Is flashing the Xavier Drive platform from an Ubuntu 16 VirtualBox guest (Ubuntu 18 host) supported?
Currently the SDKManager does not Support Ubuntu 18, therefore i have to use an Virtual Machine, however I forwarded the USB IDs 0955:7019 and 0403:6011 to the Virtualmachine.
- The Xavier reboots when i start flashing, i assume connection is fine
- I get different Errors while flashing, sometimes invalid arguments errors sometimes “error-target-port-mismatch”.
The Xavier system is connected via an hub to the Bridget network port. The host is DHCP server for this network and i can access the drive platform when it boots up via ip and ttyUSB.
Therefore my questions:
- Is flashing from an VM supported, did I miss something?
- Is there an Ubuntu 18 (beta/alpha) version of the SDK Available?
