I’m working with the Jetson Xavier NX dev (I think, as it has 16gb local memory) and there are two available device trees to flash,
tegra194-p3668-0001-p3509-0000.dtb and tegra194-p3668-0000-p3509-0000.dtb.
I believe, both are very similar and I think the p3668-0001 device tree is the correct one, however I would liked to know how to flash the p3668-0000 tree, to keep the hardware team happy when diagnosing hardware issues.
Anyways another trick that I consider faster is to update only the device tree by modifying the /boot/extlinux/extlinux.conf file to something like:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
FDT /boot/dtb/tegra194-p3668-0001-p3509-0000.dtb
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
The new line that you should need is the FDT one. That way you should only need to copy (through scp or USB flash drive) the dtb file to the specified file path.
