Hi
I am trying to flash the Nvidia provided Linux image to a Jetson TX2 (on the dev kit board). As my PC runs Ubuntu 17.x, I am running flash.sh from within a Ubuntu 16.04 VM with USB passthrough. At first, everything works fine, but then it gets stuck:
[ 12.2810 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 12.2813 ] [................................................] 100%
[ 12.2936 ] Writing partition mb1_b with mb1_prod.bin.encrypt
[ 12.3208 ] [................................................] 100%
[ 12.3334 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 12.3600 ] [................................................] 100%
[ 12.3720 ] Writing partition spe-fw_b with spe_sigheader.bin.encrypt
[ 12.3854 ] [................................................] 100%
[ 12.3995 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 12.4080 ] [................................................] 100%
[ 12.4207 ] Writing partition mb2_b with nvtboot_sigheader.bin.encrypt
[ 12.4641 ] [................................................] 100%
[ 12.4822 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 12.5284 ] [................................................] 100%
[ 12.5416 ] Writing partition mts-preboot_b with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 12.5883 ] [................................................] 100%
[ 12.6007 ] Writing partition SMD with slot_metadata.bin
[ 12.6578 ] [................................................] 100%
[ 12.6840 ] Writing partition SMD_b with slot_metadata.bin
[ 12.6949 ] [................................................] 100%
[ 12.7043 ] Writing partition master_boot_record with mbr_1_3.bin
[ 12.7579 ] [................................................] 100%
[ 12.7671 ] Writing partition APP with system.img
[ 12.7720 ] [.............. ] 029%
lsusb shows the device as still connected in the VM:
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 0955:7c18 NVidia Corp.
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Syslog contains an interesting entry:
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911434] INFO: task tegradevflash_v:4035 blocked for more than 120 seconds.
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911447] Tainted: G OE 4.13.0-39-generic #44~16.04.1-Ubuntu
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911451] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911455] tegradevflash_v D 0 4035 1311 0x20020004
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911462] Call Trace:
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911480] __schedule+0x3d6/0x8b0
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911486] schedule+0x36/0x80
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911492] schedule_timeout+0x17a/0x360
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911501] ? call_timer_fn+0x140/0x140
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911507] wait_for_completion_timeout+0xad/0x140
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911512] ? wait_for_completion_timeout+0xad/0x140
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911518] ? wake_up_q+0x70/0x70
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911526] usb_start_wait_urb+0x8c/0x170
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911532] usb_bulk_msg+0xbd/0x160
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911539] proc_bulk+0x21b/0x380
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911545] usbdev_do_ioctl+0x993/0x1140
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911551] ? entry_INT80_compat+0x131/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911556] ? entry_INT80_compat+0x12a/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911559] ? entry_INT80_compat+0x123/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911563] ? entry_INT80_compat+0x11c/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911567] ? entry_INT80_compat+0x115/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911571] ? entry_INT80_compat+0x10e/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911575] ? entry_INT80_compat+0x107/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911579] ? entry_INT80_compat+0x100/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911583] ? entry_INT80_compat+0xf9/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911588] usbdev_compat_ioctl+0x10/0x20
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911596] compat_SyS_ioctl+0xc5/0x410
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911600] ? entry_INT80_compat+0xa5/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911607] do_int80_syscall_32+0x63/0x120
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911612] entry_INT80_compat+0x142/0x150
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911617] RIP: 0023:0x8076ac4
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911620] RSP: 002b:00000000ff997dd8 EFLAGS: 00000206 ORIG_RAX: 0000000000000036
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911625] RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00000000c0105502
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911628] RDX: 00000000ff997e00 RSI: 0000000000090000 RDI: 000000000953fe00
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911630] RBP: 00000000f7eb1008 R08: 0000000000000000 R09: 0000000000000000
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911633] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
May 4 16:54:41 ubuntu16vm kernel: [ 3865.911635] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
I have tried it several times, and the script gets stuck in the same step every time, although at a different percentage (29%, 64%, and even 0%). The syslog message shows up every time. I am using Virtualbox with USB 3.0 Passthrough.
