Flash jetson nano error
I have been failing in the process of burning jetson nano, with the same error every time. Could you help me analyze it?
SDKM_logs_JetPack_4.6.3_Linux_for_Jetson_Nano_modules_2024-08-18_05-37-54.zip (54.0 KB)
Hi 2071921351,
Are you using the devkit or custom board for Jetson Nano?
eMMC or SD module?
What’s your Jetpack version in use? (JP4.6.3?)
Have you also tried using command to flash the board?
