I use ‘–usb-instance ’ to flash my Jetson NX module,
in terminal input “lsusb -t” in my PC:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/16p, 480M
|__ Port 1: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 56, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 110, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 7: Dev 105, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 108, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 14: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 14: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
" --usb-instance – Specify the USB instance to connect to; integer
ID (e.g. 0, 1), bus/dev (e.g. 003/091), or USB
port path (e.g. 3-14). The latter is best."
what is “usb port path”?
