How to set ODMDATA=0x90000 and Flash the DTB partition ?
I am using command
sudo ./flash -r -k kernel-dtb jetson-tx2 mmcblk0p1
How to check value of ODMDATA ?
I have refereed PLATFORM ADAPTATION AND BRING-UP GUIDE and default ODMDATA=0x10900000
i want to change in ODMDATA=0x90000
Ranjit
ranjit.jambhale,
In your usecase, you are using jetson-tx2.conf under Linux_for_Tegra.
As you see this file, it is linked to p2771-0000-devkit.conf.
jetson-tx2.conf -> p2771-0000-devkit.conf
Also, p2771-0000-devkit.conf includes “p2771-0000.conf.common”.
Thus, to modify ODMDATA, please just go to p2771-0000.conf.common and modify below line.
local kerndtbfab="-c03"; # default = C03
<b>ODMDATA=0x1090000; # default = C0X</b>
Hi wayne,
with above changes able to detect wifi module 8260ngw
Ranjit
