Flash Jetson Xavier NX - flash: *** ERROR: flashing failed
I’m trying to flash the Jetson Xavier NX and it fails. I’m using the SDK Manager GUI. It detects the board. I’ve tried flashing JetPack 4.4 and JetPack 4.6, but neither works.
In the terminal, I get this error early in the process, but it continues:
11:17:57 INFO: Flash Jetson Xavier NX - flash: Re-generating recovery ramdisk for recovery image...
11:17:58 INFO: Flash Jetson Xavier NX - flash: ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
11:17:58 ERROR: Flash Jetson Xavier NX - flash: 30412 blocks
11:17:58 INFO: Flash Jetson Xavier NX - flash: _BASE_KERNEL_VERSION=4.9.253-tegra
11:17:59 INFO: Flash Jetson Xavier NX - flash: ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra
11:18:03 ERROR: Flash Jetson Xavier NX - flash: 66117 blocks
11:18:03 INFO: Flash Jetson Xavier NX - flash: Making Recovery image...
11:18:04 INFO: Flash Jetson Xavier NX - flash: copying recdtbfile(/home/lhy27/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
11:18:04 ERROR: Flash Jetson Xavier NX - flash: 20 bytes copied, 0.000329473 s, 60.7 kB/s
11:18:04 INFO: Flash Jetson Xavier NX - flash: Existing mcepreboot(/home/lhy27/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
11:18:04 INFO: Flash Jetson Xavier NX - flash: Existing mtsproper(/home/lhy27/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
11:18:04 INFO: Flash Jetson Xavier NX - flash: Existing mb1file(/home/lhy27/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
And I’m not using a virtual machine.
SDKM_logs_2021-10-23_15-38-38.zip (416.5 KB)
About sudo ./flash.sh jetson-xavier-nx-devkit mmcblk0p1
In the terminal I get this error:
CPU Bootloader is not running on device.
and for another try:
[  33.5088 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[  33.5095 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt of size 199808
[  33.5098 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[  33.5101 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[  33.5103 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[  33.5105 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 209920
[  33.5122 ]
[  33.5123 ] Sending bootloader and pre-requisite binaries
[  33.5145 ] tegrarcm_v2 --download blob blob.bin
[  33.5170 ] Applet version 01.00.0000
[  33.5345 ] Sending blob
[ 1090.2559 ]
Error: Return value 3
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
Please export the full log and attach it here. It should be a zip file.
The full log has been uploaded, thx.
Is this sdcard or emmc module?
The sdcard module
Do you have only one module to validate whether your sdkmanager can flash the board?
