Flash Jetson T4000 fail
I tried to flash the T400 module. The carrier board I used is the board of Jetson AGX Thor Developer Kit, which is tested to be normal when flashing the Kit.
I test both the USB disk with iso file and direct flash with SDKM, both ended in failure.
USB drive ISO installation
I created a bootable USB drive with official L4T ISO image to install the system locally on the module. The flashing process always aborted halfway without completion.
Direct flashing via SDKM
Connected the carrier board’s recovery USB port to the Ubuntu host PC and tried flashing using SDK Manager. The procedure also failed repeatedly.
I have tested both JetPack 7.1 and JetPack 7.2 respectively, and the same failure occurs on both versions. The full SDK Manager log file for JetPack 7.1 flashing is attached for your reference.
(3.3 MB)SDKM_logs_JetPack_7.1_Linux_for_Jetson_AGX_Thor_T4000_2026-07-23_11-49-16.zip
Please advise whether the T4000 module has hardware faults, or if any firmware/patch can fix the flashing interruption issue.
Please try to run below commands under the Linux_for_Tegra
 sudo ./l4t_initrd_flash.sh --erase-all jetson-agx-thor-t4000 internal
I try to flash it with the command, but it fails either.
logs is attached.
logs.txt (674.8 KB)
Do you have other NVMe?
Please try other working NVMe to cross check the issue.
In the attached debug logs, I was using a 128GB NVMe SSD. This drive passed the official Thor Kit test without any issues. I also tested a 500GB NVMe SSD due to capacity considerations, yet the error symptoms and log outputs remained nearly identical.
Please upload the serial console log for further debug.
The logs of the flashing with an Ubuntu host and the serial console are attached for debug.
I changed to use a bigger NVME SSD this time.
MobaXterm terminal output.log (111.4 KB)
terminal_full.log (687.5 KB)
Do you have other T4000 for testing?
If yes, please replace and retry.
If no, please proceed with the RMA.
