5.8633 ] Packing sdram param for instance[9]
[ 5.8633 ] Packing sdram param for instance[10]
[ 5.8633 ] Packing sdram param for instance[11]
[ 5.8633 ] Packing sdram param for instance[12]
[ 5.8633 ] Packing sdram param for instance[13]
[ 5.8633 ] Packing sdram param for instance[14]
[ 5.8633 ] Packing sdram param for instance[15]
[ 5.8634 ]
[ 5.8634 ] Getting sector size from pt
[ 5.8648 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 5.8660 ]
[ 5.8661 ] BlockSize read from layout is 200
[ 5.8673 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_4.bct
[ 5.8684 ] adding BCH for /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_1.bct
[ 5.8716 ]
[ 5.8729 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 5.8744 ]
[ 5.8762 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 5.8777 ] Header already present for mem_coldboot.bct
[ 5.8782 ]
[ 5.8800 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.8812 ] Assuming zero filled SBK key
[ 5.8818 ]
[ 5.8835 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 5.8853 ]
[ 5.8854 ] Generating recovery mem-bct
[ 5.8867 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1.cfg --membct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/26185/tmpIsRNFM1_4.bct
[ 5.8879 ] Packing sdram param for instance[0]
[ 5.9824 ] Packing sdram param for instance[1]
[ 5.9829 ] Packing sdram param for instance[2]
[ 5.9829 ] Packing sdram param for instance[3]
[ 5.9830 ] Packing sdram param for instance[4]
[ 5.9830 ] Packing sdram param for instance[5]
[ 5.9830 ] Packing sdram param for instance[6]
[ 5.9830 ] Packing sdram param for instance[7]
[ 5.9830 ] Packing sdram param for instance[8]
[ 5.9830 ] Packing sdram param for instance[9]
[ 5.9830 ] Packing sdram param for instance[10]
[ 5.9830 ] Packing sdram param for instance[11]
[ 5.9830 ] Packing sdram param for instance[12]
[ 5.9830 ] Packing sdram param for instance[13]
[ 5.9830 ] Packing sdram param for instance[14]
[ 5.9830 ] Packing sdram param for instance[15]
[ 5.9830 ]
[ 5.9846 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 5.9861 ]
[ 5.9874 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 5.9887 ] adding BCH for mem_rcm.bct
[ 5.9909 ]
[ 5.9925 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.9938 ] Assuming zero filled SBK key
[ 5.9942 ]
[ 5.9963 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 5.9995 ]
[ 5.9996 ] Copying signatures
[ 6.0012 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 8.2525 ]
[ 8.2526 ] Boot Rom communication
[ 8.2540 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 8.2551 ] BR_CID: 0x880219116450b888180000000a040200
[ 8.2560 ] RCM version 0X190001
[ 8.2763 ] Boot Rom communication completed
[ 9.2919 ]
[ 10.2981 ] tegrarcm_v2 --isapplet
[ 10.3030 ] Applet version 01.00.0000
[ 10.3269 ]
[ 10.3271 ] Sending BCTs
[ 10.3366 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 10.3425 ] Applet version 01.00.0000
[ 10.3588 ] Sending bct_bootrom
[ 10.3595 ] [................................................] 100%
[ 10.3615 ] Sending bct_mb1
[ 10.3652 ] [................................................] 100%
[ 10.3702 ] Sending bct_mem
[ 10.4148 ] [................................................] 100%
[ 10.5321 ]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
Info: [ Component Install Finished with Error ]
Info: [ 8.68 GB used. Disk Avail: 792.12 GB ]
Info: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 9m23s ]
Error: [error]: Run commands failed at step Install: command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
I am flashing from host with Ubuntu 18.04 (no VM).
Any help is appreciated,
Daniel
I looks like raw to sparse was ok:
Can you loopback mount and examine the raw image?
sudo -s
mount -o loop /where/ever/it/is/Linux_for_Tegra/bootloader/system.img.raw /mnt
ls /mnt
umount /mnt
exit
I do not know what error code 8 is, someone else may know.
I did, what you suggested and on first look it does look like everything is OK.
root@ubuntu-dstorc:~# mount -o loop /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/system.img.raw /mnt
root@ubuntu-dstorc:~# ls /mnt
bin dev home lost+found mnt proc root sbin srv tmp var
boot etc lib media opt README.txt run snap sys usr
What i posted in my earlier post was logs, which I exported by SDKManager. This is what is written in console directly
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.3677 ] adding BCH for nvtboot_applet_t194.bin
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.3724 ]
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.3753 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.3772 ] Assuming zero filled SBK key
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.3779 ]
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4390 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4454 ]
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4483 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4509 ] Applet version 01.00.0000
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4657 ] Sending mb2
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4660 ] [...] 100%
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4785 ]
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4803 ] tegrarcm_v2 --boot recovery
10:43:25 INFO : Flash Jetson AGX Xavier : [ 2.4817 ] Applet version 01.00.0000
10:43:26 INFO : Flash Jetson AGX Xavier : [ 2.5049 ]
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5127 ] tegrarcm_v2 --isapplet
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5399 ]
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5450 ] tegrarcm_v2 --ismb2
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5492 ] MB2 Applet version 01.00.0000
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5660 ]
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5682 ] tegrarcm_v2 --ismb2
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.5704 ] MB2 Applet version 01.00.0000
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.6057 ]
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.6070 ] Retrieving EEPROM data
10:43:26 INFO : Flash Jetson AGX Xavier : [ 3.6072 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6089 ] MB2 Applet version 01.00.0000
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6448 ] Saved platform info in /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cvm.bin
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6796 ]
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6797 ] Rebooting to recovery mode
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6817 ] tegrarcm_v2 --ismb2
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.6842 ] MB2 Applet version 01.00.0000
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.7057 ]
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.7057 ] Rebooting to recovery mode
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.7070 ] tegrarcm_v2 --reboot recovery
10:43:27 INFO : Flash Jetson AGX Xavier : [ 3.7081 ] MB2 Applet version 01.00.0000
10:43:29 INFO : Flash Jetson AGX Xavier : [ 3.7327 ]
10:43:29 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(J.0)
10:43:29 INFO : Flash Jetson AGX Xavier : creating dummy /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin
10:43:29 ERROR : Flash Jetson AGX Xavier : 1+0 records in
10:43:29 INFO : Flash Jetson AGX Xavier : 1+0 records out
10:43:29 INFO : Flash Jetson AGX Xavier : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.00012037 s, 34.0 MB/s
10:43:29 INFO : Flash Jetson AGX Xavier : copying bctfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying bctfile1(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying uphy_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying device_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying misc_cold_boot_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying misc_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying pinmux_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying gpioint_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying pmic_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying pmc_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying prod_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying scr_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying scr_cold_boot_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying bootrom_config(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : copying dev_params(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
10:43:29 INFO : Flash Jetson AGX Xavier : Existing bootloader(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
10:43:29 INFO : Flash Jetson AGX Xavier : copying initrd(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
10:43:30 INFO : Flash Jetson AGX Xavier : populating kernel to rootfs... done.
10:43:30 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
10:43:30 INFO : Flash Jetson AGX Xavier : version 1.0.0
10:43:30 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
10:43:30 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0009 ] Generating signature
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0021 ] tegrasign_v2 --key --getmode mode.txt
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0032 ] Assuming zero filled SBK key
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0038 ]
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0039 ] header_magic: 805514
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0054 ] tegrahost_v2 --chip 0x19 --align 1_Image
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0068 ]
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0081 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
10:43:30 INFO : Flash Jetson AGX Xavier : [ 0.0092 ] adding BCH for 1_Image
10:43:31 INFO : Flash Jetson AGX Xavier : [ 0.9520 ]
10:43:31 INFO : Flash Jetson AGX Xavier : [ 0.9535 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml
10:43:31 INFO : Flash Jetson AGX Xavier : [ 0.9545 ] Assuming zero filled SBK key
10:43:31 INFO : Flash Jetson AGX Xavier : [ 1.0132 ]
10:43:31 INFO : Flash Jetson AGX Xavier : [ 1.0162 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
10:43:32 INFO : Flash Jetson AGX Xavier : [ 1.7913 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 1.8549 ] Signed file: /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/Image_sigheader.encrypt
10:43:32 INFO : Flash Jetson AGX Xavier : Generate header for Image_sigheader.encrypt
10:43:32 INFO : Flash Jetson AGX Xavier : Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
10:43:32 INFO : Flash Jetson AGX Xavier : Remove temporary file
10:43:32 INFO : Flash Jetson AGX Xavier : done.
10:43:32 INFO : Flash Jetson AGX Xavier : populating initrd to rootfs... done.
10:43:32 INFO : Flash Jetson AGX Xavier : populating /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
10:43:32 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
10:43:32 INFO : Flash Jetson AGX Xavier : version 1.0.0
10:43:32 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
10:43:32 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0010 ] Generating signature
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0020 ] tegrasign_v2 --key --getmode mode.txt
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0029 ] Assuming zero filled SBK key
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0033 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0034 ] header_magic: d00dfeed
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0050 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0064 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0077 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0088 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0167 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0183 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0193 ] Assuming zero filled SBK key
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0201 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0229 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0282 ]
10:43:32 INFO : Flash Jetson AGX Xavier : [ 0.0290 ] Signed file: /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/boot/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
10:43:32 INFO : Flash Jetson AGX Xavier : Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
10:43:32 INFO : Flash Jetson AGX Xavier : Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
10:43:34 INFO : Flash Jetson AGX Xavier : Making Boot image... done.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing sosfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing tegraboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing cpu_bootloader(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing mb2blfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing mtspreboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing mcepreboot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing mtsproper(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing mb1file(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing bpffile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : copying bpfdtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing scefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing camerafw(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing spefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing drameccfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing badpagefile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/badpage.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing wb0boot(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing tosfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : Existing eksfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/eks.img) reused.
10:43:34 INFO : Flash Jetson AGX Xavier : copying soft_fuses(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
10:43:34 INFO : Flash Jetson AGX Xavier : copying dtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
10:43:34 INFO : Flash Jetson AGX Xavier : Copying nv_boot_control.conf to rootfs
10:43:34 INFO : Flash Jetson AGX Xavier : Making system.img...
10:45:38 INFO : Flash Jetson AGX Xavier : populating rootfs from /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs ...
10:49:23 INFO : Flash Jetson AGX Xavier : done.
10:49:32 INFO : Flash Jetson AGX Xavier : Sync'ing system.img ... done.
10:49:33 INFO : Flash Jetson AGX Xavier : Converting RAW image to Sparse image...
10:49:33 ERROR : Flash Jetson AGX Xavier :
10:49:33 INFO : Flash Jetson AGX Xavier : ---- Raw to Sparse Image Converter v1.0
10:49:33 ERROR : Flash Jetson AGX Xavier : ----------------------------
10:49:33 ERROR : Flash Jetson AGX Xavier : 0: RAW: 4263936( 1041 blks) ==> 28:4263948
10:49:33 ERROR : Flash Jetson AGX Xavier : 1: SKP: 16384( 4 blks) ==> 4263976:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 2: RAW: 4096( 1 blks) ==> 4263988:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 3: SKP: 61440( 15 blks) ==> 4268096:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 4: RAW: 4096( 1 blks) ==> 4268108:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 5: SKP: 33550336( 8191 blks) ==> 4272216:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 6: RAW: 24576( 6 blks) ==> 4272228:24588
10:49:33 ERROR : Flash Jetson AGX Xavier : 7: SKP: 96292864( 23509 blks) ==> 4296816:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 8: RAW: 20480( 5 blks) ==> 4296828:20492
10:49:33 ERROR : Flash Jetson AGX Xavier : 9: SKP: 4448256( 1086 blks) ==> 4317320:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 10: RAW: 3448832( 842 blks) ==> 4317332:3448844
10:49:33 INFO : Flash Jetson AGX Xavier : 11: SKP: 8192( 2 blks) ==> 7766176:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 12: RAW: 65536( 16 blks) ==> 7766188:65548
10:49:33 ERROR : Flash Jetson AGX Xavier : 13: SKP: 397312( 97 blks) ==> 7831736:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 14: RAW: 15552512( 3797 blks) ==> 7831748:15552524
10:49:33 ERROR : Flash Jetson AGX Xavier : 15: SKP: 45056( 11 blks) ==> 23384272:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 16: RAW: 147456( 36 blks) ==> 23384284:147468
10:49:33 INFO : Flash Jetson AGX Xavier : 17: SKP: 4096( 1 blks) ==> 23531752:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 18: RAW: 77824( 19 blks) ==> 23531764:77836
10:49:33 ERROR : Flash Jetson AGX Xavier : 19: SKP: 4096( 1 blks) ==> 23609600:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 20: RAW: 331776( 81 blks) ==> 23609612:331788
10:49:33 INFO : Flash Jetson AGX Xavier : 21: SKP: 4096( 1 blks) ==> 23941400:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 22: RAW: 790528( 193 blks) ==> 23941412:790540
10:49:33 INFO : Flash Jetson AGX Xavier : 23: SKP: 4096( 1 blks) ==> 24731952:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 24: RAW: 57344( 14 blks) ==> 24731964:57356
10:49:33 ERROR : Flash Jetson AGX Xavier : 25: SKP: 8192( 2 blks) ==> 24789320:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 26: RAW: 143360( 35 blks) ==> 24789332:143372
10:49:33 ERROR : Flash Jetson AGX Xavier : 27: SKP: 290816( 71 blks) ==> 24932704:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 28: RAW: 4190208( 1023 blks) ==> 24932716:4190220
10:49:33 INFO : Flash Jetson AGX Xavier : 29: SKP: 4096( 1 blks) ==> 29122936:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 30: RAW: 196608( 48 blks) ==> 29122948:196620
10:49:33 ERROR : Flash Jetson AGX Xavier : 31: SKP: 274432( 67 blks) ==> 29319568:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 32: RAW: 278528( 68 blks) ==> 29319580:278540
10:49:33 ERROR : Flash Jetson AGX Xavier : 33: SKP: 8192( 2 blks) ==> 29598120:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 34: RAW: 434176( 106 blks) ==> 29598132:434188
10:49:33 INFO : Flash Jetson AGX Xavier : 35: SKP: 4096( 1 blks) ==> 30032320:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 36: RAW: 4096( 1 blks) ==> 30032332:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 37: SKP: 1339392( 327 blks) ==> 30036440:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 38: RAW: 49152( 12 blks) ==> 30036452:49164
10:49:33 ERROR : Flash Jetson AGX Xavier : 39: SKP: 368640( 90 blks) ==> 30085616:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 40: RAW: 20480( 5 blks) ==> 30085628:20492
10:49:33 INFO : Flash Jetson AGX Xavier : 41: SKP: 4096( 1 blks) ==> 30106120:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 42: RAW: 16384( 4 blks) ==> 30106132:16396
10:49:33 ERROR : Flash Jetson AGX Xavier : 43: SKP: 4096( 1 blks) ==> 30122528:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 44: RAW: 4096( 1 blks) ==> 30122540:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 45: SKP: 16384( 4 blks) ==> 30126648:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 46: RAW: 4096( 1 blks) ==> 30126660:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 47: SKP: 4096( 1 blks) ==> 30130768:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 48: RAW: 4096( 1 blks) ==> 30130780:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 49: SKP: 8192( 2 blks) ==> 30134888:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 50: RAW: 4096( 1 blks) ==> 30134900:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 51: SKP: 8192( 2 blks) ==> 30139008:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 52: RAW: 4096( 1 blks) ==> 30139020:4108
10:49:33 ERROR : Flash Jetson AGX Xavier : 53: SKP: 8192( 2 blks) ==> 30143128:12
10:49:33 ERROR : Flash Jetson AGX Xavier : 54: RAW: 6426624( 1569 blks) ==> 30143140:6426636
10:49:34 ERROR : Flash Jetson AGX Xavier : 55: SKP: 69632( 17 blks) ==> 36569776:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 56: RAW: 12288( 3 blks) ==> 36569788:12300
10:49:34 ERROR : Flash Jetson AGX Xavier : 57: SKP: 8192( 2 blks) ==> 36582088:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 58: RAW: 1597440( 390 blks) ==> 36582100:1597452
10:49:34 INFO : Flash Jetson AGX Xavier : 59: SKP: 8192( 2 blks) ==> 38179552:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 60: RAW: 327680( 80 blks) ==> 38179564:327692
10:49:34 INFO : Flash Jetson AGX Xavier : 61: SKP: 12288( 3 blks) ==> 38507256:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 62: RAW: 266240( 65 blks) ==> 38507268:266252
10:49:34 INFO : Flash Jetson AGX Xavier : 63: SKP: 28672( 7 blks) ==> 38773520:12
10:49:34 INFO : Flash Jetson AGX Xavier : 64: RAW: 12288( 3 blks) ==> 38773532:12300
10:49:34 INFO : Flash Jetson AGX Xavier : 65: SKP: 12288( 3 blks) ==> 38785832:12
10:49:34 INFO : Flash Jetson AGX Xavier : 66: RAW: 4096( 1 blks) ==> 38785844:4108
10:49:34 ERROR : Flash Jetson AGX Xavier : 67: SKP: 45056( 11 blks) ==> 38789952:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 68: RAW: 6791168( 1658 blks) ==> 38789964:6791180
10:49:34 ERROR : Flash Jetson AGX Xavier : 69: SKP: 12288( 3 blks) ==> 45581144:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 70: RAW: 32768( 8 blks) ==> 45581156:32780
10:49:34 ERROR : Flash Jetson AGX Xavier : 71: SKP: 16384( 4 blks) ==> 45613936:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 72: RAW: 8192( 2 blks) ==> 45613948:8204
10:49:34 ERROR : Flash Jetson AGX Xavier : 73: SKP: 4096( 1 blks) ==> 45622152:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 74: RAW: 864256( 211 blks) ==> 45622164:864268
10:49:34 INFO : Flash Jetson AGX Xavier : 75: SKP: 4096( 1 blks) ==> 46486432:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 76: RAW: 40960( 10 blks) ==> 46486444:40972
10:49:34 INFO : Flash Jetson AGX Xavier : 77: SKP: 4096( 1 blks) ==> 46527416:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 78: RAW: 24858624( 6069 blks) ==> 46527428:24858636
10:49:34 INFO : Flash Jetson AGX Xavier : 79: SKP: 4096( 1 blks) ==> 71386064:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 80: RAW: 73728( 18 blks) ==> 71386076:73740
10:49:34 ERROR : Flash Jetson AGX Xavier : 81: SKP: 839680( 205 blks) ==> 71459816:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 82: RAW: 4096( 1 blks) ==> 71459828:4108
10:49:34 ERROR : Flash Jetson AGX Xavier : 83: SKP: 12288( 3 blks) ==> 71463936:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 84: RAW: 4096( 1 blks) ==> 71463948:4108
10:49:34 ERROR : Flash Jetson AGX Xavier : 85: SKP: 12288( 3 blks) ==> 71468056:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 86: RAW: 4096( 1 blks) ==> 71468068:4108
10:49:34 ERROR : Flash Jetson AGX Xavier : 87: SKP: 12288( 3 blks) ==> 71472176:12
10:49:34 ERROR : Flash Jetson AGX Xavier : 88: RAW: 28672( 7 blks) ==> 71472188:28684
10:49:34 ERROR : Flash Jetson AGX Xavier : 89: SKP: 16699392( 4077 blks) ==> 71500872:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 90: RAW: 24170496( 5901 blks) ==> 71500884:24170508
10:49:35 INFO : Flash Jetson AGX Xavier : 91: SKP: 8192( 2 blks) ==> 95671392:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 92: RAW: 69632( 17 blks) ==> 95671404:69644
10:49:35 ERROR : Flash Jetson AGX Xavier : 93: SKP: 917504( 224 blks) ==> 95741048:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 94: RAW: 17190912( 4197 blks) ==> 95741060:17190924
10:49:35 INFO : Flash Jetson AGX Xavier : 95: SKP: 8192( 2 blks) ==> 112931984:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 96: RAW: 3825664( 934 blks) ==> 112931996:3825676
10:49:35 INFO : Flash Jetson AGX Xavier : 97: SKP: 4096( 1 blks) ==> 116757672:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 98: RAW: 49152( 12 blks) ==> 116757684:49164
10:49:35 ERROR : Flash Jetson AGX Xavier : 99: SKP: 8192( 2 blks) ==> 116806848:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 100: RAW: 4096( 1 blks) ==> 116806860:4108
10:49:35 ERROR : Flash Jetson AGX Xavier : 101: SKP: 16384( 4 blks) ==> 116810968:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 102: RAW: 2916352( 712 blks) ==> 116810980:2916364
10:49:35 ERROR : Flash Jetson AGX Xavier : 103: SKP: 1142784( 279 blks) ==> 119727344:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 104: RAW: 16736256( 4086 blks) ==> 119727356:16736268
10:49:35 ERROR : Flash Jetson AGX Xavier : 105: SKP: 8192( 2 blks) ==> 136463624:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 106: RAW: 14987264( 3659 blks) ==> 136463636:14987276
10:49:35 INFO : Flash Jetson AGX Xavier : 107: SKP: 4096( 1 blks) ==> 151450912:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 108: RAW: 1548288( 378 blks) ==> 151450924:1548300
10:49:35 INFO : Flash Jetson AGX Xavier : 109: SKP: 8192( 2 blks) ==> 152999224:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 110: RAW: 3792896( 926 blks) ==> 152999236:3792908
10:49:35 INFO : Flash Jetson AGX Xavier : 111: SKP: 4096( 1 blks) ==> 156792144:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 112: RAW: 45056( 11 blks) ==> 156792156:45068
10:49:35 ERROR : Flash Jetson AGX Xavier : 113: SKP: 8192( 2 blks) ==> 156837224:12
10:49:35 ERROR : Flash Jetson AGX Xavier : 114: RAW: 4096( 1 blks) ==> 156837236:4108
10:49:35 ERROR : Flash Jetson AGX Xavier : 115: SKP: 16384( 4 blks) ==> 156841344:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 116: RAW: 1171456( 286 blks) ==> 156841356:1171468
10:49:36 ERROR : Flash Jetson AGX Xavier : 117: SKP: 3608576( 881 blks) ==> 158012824:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 118: RAW: 13430784( 3279 blks) ==> 158012836:13430796
10:49:36 ERROR : Flash Jetson AGX Xavier : 119: SKP: 3346432( 817 blks) ==> 171443632:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 120: RAW: 12365824( 3019 blks) ==> 171443644:12365836
10:49:36 ERROR : Flash Jetson AGX Xavier : 121: SKP: 12288( 3 blks) ==> 183809480:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 122: RAW: 81920( 20 blks) ==> 183809492:81932
10:49:36 ERROR : Flash Jetson AGX Xavier : 123: SKP: 16384( 4 blks) ==> 183891424:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 124: RAW: 81920( 20 blks) ==> 183891436:81932
10:49:36 ERROR : Flash Jetson AGX Xavier : 125: SKP: 12288( 3 blks) ==> 183973368:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 126: RAW: 77824( 19 blks) ==> 183973380:77836
10:49:36 ERROR : Flash Jetson AGX Xavier : 127: SKP: 12288( 3 blks) ==> 184051216:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 128: RAW: 73728( 18 blks) ==> 184051228:73740
10:49:36 INFO : Flash Jetson AGX Xavier : 129: SKP: 16384( 4 blks) ==> 184124968:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 130: RAW: 73728( 18 blks) ==> 184124980:73740
10:49:36 ERROR : Flash Jetson AGX Xavier : 131: SKP: 12288( 3 blks) ==> 184198720:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 132: RAW: 73728( 18 blks) ==> 184198732:73740
10:49:36 ERROR : Flash Jetson AGX Xavier : 133: SKP: 12288( 3 blks) ==> 184272472:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 134: RAW: 73728( 18 blks) ==> 184272484:73740
10:49:36 INFO : Flash Jetson AGX Xavier : 135: SKP: 12288( 3 blks) ==> 184346224:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 136: RAW: 65536( 16 blks) ==> 184346236:65548
10:49:36 ERROR : Flash Jetson AGX Xavier : 137: SKP: 16384( 4 blks) ==> 184411784:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 138: RAW: 2662400( 650 blks) ==> 184411796:2662412
10:49:36 ERROR : Flash Jetson AGX Xavier : 139: SKP: 1024000( 250 blks) ==> 187074208:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 140: RAW: 5353472( 1307 blks) ==> 187074220:5353484
10:49:36 ERROR : Flash Jetson AGX Xavier : 141: SKP: 32768( 8 blks) ==> 192427704:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 142: RAW: 8192( 2 blks) ==> 192427716:8204
10:49:36 ERROR : Flash Jetson AGX Xavier : 143: SKP: 32768( 8 blks) ==> 192435920:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 144: RAW: 45056( 11 blks) ==> 192435932:45068
10:49:36 ERROR : Flash Jetson AGX Xavier : 145: SKP: 8192( 2 blks) ==> 192481000:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 146: RAW: 8192( 2 blks) ==> 192481012:8204
10:49:36 ERROR : Flash Jetson AGX Xavier : 147: SKP: 8192( 2 blks) ==> 192489216:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 148: RAW: 12288( 3 blks) ==> 192489228:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 149: SKP: 8192( 2 blks) ==> 192501528:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 150: RAW: 49152( 12 blks) ==> 192501540:49164
10:49:36 ERROR : Flash Jetson AGX Xavier : 151: SKP: 8192( 2 blks) ==> 192550704:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 152: RAW: 16384( 4 blks) ==> 192550716:16396
10:49:36 ERROR : Flash Jetson AGX Xavier : 153: SKP: 8192( 2 blks) ==> 192567112:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 154: RAW: 40960( 10 blks) ==> 192567124:40972
10:49:36 ERROR : Flash Jetson AGX Xavier : 155: SKP: 8192( 2 blks) ==> 192608096:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 156: RAW: 8192( 2 blks) ==> 192608108:8204
10:49:36 ERROR : Flash Jetson AGX Xavier : 157: SKP: 4096( 1 blks) ==> 192616312:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 158: RAW: 8192( 2 blks) ==> 192616324:8204
10:49:36 ERROR : Flash Jetson AGX Xavier : 159: SKP: 4096( 1 blks) ==> 192624528:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 160: RAW: 12288( 3 blks) ==> 192624540:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 161: SKP: 4096( 1 blks) ==> 192636840:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 162: RAW: 4096( 1 blks) ==> 192636852:4108
10:49:36 ERROR : Flash Jetson AGX Xavier : 163: SKP: 8192( 2 blks) ==> 192640960:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 164: RAW: 12288( 3 blks) ==> 192640972:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 165: SKP: 4096( 1 blks) ==> 192653272:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 166: RAW: 4096( 1 blks) ==> 192653284:4108
10:49:36 ERROR : Flash Jetson AGX Xavier : 167: SKP: 8192( 2 blks) ==> 192657392:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 168: RAW: 12288( 3 blks) ==> 192657404:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 169: SKP: 4096( 1 blks) ==> 192669704:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 170: RAW: 4096( 1 blks) ==> 192669716:4108
10:49:36 ERROR : Flash Jetson AGX Xavier : 171: SKP: 8192( 2 blks) ==> 192673824:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 172: RAW: 12288( 3 blks) ==> 192673836:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 173: SKP: 8192( 2 blks) ==> 192686136:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 174: RAW: 12288( 3 blks) ==> 192686148:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 175: SKP: 8192( 2 blks) ==> 192698448:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 176: RAW: 8192( 2 blks) ==> 192698460:8204
10:49:36 ERROR : Flash Jetson AGX Xavier : 177: SKP: 8192( 2 blks) ==> 192706664:12
10:49:36 ERROR : Flash Jetson AGX Xavier : 178: RAW: 12288( 3 blks) ==> 192706676:12300
10:49:36 ERROR : Flash Jetson AGX Xavier : 179: SKP: 8192( 2 blks) ==> 192718976:12
It seems that the raw image (system.img.raw
) is valid, and this is the source for creating a sparse image. Your logs end with these lines which are in the middle of raw to sparse conversion:
Is it correct that things just “stop” here, and that there is no more output? This would be quite unusual unless the raw image contained ext4 errors (e.g., a journal needs to be replayed to fix a bad boot). However, I did not see anything in your notes which indicated the loopback mount had first repaired something.
Are you out of space during this step? Do you see spare disk available at “df -H /where/ever/it/is/Linux_for_Tegra/bootloader/
As an experiment you could try to manually convert the raw to sparse image (assuming you have enough disk space…don’t do this if disk space is low on the host PC). Assumes system.img.raw
is still there, and that this works in the previously mentioned loopback mount (but don’t mount during the mksparse):
cd /where/ever/it/is/Linux_for_Tegra/bootloader
sudo ./mksparse -v --fillpattern=0 system.img.raw system.img
If needed you can first rm the old “bootloader/system.img
” and verify you still have a valid “bootloader/system.img.raw
Does manually creating the sparse image work?
No sorry it didn’t end there, it continued and ended like this
10:52:19 ERROR : Flash Jetson AGX Xavier : 4862: RAW: 4096( 1 blks) ==> 4352697348:4108
10:52:19 ERROR : Flash Jetson AGX Xavier : 4863: SKP: 61440( 15 blks) ==> 4352701456:12
10:52:19 ERROR : Flash Jetson AGX Xavier : 4864: RAW: 1097728( 268 blks) ==> 4352701468:1097740
10:52:19 ERROR : Flash Jetson AGX Xavier : 4865: SKP: 32456704( 7924 blks) ==> 4353799208:12
10:52:19 ERROR : Flash Jetson AGX Xavier : 4866: RAW: 6496256( 1586 blks) ==> 4353799220:6496268
10:52:19 ERROR : Flash Jetson AGX Xavier : 4867: SKP: 94035968( 22958 blks) ==> 4360295488:12
10:52:20 ERROR : Flash Jetson AGX Xavier : 4868: RAW: 15118336( 3691 blks) ==> 4360295500:15118348
10:52:20 INFO : Flash Jetson AGX Xavier : 4869: SKP: 4096( 1 blks) ==> 4375413848:12
10:52:20 ERROR : Flash Jetson AGX Xavier : 4870: RAW: 16384( 4 blks) ==> 4375413860:16396
10:52:21 ERROR : Flash Jetson AGX Xavier : 4871: SKP: 1998127104( 487824 blks) ==> 4375430256:12
10:52:21 ERROR : Flash Jetson AGX Xavier : -- Total: ---------------------------------------------------
10:52:21 INFO : Flash Jetson AGX Xavier : 4872 CHUNK 30064771072(7340032 blks) ==> 4375430268(1068206 blks)
10:52:21 INFO : Flash Jetson AGX Xavier : done.
10:52:21 INFO : Flash Jetson AGX Xavier : system.img built successfully.
10:52:22 INFO : Flash Jetson AGX Xavier : Existing tbcfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
10:52:22 INFO : Flash Jetson AGX Xavier : copying tbcdtbfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
10:52:22 INFO : Flash Jetson AGX Xavier : copying cfgfile(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
10:52:22 INFO : Flash Jetson AGX Xavier : Existing flasher(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
10:52:22 INFO : Flash Jetson AGX Xavier : Existing flashapp(/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py) reused.
10:52:22 INFO : Flash Jetson AGX Xavier : ./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
10:52:22 INFO : Flash Jetson AGX Xavier : saving flash command in /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flashcmd.txt
10:52:23 INFO : Flash Jetson AGX Xavier : saving Windows flash command to /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/flash_win.bat
10:52:23 INFO : Flash Jetson AGX Xavier : *** Flashing target device started. ***
10:52:24 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
10:52:24 INFO : Flash Jetson AGX Xavier : version 1.0.0
10:52:24 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
10:52:24 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0317 ] tegrasign_v2 --key None --getmode mode.txt
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0355 ] Assuming zero filled SBK key
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0623 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0626 ] Generating RCM messages
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0760 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.0797 ] Header already present for mb1_t194_prod.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1019 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1036 ] tegrasign_v2 --key None --getmode mode.txt
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1058 ] Assuming zero filled SBK key
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1061 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1076 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1089 ] Assuming zero filled SBK key
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1099 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1112 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1165 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1409 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1604 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1778 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1790 ] RCM 0 is saved as rcm_0.rcm
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1833 ] RCM 1 is saved as rcm_1.rcm
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1833 ] RCM 2 is saved as rcm_2.rcm
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1833 ] List of rcm files are saved in rcm_list.xml
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1833 ] Signing RCM messages
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1846 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1856 ] Assuming zero filled SBK key
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1864 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1864 ] Copying signature to RCM mesages
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1876 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1894 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.1894 ] Parsing partition layout
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2017 ] tegraparser_v2 --pt flash.xml.tmp
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2039 ]
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2039 ] Creating list of images to be signed
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2052 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2063 ] MB1: Nvheader already present is mb1_t194_prod.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2069 ] Header already present for mb1_t194_prod_sigheader.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2076 ] MB1: Nvheader already present is mb1_t194_prod.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2116 ] Header already present for mb1_t194_prod_sigheader.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2122 ] adding BCH for spe_t194.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2185 ] adding BCH for spe_t194.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2210 ] adding BCH for nvtboot_t194.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2256 ] adding BCH for nvtboot_t194.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2319 ] Header already present for preboot_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2370 ] Header already present for preboot_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2376 ] Header already present for mce_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2913 ] Header already present for mce_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.2932 ] adding BCH for mts_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.3494 ] adding BCH for mts_c10_prod_cr.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.4409 ] adding BCH for cboot_t194.bin
10:52:24 INFO : Flash Jetson AGX Xavier : [ 0.5398 ] adding BCH for cboot_t194.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.5497 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.5620 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.5698 ] adding BCH for tos-trusty_t194.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.6408 ] adding BCH for tos-trusty_t194.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.6493 ] adding BCH for eks.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.6752 ] adding BCH for eks.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.6754 ] adding BCH for bpmp_t194.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.7319 ] adding BCH for bpmp_t194.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.7548 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
10:52:25 INFO : Flash Jetson AGX Xavier : [ 0.9725 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.0332 ] adding BCH for camera-rtcpu-rce.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1058 ] adding BCH for camera-rtcpu-rce.img
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1132 ] adding BCH for adsp-fw.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1329 ] adding BCH for adsp-fw.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1357 ] Header already present for warmboot_t194_prod.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1397 ] Header already present for warmboot_t194_prod.bin
10:52:25 INFO : Flash Jetson AGX Xavier : [ 1.1406 ] adding BCH for boot.img
10:52:26 INFO : Flash Jetson AGX Xavier : [ 1.1705 ] adding BCH for boot.img
10:52:28 INFO : Flash Jetson AGX Xavier : [ 2.2517 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
10:52:28 INFO : Flash Jetson AGX Xavier : [ 3.6355 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6914 ]
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6914 ] Filling MB1 storage info
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6915 ] Generating br-bct
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6926 ] Performing cfg overlay
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6927 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
10:52:29 INFO : Flash Jetson AGX Xavier : [ 3.6936 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.7582 ]
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.7583 ] Updating dev and MSS params in BR BCT
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.7584 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8154 ]
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8155 ] Updating bl info
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8170 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8206 ]
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8206 ] Generating signatures
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8219 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
10:52:29 INFO : Flash Jetson AGX Xavier : [ 4.8232 ] Assuming zero filled SBK key
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5411 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5411 ] Generating br-bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5444 ] Performing cfg overlay
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5445 ] ['/home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg']
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5445 ] Updating dev and MSS params in BR BCT
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.5448 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6283 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6284 ] Updating bl info
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6297 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6343 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6343 ] Updating smd info
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6355 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6371 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6372 ] Updating Odmdata
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6383 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6401 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6401 ] Get Signed section of bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6413 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6428 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6440 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6451 ] Assuming zero filled SBK key
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6454 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6454 ] Updating BCT with signature
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6465 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6481 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6482 ] Generating coldboot mb1-bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6743 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6756 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6760 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6768 ] Added Platform Config 0 data with size :- 3008
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6872 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.6876 ] Added Platform Config 1 data with size :- 19640
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7230 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7238 ] Added Platform Config 2 data with size :- 24
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7243 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7250 ] Added Platform Config 4 data with size :- 348
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7254 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7261 ] Added Platform Config 3 data with size :- 92
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7375 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7381 ] Added Platform Config 5 data with size :- 56
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7384 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.7390 ] Added Platform Config 7 data with size :- 392
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9205 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9228 ] Added Platform Config 8 data with size :- 12
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9485 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9485 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9485 ] Added Platform Config 9 data with size :- 32
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9487 ] Updating mb1-bct with firmware information
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9550 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9617 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9618 ] Updating mb1-bct with storage information
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9666 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9707 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9733 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9779 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9841 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9881 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9913 ] adding BCH for mb1_cold_boot_bct_MB1.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9937 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 5.9986 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0009 ] Assuming zero filled SBK key
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0076 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0100 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0126 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0127 ] Generating recovery mb1-bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0145 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0196 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0203 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0226 ] Added Platform Config 0 data with size :- 3008
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0240 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0251 ] Added Platform Config 1 data with size :- 19640
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0447 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0457 ] Added Platform Config 2 data with size :- 24
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0464 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0473 ] Added Platform Config 4 data with size :- 348
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Added Platform Config 3 data with size :- 92
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Added Platform Config 5 data with size :- 56
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Added Platform Config 7 data with size :- 392
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Added Platform Config 8 data with size :- 12
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Added Platform Config 9 data with size :- 32
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0474 ] Updating mb1-bct with firmware information
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0510 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0522 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0639 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0639 ] Updating mb1-bct with storage information
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0656 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0673 ] MB1-BCT version: 0x1
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0679 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0692 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0703 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0714 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0725 ] adding BCH for mb1_bct_MB1.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0734 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0750 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0760 ] Assuming zero filled SBK key
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0764 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0782 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0798 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0799 ] Generating coldboot mem-bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0817 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --membct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_4.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.0837 ] Packing sdram param for instance[0]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1441 ] Packing sdram param for instance[1]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1444 ] Packing sdram param for instance[2]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[3]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[4]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[5]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[6]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[7]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[8]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[9]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[10]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[11]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[12]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[13]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[14]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Packing sdram param for instance[15]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1447 ] Getting sector size from pt
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1461 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1478 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1478 ] BlockSize read from layout is 200
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1492 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_4.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1505 ] adding BCH for /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_1.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1536 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1550 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1561 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1573 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1591 ] Header already present for mem_coldboot.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1693 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1708 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1719 ] Assuming zero filled SBK key
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1725 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1742 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1757 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1758 ] Generating recovery mem-bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1772 ] tegrabct_v2 --chip 0x19 0 --sdram /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1.cfg --membct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_1.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_2.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_3.bct /home/dstorc/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/13085/tmpliNMZX1_4.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.1785 ] Packing sdram param for instance[0]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2325 ] Packing sdram param for instance[1]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2333 ] Packing sdram param for instance[2]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2333 ] Packing sdram param for instance[3]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2333 ] Packing sdram param for instance[4]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2333 ] Packing sdram param for instance[5]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2333 ] Packing sdram param for instance[6]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[7]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[8]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[9]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[10]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[11]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[12]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[13]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[14]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2334 ] Packing sdram param for instance[15]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2357 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2373 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2385 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2400 ] adding BCH for mem_rcm.bct
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2419 ]
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2436 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml
10:52:30 INFO : Flash Jetson AGX Xavier : [ 6.2445 ] Assuming zero filled SBK key
10:52:33 INFO : Flash Jetson AGX Xavier : [ 6.2449 ]
My system dosen’t seem to run out of space (more than 500gb free).
---- Raw to Sparse Image Converter v1.0 ----------------------------
--- More lines ---
The run of mkspare
went fine (no errors in console). But I can’t tell if it’s okay or not.
Some of the flash messages related to mksparse
are misleading, and it appears all of this was actually successful. In fact, parts of flash which prepared for the flash was successful. Unfortunately I do not have any way of looking up the specific meaning of the return value 8 from:
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
Info: [ Component Install Finished with Error ]
Info: [ 8.68 GB used. Disk Avail: 792.12 GB ]
Info: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 9m23s ]
Error: [error]: Run commands failed at step Install: command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
Boot ROM communicated earlier, some of the images succeeded in flash, and then it basically aborts with this. Can anyone say more about the specific meaning of flash errors return value 8? This pops up a lot.
_av
May 31, 2020, 1:35pm
#8
@danielstorc ,
Will the issue re-occur if you use sdkmanager uninstall, and then try building the flash image and installing it again?
