We have purchased 4 unit TX2 modules from a agent, when we mounted them on Jetson TX2 Developer Kit base board and try to flash OS with jetpack3.0 , it always fail with all those modules. We have changed several Jetson TX2 Developer Kit base board and Ubuntu host PC, but the fault as before. We have connect a serial cable to the console and found there was something wrong when boot, the related message is:
[ 2.114554] tegradc 15210000.nvdisplay: DT parsed successfully
[ 2.114654] ------------[ cut here ]------------
[ 2.114657] WARNING: at ffffffc0007c4470 [verbose debug info unavailable]
[ 2.114665] Modules linked in:
[ 2.114667]
[ 2.114685] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.4.15-tegra #1
[ 2.114687] Hardware name: quill (DT)
[ 2.114691] task: ffffffc1f6870000 ti: ffffffc1f6878000 task.ti: ffffffc1f6878000
[ 2.114722] PC is at __tegra_isomgr_register+0x30c/0x4d4
[ 2.114726] LR is at __tegra_isomgr_register+0x30c/0x4d4
[ 2.114750] pc : [<ffffffc0007c4470>] lr : [<ffffffc0007c4470>] pstate: 80000045
[ 2.114764] sp : ffffffc1f687bb30
[ 2.114792] x29: ffffffc1f687bb30 x28: 0000000000000380
[ 2.114806] x27: ffffffc001320000 x26: ffffffc001260000
[ 2.114814] x25: ffffffc000b4b000 x24: 0000000000000000
[ 2.114819] x23: 0000000000000000 x22: 0000000000000008
[ 2.114827] x21: 000000000016e360 x20: ffffffc001320c40
[ 2.114834] x19: ffffffc001321020 x18: 000000000000000b
[ 2.114842] x17: ffffffc000a6da80 x16: ffffffc000a6da80
[ 2.114858] x15: 00000000fa83b2da x14: 2c30303030353231
[ 2.114876] x13: 3d77625f6f73695f x12: 7073692072657473
[ 2.114890] x11: 696765725f72676d x10: ffffffc0012bae88
[ 2.114953] x9 : ffffffc1f687ba80 x8 : 206d6f726620424b
[ 2.114961] x7 : 3030303030353120 x6 : ffffffc0012bb838
[ 2.114970] x5 : 0000000003e7c423 x4 : 0000000000000000
[ 2.114975] x3 : ffffffc1f687b9a0 x2 : 0000000000000000
[ 2.114980] x1 : 0000000000000000 x0 : 000000000000002b
[ 2.114981]
[ 2.115018] ---[ end trace 95e315db6bb23a16 ]---
[ 2.115022] Call trace:
[ 2.115029] [<ffffffc0007c4470>] __tegra_isomgr_register+0x30c/0x4d4
[ 2.115035] [<ffffffc0007c4654>] tegra_isomgr_register+0x1c/0x2c
[ 2.115054] [<ffffffc000417748>] tegra_camera_probe+0x270/0x3d8
[ 2.115073] [<ffffffc000532948>] platform_drv_probe+0x50/0xbc
[ 2.115080] [<ffffffc000530468>] driver_probe_device+0xc8/0x408
[ 2.115083] [<ffffffc000530844>] __driver_attach+0x9c/0xa0
[ 2.115130] [<ffffffc00052e4e4>] bus_for_each_dev+0x58/0x98
[ 2.115135] [<ffffffc00052ff10>] driver_attach+0x20/0x28
[ 2.115139] [<ffffffc00052fa80>] bus_add_driver+0x1f0/0x294
[ 2.115145] [<ffffffc00053162c>] driver_register+0x68/0x108
[ 2.115150] [<ffffffc000532850>] __platform_driver_register+0x54/0x5c
[ 2.115157] [<ffffffc000fe59d8>] tegra_camera_init+0x18/0x20
[ 2.115172] [<ffffffc000081ab4>] do_one_initcall+0xc8/0x1c0
[ 2.115192] [<ffffffc000fbab60>] kernel_init_freeable+0x1d0/0x274
[ 2.115212] [<ffffffc000a5cd6c>] kernel_init+0x10/0xe0
[ 2.115222] [<ffffffc000084e10>] ret_from_fork+0x10/0x40
[ 2.115226] __tegra_isomgr_register(): ISO BW usage:
[ 2.115230] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 2.115233] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 2.115236] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 2.115238] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 2.115241] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=1500000KB
[ 2.115243] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 2.115246] __tegra_isomgr_register(): client=eqos, iso dedi bw=0KB
[ 2.115248] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 2.129223] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 4.658688] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 4.659621] max_iso_bw is relaxed to 1581920KB from 1500000KB
[ 4.659622] ------------[ cut here ]------------
[ 4.659625] WARNING: at ffffffc0007c4470 [verbose debug info unavailable]
[ 4.659628] Modules linked in:
[ 4.659630]
[ 4.659641] CPU: 0 PID: 53 Comm: kworker/u12:1 Tainted: G W 4.4.15-tegra #1
[ 4.659643] Hardware name: quill (DT)
[ 4.659668] Workqueue: events_unbound async_run_entry_fn
[ 4.659671] task: ffffffc1f5923e80 ti: ffffffc1f59b8000 task.ti: ffffffc1f59b8000
[ 4.659689] PC is at __tegra_isomgr_register+0x30c/0x4d4
[ 4.659691] LR is at __tegra_isomgr_register+0x30c/0x4d4
[ 4.659695] pc : [<ffffffc0007c4470>] lr : [<ffffffc0007c4470>] pstate: 80000045
[ 4.659696] sp : ffffffc1f59bba80
[ 4.659698] x29: ffffffc1f59bba80 x28: 0000000000000460
[ 4.659701] x27: ffffffc001320000 x26: ffffffc001260000
[ 4.659703] x25: ffffffc000b4b000 x24: 0000000000000000
[ 4.659705] x23: 0000000000000000 x22: 000000000000000a
[ 4.659707] x21: 0000000000014000 x20: ffffffc001320c40
[ 4.659709] x19: ffffffc001321100 x18: ffffffc000ad5840
[ 4.659710] x17: ffffffc000a6da80 x16: 00000000fa83b2da
[ 4.659712] x15: 000000000002ec2b x14: 000129087a9750c5
[ 4.659714] x13: 0000000000000000 x12: 0000000000000400
[ 4.659716] x11: 00000000000387f9 x10: ffffffc0012bae88
[ 4.659718] x9 : ffffffc1f59bb9d0 x8 : 206d6f726620424b
[ 4.659719] x7 : 3032393138353120 x6 : ffffffc0012bb838
[ 4.659721] x5 : 0000000008a553db x4 : 0000000000000000
[ 4.659723] x3 : ffffffc1f59bb8f0 x2 : 0000000000000000
[ 4.659724] x1 : 0000000000000000 x0 : 0000000000000031
[ 4.659725]
[ 4.659727] ---[ end trace 95e315db6bb23a17 ]---
[ 4.659730] Call trace:
[ 4.659732] [<ffffffc0007c4470>] __tegra_isomgr_register+0x30c/0x4d4
[ 4.659735] [<ffffffc0007c4654>] tegra_isomgr_register+0x1c/0x2c
[ 4.659752] [<ffffffc00086c660>] eqos_probe+0x964/0xfac
[ 4.659765] [<ffffffc000532948>] platform_drv_probe+0x50/0xbc
[ 4.659769] [<ffffffc000530468>] driver_probe_device+0xc8/0x408
[ 4.659770] [<ffffffc000530844>] __driver_attach+0x9c/0xa0
[ 4.659776] [<ffffffc00052e4e4>] bus_for_each_dev+0x58/0x98
[ 4.659779] [<ffffffc00052ff10>] driver_attach+0x20/0x28
[ 4.659782] [<ffffffc00052e9a0>] driver_attach_async+0x14/0x50
[ 4.659784] [<ffffffc0000bf830>] async_run_entry_fn+0x44/0x180
[ 4.659793] [<ffffffc0000b7240>] process_one_work+0x154/0x434
[ 4.659795] [<ffffffc0000b7654>] worker_thread+0x134/0x40c
[ 4.659800] [<ffffffc0000bcebc>] kthread+0xe0/0xf4
[ 4.659808] [<ffffffc000084e10>] ret_from_fork+0x10/0x40
[ 4.659810] __tegra_isomgr_register(): ISO BW usage:
[ 4.659812] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 4.659814] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 4.659816] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 4.659817] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 4.659820] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=1500000KB
[ 4.659821] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 4.659822] __tegra_isomgr_register(): client=eqos, iso dedi bw=81920KB
[ 4.659823] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 5.013095] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 5.021069] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 5.028561] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 5.036503] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 5.043568] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 5.051840] tegra210-adsp adsp_audio: using adma channel page 0
[ 5.058326] tegra210_adsp_audio_platform_probe probe successfull.max_iso_bw is relaxed to 1606496KB from 1581920KB
[ 5.073574] ------------[ cut here ]------------
[ 5.079189] WARNING: at ffffffc0007c4470 [verbose debug info unavailable]
[ 5.086383] Modules linked in:
[ 5.089864]
[ 5.091778] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G W 4.4.15-tegra #1
[ 5.100263] Hardware name: quill (DT)
[ 5.104376] task: ffffffc1f6870000 ti: ffffffc1f6878000 task.ti: ffffffc1f6878000
[ 5.112808] PC is at __tegra_isomgr_register+0x30c/0x4d4
[ 5.118624] LR is at __tegra_isomgr_register+0x30c/0x4d4
[ 5.124452] pc : [<ffffffc0007c4470>] lr : [<ffffffc0007c4470>] pstate: 60000045
[ 5.132779] sp : ffffffc1f687b790
[ 5.136568] x29: ffffffc1f687b790 x28: 00000000000003f0
[ 5.142409] x27: ffffffc001320000 x26: ffffffc001260000
[ 5.148235] x25: ffffffc000b4b000 x24: ffffffc1efa14000
[ 5.154072] x23: ffffffc0008c8334 x22: 0000000000000009
[ 5.159904] x21: 0000000000006000 x20: ffffffc001320c40
[ 5.165752] x19: ffffffc001321090 x18: 0000000000000000
[ 5.171605] x17: 0000000000000000 x16: ffffffc000a6da80
[ 5.177436] x15: ffffffc000a6da80 x14: 0000000000000008
[ 5.183254] x13: ffffffc1f4131630 x12: 0000000000000001
[ 5.189059] x11: 00000000ffffffff x10: ffffffc0011114a8
[ 5.194871] x9 : 00000000000002ca x8 : ffffffc000ac2e00
[ 5.200656] x7 : 0000000000000001 x6 : 0000000000000000
[ 5.206437] x5 : 0000000000000000 x4 : 0000000000000000
[ 5.212193] x3 : ffffffc1f687b600 x2 : 0000000000000000
[ 5.217953] x1 : 0000000000000000 x0 : 0000000000000031
[ 5.223691]
[ 5.225555] ---[ end trace 95e315db6bb23a18 ]---
[ 5.230558] Call trace:
[ 5.233382] [<ffffffc0007c4470>] __tegra_isomgr_register+0x30c/0x4d4
[ 5.240112] [<ffffffc0007c4654>] tegra_isomgr_register+0x1c/0x2c
[ 5.246505] [<ffffffc0008c83c0>] tegra_isomgr_adma_register+0x88/0xe8
[ 5.253332] [<ffffffc0008c92c8>] tegra210_admaif_probe+0x138/0x450
[ 5.259896] [<ffffffc000532948>] platform_drv_probe+0x50/0xbc
[ 5.266004] [<ffffffc000530468>] driver_probe_device+0xc8/0x408
[ 5.272284] [<ffffffc000530900>] __device_attach_driver+0x8c/0xb0
[ 5.278733] [<ffffffc00052e59c>] bus_for_each_drv+0x54/0x94
[ 5.284668] [<ffffffc000530290>] __device_attach+0xc0/0x150
[ 5.290602] [<ffffffc000530a40>] device_initial_probe+0x10/0x18
[ 5.296889] [<ffffffc00052f738>] bus_probe_device+0x90/0x98
[ 5.302832] [<ffffffc00052d430>] device_add+0x3ac/0x584
[ 5.308434] [<ffffffc0007a8af8>] of_device_add+0x50/0x5c
[ 5.314118] [<ffffffc0007a9454>] of_platform_device_create_pdata+0x90/0xe8
[ 5.321372] [<ffffffc0007a95ac>] of_platform_bus_create+0xe4/0x3c0
[ 5.327930] [<ffffffc0007a99f0>] of_platform_populate+0x48/0xac
[ 5.334229] [<ffffffc0008d6088>] tegra186_xbar_registration+0x7c/0x110
[ 5.341155] [<ffffffc0008d6c20>] tegra210_xbar_probe+0x2a8/0x418
[ 5.347557] [<ffffffc000532948>] platform_drv_probe+0x50/0xbc
[ 5.353702] [<ffffffc000530468>] driver_probe_device+0xc8/0x408
[ 5.360021] [<ffffffc000530844>] __driver_attach+0x9c/0xa0
[ 5.365914] [<ffffffc00052e4e4>] bus_for_each_dev+0x58/0x98
[ 5.371883] [<ffffffc00052ff10>] driver_attach+0x20/0x28
[ 5.377589] [<ffffffc00052fa80>] bus_add_driver+0x1f0/0x294
[ 5.383554] [<ffffffc00053162c>] driver_register+0x68/0x108
[ 5.389518] [<ffffffc000532850>] __platform_driver_register+0x54/0x5c
[ 5.396347] [<ffffffc001000bb4>] tegra210_xbar_driver_init+0x18/0x20
[ 5.403106] [<ffffffc000081ab4>] do_one_initcall+0xc8/0x1c0
[ 5.409088] [<ffffffc000fbab60>] kernel_init_freeable+0x1d0/0x274
[ 5.415592] [<ffffffc000a5cd6c>] kernel_init+0x10/0xe0
[ 5.421130] [<ffffffc000084e10>] ret_from_fork+0x10/0x40
[ 5.426878] __tegra_isomgr_register(): ISO BW usage:
[ 5.432252] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 5.439114] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 5.445949] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 5.452769] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 5.459524] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=1500000KB
[ 5.469626] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=24576KB
[ 5.476993] __tegra_isomgr_register(): client=eqos, iso dedi bw=81920KB
[ 5.484026] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 5.505001] OPE platform probe
[ 5.509050] OPE platform probe successful
[ 5.539550] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 5.640538] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.649315] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.657979] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 317.913620] rc.local[723]: RTNETLINK answers: Network is unreachable
[ 318.923111] rc.local[723]: RTNETLINK answers: Network is unreachable
[ 319.931058] rc.local[723]: RTNETLINK answers: Network is unreachable
[ 320.939568] rc.local[723]: RTNETLINK answers: Network is unreachable
[ 321.948476] rc.local[723]: RTNETLINK answers: Network is unreachable
But when we mounted the TX2 module from the Developer Kit, the flash always success, so we think maybe there are something wrong with those “brand new” modules.we have purchased 25pcs modules from the same agent last time, and there are 2pcs have the same fault. can you give us the reason? if necessary, we can provide the SN of those modules.
the full log message and jetpack screen shot are in the attachments:
flash-fail-log.txt (127 KB)
